Question about Sony PlayStation 2 Slimline Console
Broken switch at back. Where to get a cheap replacement part.
My other half kindly volunteered to help repair my console V15 (77003)....ended up breaking the switch at the back (top came off the switch) that tells the laser to go do it's stuff.  I'm not happy:o( especially since I just put a new laser in.
What I want to know is where I can get the part either in the UK or somewhere reliable elsewhere.  I live in an area that is short of everything.
    Problem Solver:
  • 34 Answers
Call a toll free playstation number at 1-800-222-sony
(1-800-222-7669
Posted on Aug 29, 2008
SOURCE:
1995 Gmc Yukon. Need wiring diagram. Could anyone suggest something
Hello Mini,
Popular USA market vehicles: Totally FREE wiring diagrams are
available from the BBB Industries website at:
BBB Industries Premium Alternators Starters Power Steering Products
Registration is required as these are typically
REAL FACTORY drawings...
((and TECHNICAL SERVICE BULLETINS... TSBs )).
State your problem... perhaps some of the honest & sincere volunteers here can actually help you...
Hope this helps.
Carnac the Magnificent
Feb 14, 2018 | GMC Cars & Trucks
Hi, I am having a problem with my rf adapter for my sega genesis specifically the end is broken off how should i fix it?
  • Well, if it broke off right flush with the pack then you would have to split the pack and re-soldier the wires on. This can be a big pain. No easy way but to carefully split it open. The original adapters sort of split in half.
  • There is a little flex part on the end of the wire before the actual adapter. If it broke off there then you can carefully splice off the little end piece lengthwise making sure not to cut the wire itself.
  • When that is removed then you can splice the two wires together. I recommend soldiering them together and insulating with shrink tube. Electric tape will work temporarily (see photo)
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 02, 2011 | Sega Genesis Console
It's broken in half
Unfortunately, if your DS is broken in half, you will need to get it repaired by Nintendo.You can call them at 1-800-255-3700 for a repair estimate.
May 02, 2011 | Nintendo DS Lite Console
How do you replace the coupler
Remove end caps of consol///remove two screws at the end of consols///flip consol up//unplug lid switch///remove two clamps with screw driver they pry out// washer casing will lean forward and come right off////you will now see the pump and motor remove two clamps of pump//there are two clamps on motor may be screws in those clamps look close///the coupler is there one half on motor one half on gear gearcase I use a socket and small hammer to bang each half on//put in middle section of coupler reverse the teardown to put back togeather....If I helped you Please VOTE..if you need more help please ask good luck
Feb 04, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Gearshift seems to have broken linkage..no connection with gears. Can it be fixed (ie, broken linkage) or does it need to be replaced?
there is a common problem with the shift cable bushing. so take out the console and examine the connection between the cable ends and the shifter levers. possibly the cheap little repair kits they sell on ebay for less than 20 bucks will set you right. if the cables themselves are broken, you need to get another set of those, cheaper at autozone or advance than at a dealer.
Aug 18, 2010 | 1997 Saturn SL
Broken door switch
on the corners of unit console ,,are plastic end caps,,pull them of with your hand ,,grasp it and tug hard,,now you see 2 a scew under each cap..remove screws ,,than flip the console back...now under the console theres three screws holding lid dowb,,remove them slide lid forward ,,,but screw for door switch are on the bottom of front door panel..always unplug first...onthejob
Jan 15, 2009 | Kenmore 63942 Dryer
How do i remove the lid to replace a lid switch?
quite an easy repair, you tube videos show how to remove the console, http://www.youtube.com/watch?v=vogysB7XOc8 the switch has problalby broken in half which is why the screws fall out,not uncommon.
Dec 07, 2008 | Kenmore 24032\24036 Top Load Washer
Turns on but has black scratchy screen
Make sure that the console has its A/V cables plugged into the back of the console and the television, if it is and xbox 360, make sure the switch at the end of the base is turned to the right tv type.
There also may be a problem with your A/V cable which can be solved by buying a new cable they are cheap and won't set u back much. Let me know if this helps. :-)
Mar 17, 2008 | Video Game Consoles & Games
Psp power switch is broken
The power switch has been dislodged from its mounting.
The switch will need replacing and you can find one easily and cheap on an internet auction site.
Dec 08, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation 2 Slimline Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
