Question about Motorola BDN6648C Professional Headset
Motorola BDN 6648C headset. Limiting
Does the above headset have a limiter on the received audio, and if so, what SPL is it set to?
Many thanks,
Eddie Jewell
Noise Consultant
2 Suggested Answers
SOURCE: Motorola HS850 Headset gone silent
I bought a new HS850 and guess what, I got this hearing problem on the very first day ...phew ! I did the pairing with my Motorola A1200 phone and it worked for once, even the sound was coming in the earpiece and then I put it to charge for the first time and once done, I again started it up and it got connected with the phone and after that there was no sound in the ear piece. I was going nuts....about what could be the problem.
So i decided to delete the earlier paired profile from my phone and do the pairing again and guess what...It Worked....:) So you can try that out too....
Posted on Aug 26, 2008
Staples shredder parts
You can try cleaning it and maybe limiting shredding to one sheet at a time.
Jan 14, 2014 | Office Equipment & Supplies
Is it possible to limit the volumn so that it cannot be put above 33 on the scale either from remote or on side of TV? Tried unlocking parental control, setting volumn and then relocking. Didnt work
volume limiting is self defeating because of the various volumes from different shows and different section of the shows. so there will not be a volume limiting switch/ mode on your set.
Oct 08, 2013 | Televison & Video
What gauge speaker wire use for yamaha R-v905 Receiver
The usual gauges range from 18 to 16 with one limiting factor being the ability of the receiver and speaker terminals to handle larger gauge wire
Jan 28, 2013 | Yamaha R-V905 Receiver
Hi! the M.vol does not get above 6db.. how can i fix it?
Your receiver has a customizable setting for volume limiting control, up to +18dB maximum.
Find your system setup button either on the front panel of the receiver or the remote control and press it, then press enter. On the display it will show number one, a two and a three. 1 is for speakers, 2 is for input and 3 is for option. You want to select number three.
Use the right arrow key to highlight number three with the cursor and press enter. Use your up or down arrow key to select the next item that appears on the display in a list. The first thing listed is the setting for the volume limit control. Use your right or left arrow key to select a limit up to 18dB which is the maximum, or select off, which is also the maximum. Then press enter.
Aug 20, 2011 | Denon AVR-1507 Receiver
Hi I have the T5622 talkabout with a PTT headset. I can transmit OK but I am not receiving anything other than a ''click'' when the other person transmits. I have tested the headset and I am able to recive...
Here a few thoughts which come to mind.
1. You do not mention whether the radios communicate with the headset no on the radio. I will at this point, assume they do.
2. Be certain to have the radio SHUT OFF when plugging in the audio device.
3. Check your VOX settings. It could be your radio is going into VOX mode.
4. Only use the PTT button on the headset. Do not press the PTT on the radio at any time while using the headset.
5. Check that you have CALL TONES shut off.
6. Lastly, if nothing else works, go back to a basic mode, and set both radios where there are no special features turned on. ie turn off CODE, Qt Filter, VOX, Call Tones, etc.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Feb 05, 2010 | Motorola Talkabout T5720 (7 Channels)...
Crate bass amp bt220 limit led is flashing with the volume only at half
You can reach the limiting IRRESPECTIVE of where the volume control is set when you have a guitar or other source that has HIGH output.
Guitars that have battery in them with internal amplifiers are an example of a high output guitar. Plain inductive pickups may require the volume control to be set at say 70% to reach limiting.
Please NOTE that the volume control is NOT linear, but is an "audio taper".
Limiting means you are probably driving it too hard. Many learn the hard way when speakers and thee power amp fail.
When the cone is driven too far beyond the pole pieces of the magnet, then the IMPEDANCE of the speaker becomes relatively low and can damage the power amp. The limiter tries to prevent this by sensing the current and or voltage and will back off the gain internally. This causes distortion when it happens.
Dec 14, 2009 | Crate Music
Maual for Motorola H350 bluetooth headset
Hi - You can download the manual from the link underlined in blue below:
H350
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 19, 2008 | Motorola Mobility H350 Wireless Headset
Moto site is a bit difficult to navigate, but manual is on there...
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H350_QSG.pdf
I still can't seem to get the audio tones under control though
(ring tone for 5 seconds of call and at random other times)
May 12, 2008 | Motorola Mobility H350 Wireless Headset
Reg: H700 connection with sony ericsson 580i
You may have to get a bluetooth headset specifically used with Ericson or change bluetooth setting on your cell to handsfree
Jan 08, 2008 | Motorola Mobility H700 Wireless Headset
Motorola BDN6648C Professional Headset Logo
87 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
