Model DE713 Dryer functions great BUT does not heat - takes days to dry clothes.Model DE713 Dryer functions great BUT does not heat - takes days to dry clothes.
AnonymousAug 17, 2008
dryer get hot but won't spin.dryer get hot but won't spin.
You can't post conmments that contain an email address.
Check your fuses or breaker...If you have fuses, replace both 30 amp fuses. If you have breakers, flip breaker to OFF then back to ON, then try your dryer to see if it heats.
I have the same problem with the same model Maytag dryer. I called a repairman and paid a hefty service charge and the repairman found that the electronic control board needed to be replaced. This particular part (Part #8558455) costs between $250 and $350. Evidently there are many people with the same problem.
This sounds like the drum's drive belt broke. But also ensure there isn't a problem with the drive motor. Do you still hear a motor running when you turn it on? If so, you'll need to replace the drive belt.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
The Link below will show you the configuration for all dryers. Choose the one that looks most like yours keeping in mind that some dryers are made under several different names: Good Luck
hi thanksfor the question the noise that you hear could be the blower wheel this is a very common problem with maytag the blower is located at the left front
you may need to replace the heating coil from the back... i have the unit pulled apart as we speak :).... also make sure to check the connections on the back switch to the heat selector! if you need pictures i would be more than happy to get them for you please contact me a Admin ........ at .......WhyPayForHelp .... .... dot org ... the e-mail is "encrypted but you should be able to figure it out :)
