I have a cruzer mini 256MB. After a long time of working fine it now is recognised as a ADIR ROM device and i cannot get to the data. How can I fix this or get it repaired ?
    Genius:
  • 1,601 Answers
I just expereienced this same issue and this is what I did to resolve.
Step 1. Back up your registry.
Step 2. Look and see if you now have a key called HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USB\Vid_0781&Pid_1234 and a key called HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USB\Vid_0781&Pid_5150.
Step 3. Delete Both (Note the the latter is the one for your Cruiser but you should start fresh.)
Step 4. Reboot (Make sure you don't have the flash drive plugged in.)
Step 5. Once logged back on, install the flash drive. It will still go thru the routine of hardwareI have a cruzer mini - 1.gif discovery but most likely will not work correctly. You should notice that the key HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USB\Vid_0781&Pid_1234 is back but the later is still gone.
Step 6. Change the following keys to the values indicated..
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USB\Vid_0781&Pid_1234\12345678
DeviceDescrip FROM ADirRom TO Sandisk Cruzer
LocationInformation FROM ADirRom TO Sandisk Cruzer
and ADD the Following
Driver {36FC9E60-C465-11CF-8056-444553540000}\0013
Service USBSTOR
Step 7
Remove the drive and reinstall. If you are as lucky as I, you may still get an initial message about can't find a driver for the Adir, but then the hardware detection will start anew and correctly recogize as a Cruiser Mini.
Posted on Mar 20, 2008
SOURCE:
I lost the directions for using a micro mini
Find a USB-port on your computer.
Insert the flash-drive into the USB port.
Windows will report "found new hardware", and will assign a "drive-letter" (e.g., 'A:' is your diskette drive, 'C:' is your disk-drive, 'D:' is your CD-ROM device) to the device.
Then, use "Windows Explorer" to drag-and-drop files onto the new drive-letter (probably 'E:').
Nov 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I plug the sandisk in to the computer & it doesn't light up nor make the noise. I plugged another one in just to make sure it wasn't the USB drive, the other one worked like a champ. What do I have to...
kindly go to control pannel and and see that removable media device is configured and also check the drivers for it in device manager to ensure that fault is not on sofware end ,if this does not show and green......then try changing the port you insert it into hopefully this will fix the issue else consult local hardware shop for recovery of the data in it
and also get it replace if under warranty
thanks and regards
kindly rate this solution
Oct 22, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
The dvd rom drive does not read nor write
Sounds like it could be a faulty drive. Will it play any CD/DVD like a data or music one?
Mar 22, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
SanDisk Cruzer Titanium 4gb NOT WORKING !!!
bad news bro, the disk isnt initialized. your data is long gone only a data lab may get them back
Mar 10, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
My 2 GB cruzer just stopped working
Hi there
there are many things that could go wrong it is either a usb driver error which would cause a driver conflict and the device not to be recongised or the drive is dead since flash memory has a limited read and write life .To solve this problem you need to try both or one (if one of the solutions work)
(To solve usb driver conflict)
try using it on another computer and if it recognises then follow the instructions on here http://www.aeonity.com/trialerror
(To recover files)
Try it on another computer
if it recognises on the other computer go to start>run and type cmd
then type chkdsk(space)(letter of drive with :)(space)/F
this should fix the errors on it
If it recognises on the otehr computer but files are missing you can recover your data by using recuva (www.recuva.com) just save it, install and open it (it has instructions
Nov 15, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you use sandisk cruzer mini 256mb
your problem is how to use pen drive
PEN DRIVE WITH DATA CAN BE INSERTED INTO AVAILABLE TYPE OF USB PORTS ON YOUR COMPUTER .
THE SYMBOL OF THE PEN DRIVE APPEARS ON YOUR MY COMPUTERB WINDOW .RGT CLICK .OPEN.Product Description
The Sandisk Cruzer Mini is a truly portable, truly useful pocket size data storage device that happens to look cool as well. Its stylish, diminutive design can be slipped into a pocket or purse for easy transport or data files, image files, video and audio, between home or office and virtually anywhere else. Fully compatible with Windows 98SE, ME, 2000, XP and Mac OS 9.1+, OS X v.10.1.2+
Oct 01, 2008 | Computers & Internet
My Hp pavilion notebook dv 9203tx is no longer recognising the dvd drive, it is not coming up in the device manager either nor in the bios. The drive is working will open can hear it spinning when you put...
You might have a lose conection with the rom data cable....che ch the both ends of the ROM data cable
<PLEASE RATE ME AS FIXYA>for my help......................
Jul 31, 2008 | HP Computers & Internet
USB flash disk not working
Assuming you are using a Cruzer Micro Drive with U3 Smart, things can be a little confusing because the drive actually shows up as two independent devices. When you insert the drive, there should be two devices showing up in your list of drives. One of them is installed as a CD Rom Drive and the other one is a Removable Drive. If you double click on the CD Rom Drive instead of the Removable Drive and you don't have any U3 applications mapped to the CD Rom Drive, then you'll get an insert disk message because Windows thinks that the CD Rom Drive is empty. Just use the Removable Drive if you want to simply install and transfer files.
Jan 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My computer doesnt recognise my A1200
if other usb devices are recognized,i advice u to change the mini-usb cable and give it a try....it'll work..and also be sure that u have u r micro-sd properly fixed in the slot....
Oct 29, 2007 | Motorola Mobility A1200
SanDisk 1GB Cruzer Titanium USB Flash Drive - device not recognised
I've had this same problem with a number of Cruzer Titaniums. In my case, it seemed to have been due to data corruption. There seems to a section of the flash that is dedicated not to storage but to helping the computer recognize the device. Once this gets trashed, I don't know of a way that the end user can fix the problem. What a waste, because in all other aspects the device is probably still ok. Kind of like a PC with a corrupted BIOS image.
Jan 03, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
Computers & Internet Logo
1,931 people viewed this question
Ekse
Alun Cox
