Question about Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard
Help I have gone through those steps.Took everything out reset CMOS Batt and still have the same problem.Green light on board,but no fans or post beeps.Just dead. Any other suggestions
  • micromaster
    micromaster May 11, 2010
    Did i assist you before? Location please..
  • micromaster
    Brigadier General:
  • 3,614 Answers
These are symptoms of a failing power supply fan that needs to be replaced
Posted on Jun 07, 2008
  • 93 Answers
Is the power switch connected properly to the case button ?
http://www.rhyshaden.com/images/intspkr.jpg
an example above this would prevent it from powering if it has been knocked of the jumper
Posted on Mar 24, 2008
Intel d845gvad2,Motherboard getting on green light is coming but without ram board does not giving any beeps and processor fan and smps fan are running but does not giving any display,then which one may be...
you can try taking out CMOS battery from the board and try to reset BIOS jumper on the board. once you can also try removing and reconnecting the CPU Fan and CPU from the board.
All the best
Jun 08, 2011 | Intel Desktop Board D845GVAD2 Motherboard
How to do a step by step removing battery from cmos or bios to reset the password
u will hve to take out the cmos batt.from the down bord assembly and restart it with fan working .
miro cell is inserted into it's bay
Apr 23, 2011 | Sony VAIO VGN-FZ340E Notebook
No initial beep on POST, no video, PS fan, and processor fan both working? Took out RAM, USB PCI card, PCI modem card, reset CMOS, still nothing
If you have some compatible replacement ram, I would try that first, this board has onboard video card so as long as the ram, cpu and p/s is functioning you show get display. I got a feeling that the system board is probably dead.
Oct 26, 2010 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Yellow light on power button keeps blinking but doesn't boot.
No beeps are heard, no CPU fan is turning on, only blinking yellow light. This brand usually experiences this problem.
  1. First, check the power supply. Disconnect connectors from the board and make a jumper wire for the green wire to any black wire. If the PS fan does not spin then it's busted, else proceed below.
  2. Reconnect connectors except the one with 4 wires, 2 yellow and 2 black, then switch on. If CPU fan turns on then you have a bad processor.
  3. If the fan is still not turning on then check the USB port pins for short circuit.. disconnect it from the board and switch on.
  4. Do the same with other hardware connected to the board.
PS: The metallic casing of computers must be connected to the common ground of the power utility to protect it from stray currents that result to damage of sensitive components such as processors, memory and hard disks.
Sep 24, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
No post screen, cant access cmos settings. but windows starts as usual just a blank screen til then?
Its possible that your cmos settings were changed prior to this problem so as not to display cmos settings options at boot up. Have you tried resetting your cmos settings to fix the problem? You can do this by a jumper which is usually found on the mother board named "clr cmos" (clear cmos).
Let me know if this is of help or not.
Regards,
Graemevm
Apr 25, 2009 | Dell Dimension 2350 PC Desktop
EMACHINE T6534 COMP. WANT BOOT . TRYING TO CHANGE V-CARDS
This could be a few things though if you have already checked the memory and HD. The next thing I would tell you is that you should check the cpu. Also make sure that everything in the BIOS is set to the default settings when you start it.
Feb 04, 2009 | eMachines T6534 PC Desktop
Moterboard
That green light indicates that the board is getting power. You should remove any excess components from the board, especially expansion cards like modems. Check to ensure the front panel header connections are properly connected (like the power switch, etc).
Lastly, ensure that all of the screws are in properly, so that the board isn't shorting out. As a troubleshooting step, you may try resetting the BIOS with the CMOS jumper to see whether a rogue setting may have caused the board not to power up.
Apr 07, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Fans runs but no post,no beeps.
The best advice I can give you is to remove the motherboard battery (UNPLUG THE PSU BEFORE YOU WORK ON THE MOTHERBOARD) and let the system sit for about an hour. If the CMOS settings are corrupted, removing the battery will erase the corrupted data in the CMOS, which will automatically reset the CMOS to the default settings... Then, plug the battery back into the motherboard, and try to boot the system...
If that doesn't work, you should disconnect EVERYTHING attached to the PSU, and remove ALL of the add-in cards (modem, NIC, soundcard, TV tuner, whatever you have), and install ONLY the CPU, the heatsink/fan (don't forget to PLUG THE CPU FAN IN), ONE stick of RAM... you get the idea. DISCONNECT the HDD, the FDD, the optical drive, and ANYTHING ELSE from the PSU. When you're ready to test the system, you should have ONLY the CPU, the HSF, and one DIMM plugged into the motherboard. Attach the PSU connectors (both the main ATX connector AND the auxiliary 4-pin 12-volt connector) to the motherboard, and try to boot the system. If it works, SHUT DOWN and UNPLUG THE PSU; then install ONE component (the floppy drive, for example), reattach the PSU, and reboot the system. If the system POSTs, shut down, unplug, and add another device. If the system does NOT complete the POST process, the last piece of hardware you installed is probably the culprit.
Take your time with this; be methodical, and make GOOD notes about the steps you've followed, so we can help you work through this problem...
Best of luck to you; keep us "posted" on your progress...
Jan 27, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
