Question about Nikon Coolpix 5600 Digital Camera
It doesn't turn on
I have changed batteries and the camara doesn't turn on. I tried wih different batteries, just in case they were old, but nothing happens.
What could happen?
Thanks,
marisa
  • 2 more comments
  • Anonymous May 02, 2008
    I've tried changing the batteries and have cleaned the existing ones. Could I have a faulty memory card?
  • Anonymous Jul 04, 2008
    I have the same problem. Also tried with different batteries and different memory sticks
  • Ultimate93 Jul 15, 2008
    I have the same problem. I didn't buy the camera my parents did and they don't know anything about quality or technology. All I can say is toss it and buy a sony camera, you will never have a problem with a sony camera
  • coolguy190 Oct 11, 2008
    Mine has the same problem, but when I hold down the 'power' and 'image review' buttons it doesn't turn back on. I've held it down for FIVE WHOLE FREAKIN' MINUTES and it still doesn't turn on! HELP ME!!!
Mine did the same thing and i put new batteries in and held image review buton while pressing power and it turned on
Posted on Aug 18, 2008
I Just Called Nikon USA and they told me you need to use rechargeable batteries and regular alkaline batteries, you cannot use superduty batteries.
Posted on Jul 15, 2008
I changed the batteries in my stc-tgl2m, re-set my time/date info and everything seemed fine. When I came back the next day it hadn't taken any pictures and I noticed the time/date had not changed. I shut...
Look for corrosion on the terminals that the batteries connect to. Make sure these are shiny. It sounds like you are not getting the right voltage. With a camera that old the contacts may have gotten some battery acid on them at some point.
Nov 20, 2013 | Stealth Cam Wildview Game Camera -...
My camara does not turn on only when it is connected to the charger
Did you mean that the camera turns on only when connected to the charger? then in this case the battery is weak and so does not support the camera current requirement.
Replace battery.
Apr 14, 2011 | Kodak Cameras
Turned on camara lens came out and wont go back in, pushed power button makes a sound but nothing happens
Have you tried changing the batteries with a brand new pair? I had the same problem once and it was because I had one old battery and one newer one.
Nov 06, 2010 | Samsung SL502 Digital Camera
I have a kodak v603 when i try and turn it on i have a red light that flashes under the camara icon on the top left next to the screen. the camara dosent seem to work at all. can any one please help thanks
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 01, 2010 | Kodak EasyShare V603 Digital Camera
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
My camera doesn't come on
Are you using Lithium batteries?
ALL Kodak cameras have huge problems with alkaline batteries.
Hope this helps.
Jan 17, 2008 | Kodak EasyShare One Digital Camera
PLZ Help
If you bought it new the warranty should cover it...send it back to sony. If not you may have to take to a repair center
Dec 06, 2007 | Sony PlayStation Portable (PSP) Console
CAMARA turns off when i press to take a photo
I have the same camera... and it was doing the same thing AFTER i changed my old batteries, because they were getting low. It was only after i put in the NEW batteries that i had this problem... I tried putting the old batteries back in and sure enough it worked again, so it probably all just depends on the brand of the battery you use.
Oct 09, 2007 | Fuji FinePix A500 Digital Camera
Nikon Coolpix 5600 Digital Camera Logo
189 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
