Question about Canon FaxPhone L75 Plain Paper Laser
"check printer" alarm
My fax is giving me a "check printer" alarm in the readout. It has paper. I have pushed every button I know to push. My fax is inoperable currently due to this problem. What is it and how do I fix it?
  • generallee Mar 20, 2008
    Thanks for such a quick response! I tried those suggestions but still could not get it to work. I am on with 800-okcannon right now.
    Thanks again!
    Genius:
  • 1,027 Answers
First, remove then replace the ink cartridge.
If it is hooked up to an uninteruptable power supply, disconnect it and plug directly into wall outlet, turn off for 5 secs. turn back on.
These are the most common causes for the error.
If these do not clear the error, contact canon customer care.
1-800-OK-CANON
Posted on Mar 20, 2008
Printer alarms us when a print job has been snet but wont print unless we manualy push the paper size on the printer
You have a mismatch paper size. Document is not same as paper you have in copier. Try printing 8 1/2 by 11 document if doesn't print check printer preferences and adjust settings. Check copier paper trays make sure don't have special settings on them
Nov 28, 2013 | Ricoh Office Equipment & Supplies
I defined the paper size A4 but Canon gives an error and ask me to use the current size. If I push yes it prints again
go to printers and faxes right click an d select printing preferences on 4350d and select paper as A4 . Press apply & ok. Now try printing on A4
Apr 10, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Canon Pixma iP 6600D printing problem.. went to print a scanned document .... paper began to feed in askew from autopaper feeder . Printing process stopped. the process was repeated a couple more times...
To fix the paper feed problem, Clean / rub each roller with a damp cloth with a dab of detergent.
Check for paper residue , especially near the paper empty flag,
Then reset the printer:
First power off the printer. Next, while holding STOP/RESET button, power on the printer.
While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
Wait about 20-30 second until the LED shows "0?. Then push STOP/RESET button four times.
Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Canon Pixma iP6000D InkJet Photo Printer
How to unjam a fax paper
Turn the printer around so that the back is facing you, and open the back panel. There should be two plastic tabs to push and release it. Open the panel and it gives you access to the rear rollers that push the paper through. You will be able to see any paper that is stuck there. Remove it, then push the "ok" or "enter" button on the front and the printer should continue normally.
Nov 12, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Fax machine has been moved from one facility to another and name and phone number on top of fax paper needs to be changed. Can you please give directions? Thank you
To modify the user settings: 1. push function button
2. push data registration button (blue)
3. and use the blue arrow keys to scroll through to what you need to change.
4. Once you find what you are looking for, push the set button. Make your changes, push set again
5.and finaly the red stop button to get out.
Oct 13, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Fax alarm is flashing and says check printer, fax in memory.I unplugged and rebooted.Any help is apreciated.
Please give me the error it shows on the screen when it says check printer!Check printer is a serious error!Thanks
Mar 26, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I need instructions on setting the alarm for the Pulsar Chronograph 100M. I'm able to set everything else. Your response is greatly appreciated. THANKS!!
I answered this for different Fossil watch post, but I believe it will be the same for your watch.
I'll re-post the answer below.
To set the alarm on these models of Pulsar watches, do the following:
Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
There are 3 positions on the crown: IN (#0), FIRST CLICK (#1) & SECOND CLICK (#2).
The small dials located at the bottom of the watch face (6 O'clock) are the alarm minute and hour dials.
First, pull the crown out to the second 'click' (position #2) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #2!)
Second, set the correct time. (plus one or two minutes... time to complete this.)
Third, with the crown still out to position #2, push button "B" (bottom) until the alarm minute and hour hands are set to the present time (same as the large dials).
Fourth, push the crown all the way in- to position #0.
The current time on the large dial should read the same as the small alarm 'time'. {This is the CURRENT TIME, not the alarm SOUND SET.}
To set the alarm SOUND time, pull the crown out to the first click (position #1).
Push button "B" until the dials of the alarm are at the time you want the alarm to sound... It can only be set within 12 hours! ... It does NOT know "am or pm".
When the desired time is set for the "alarm sound", push the crown all the way in (position #0).
The alarm dials will now indicate the time for your alarm to sound, NOT the current time. (this way, you know that the alarm is engaged.)
To reset the alarm- or disable it, pull the crown out to the first click (position #1) and hold button "B" down until the dials advance and stop at the current time... it will stop at the current time- then release button "B". --- Push the crown back in (position #0) and the alarm will now be disabled.
If the alarm dials are always moving and at the current time, you know that the alarm is disabled.
If the alarm dials are stationary and not moving with the time, you know that the alarm is engaged and set to the time shown.
I hope this helps.
Nov 05, 2009 | Pulsar Chronograph Watch
Machine refuses to print incoming fax. "Paper mismatch"
HP Printer 7210 or 7310 Gives Error receving faxes Load a new blank paper on paper tray.
Press * and # simultaneously, and then release both buttons.
Press 1 , 2 ,and then 3 . The Service menu appears.
Press the right arrow button (>) until the System Configuration menu appears then press OK.
Press > until Media Sense Calibration or Calibrate Spot Sensor appear and then press OK. The unit should pick the paper and eject it.
Press the Cancel button until date and hour appear on display
Mar 05, 2009 | HP Officejet 7210 All-In-One InkJet...
The printer keeps saying check paper - re load
check the paper, and reload it
check the paper sensor in paper tray, somtimes when you slide paper in to the tray it pushes under the sensor and holds it up, it is supposed to sit on top of the sensor and push it down
Jul 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Self testing
Open toner door. Press function 7/ monitor key slowly 4 times/ press */ press 6/ scroll down to shipment set/ press set/ 2/ (fax will reboot)
Mar 07, 2007 | Panasonic Panafax UF-790 Plain Paper Laser...
Canon FaxPhone L75 Plain Paper Laser Logo
116 people viewed this question
old marine
old marine
