Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
  • 1 more comment
  • nobuysamsung Jul 25, 2008
    hi i have the same problem the freezer not workingg and the fridge is but i get a lot of build up of ice in the fridge as well. the area at th e bottom of the freezer is sometimes cold. the display very tempremental sometimes freezer side displays 14 degrees c. HELP!!!!!!!!!!!!
  • ngrac Oct 04, 2008
    where could we get hold of circuit diagram for samsung fridge freezer rs20ccms
  • Anonymous Mar 13, 2014
    I have a samsung side by side refrig. The off off will not go away. I've tried everything.
    Problem Solver:
  • 9 Answers
Defrost by turning off for 48 hours and the unit will work ok (for a while)
Its a design fault common to many Samsung Side By Sides
Posted on Sep 06, 2008
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Freezer doesn't work. Fridge works OK
freezer is separate from the fridge and runs separately.there could be a problem with the evap motor or temp sensor
Sep 16, 2009 | Samsung RS2534 Side by Side Refrigerator
Samsung rs20ccms fridge and freezer stopped working
I have come across this problem too and understand it is a fault with the back plate which Samsung have now modified.
Jan 23, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Freezer and fridge don't cool at all. everything else works fine
There is a fault with samsung fridges that when it goes on defrost it will not start the compressor or the fans again. If you turn on the power the fridge should run for a couple of hours and then stop if so you will need to get a tech out to order a samsung yellow sensor and a fridge defrost isolation sensor. If the fridge does not work at all if you would like i will talk you a couple of little checks before calling someone out.
Hope this helps
Jan 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Water leak
probably the defrost drain blocked. remove back panel from inside freezer and melt ice off with hairdryer and follow up with hot water till water flows away freely.
you may find all the pipework iced up and if so you have a problem with defrost system.
an alternative way is to switch off for 24 hours and leave doors open
Aug 23, 2008 | Freezers
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
May 22, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
I have a Samsung side by side refrigerator - model RS20CCMS. The problem is both fridge and freezer not cooling properly - current temperation freezer 0 and fridge 15 and even with power cool wont go...
Read reviews on this product by doing a Google search. You may find that this is a recurring problem with this model then decide what you want to do.
May 06, 2008 | Refrigerators
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
1,009 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
