Question about Pioneer PRS-D5000SPL Car Audio Amplifier
Pioneer prs-d5000spl was all ok yesterday now isnt working and light is flashing checked fuses but all ok so i cant understand why its not working????????
    Problem Solver:
  • 5 Answers
That amp is not stable at one ohm.go to 12 volt web site an punch in the number of speakers and if they are svc or dvc it will give you the wiring diagram and the ohm.only go with two or four ohm with that amp.
Posted on Mar 22, 2009
  • 27 Answers
This sounds like an amplifier that trying to push a lower impedance load than its supposed to. Typical aftermarket car speakers have a 4ohm reading per voicecoil. By running more than one speaker per channel you can get more power(sometimes alot more) from the amp by feeding it a 2ohm load or more. If the amp isn't designed to handle ratings less than 4ohms a channel it will overheat and shutdown.
Posted on Mar 21, 2008
6ya staff
SOURCE:
Fan isnt working in my honda esi
If the fuses are ok, then I suggest check motor fan wires and harnesses connections or motor fan itself.
Aug 31, 2012 | Honda Cars & Trucks
2005 Dodge Magnum RT. Left turn signal in rear, flashes fast rear bulb replaced but blinker still blinks fast occassionally and rear turn signal light socket has no voltage when this happens. Where is the...
When its blinking fast look at both front and rear to verify which bulb isnt flashing. If the right works OK, then the flasher is OK. The flasher is INSIDE the front control module/integrated power module. If you cant find the problem, you may need a dealer to check it.
Aug 29, 2011 | 2005 Dodge Magnum
It seems my pioneer prs x720 won't ground out to my frame on my car, i have the power 12v wire connected striaght to the battery. Would it be the fuse on that wire? or would it be just because it's not...
the ground is the most important part of a car system. you should always ground directly to the frame and on a piece of bare clean metal...sand thepaint off if necessary. if not that check the fuse on the power wire if its a glass tube fuse it may have abad connection tht you cannot see under one of the end caps. go with a maxi or anl fuse!
Sep 14, 2010 | Pioneer PRS-X720 Car Audio Amplifier
My Sony reader prs-600 is frozen. The reset button doesn't do anything. How do I unfreeze it? A part of my screen still works, but a big part doesn't. What can i do?
Try holding the reset for 5-10 seconds, then flip the power switch quickly, three times. If this doesn't work, check the light next to the power switch. If it is flashing yellow, follow the same process. It might take up to three tries.
Jul 21, 2010 | Sony Reader Touch PRS-600
I have a pioneer gm-d8400m the amp isnt working
flashing light could mean a few different things. 1- constant power may not be there. check with a test light or multimeter. should read around 12 volts. it would be a good idea to check all the power and ground leads. make sure u have a good ground. 2- bad sub. im assuming sub since its a monoblock amp. you can meter the subs. make sure the total ohm load is no less than 2 ohms. any lower the amp will go into protect mode. 3- bad amp. power supply may be bad. the newer pioneer amps are full of protection circuits. ive been a professional installer for a shop about 8 years and we sell pioneer. hope it helps.
Dec 25, 2009 | Car Audio & Video
Car Radio just stoped working.
My same model did this too. The wiring harness may have gone bad. Try direct wiring the stereo or replacing the wiring harness if you can get one. This fixed the problem for me.
Jun 03, 2009 | Pioneer DEH-P6800MP CD Player
1987 Jeep Cherokee pioneer, all gauges don't work
check your fuses under dash use test light ground it, your doing negative test ,test light on, fuse ok.
do that each of them you must turn your keys on don't start the car , in order to check.. good luck!!
Mar 09, 2009 | 1993 Jeep Cherokee Country
I have a Pioneer VSX-517K that does not powers up. I also do not get the standby led to light up. The fuses are ok and the stand by voltage is 5V. I do not understand the connections ACRY or ACWP and...
There Is A Little Thyristor On The Side Of The Main Power Board look real close youl see it its on the green back side mines burnt to i cant figure out the part # to change it because its burnt if you have any luck ost it please
Oct 19, 2008 | Pioneer Audio Players & Recorders
Power problem avic-N1
I removed the battery terminals and then reconnected and now my navigator doesn't work. When I take the faceplate off there is a flashing red light
Are there any internal fuses that I can check. External ones seem to be ok
Feb 28, 2008 | Pioneer AVIC-N1 Car DVD Player
Lights dim
3000 watts divided by 12 volts=267 amps...how hot is your alternator...have you considered a separate alternator or a battery isolator?
Jan 09, 2008 | Pioneer PRS-D5000SPL Car Audio Amplifier
Pioneer PRS-D5000SPL Car Audio Amplifier Logo
245 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
