Question about Nintendo DS Lite Console
Fuse?? Thanks, it's good of you to help. I can't seem to locate this fuse. How deep is it, do I have to disassemble console? Thanks again!
Http://m3wiki.com/images/8/8e/Ntrcpu01frontfuses.jpg
http://m3wiki.com/images/b/bc/Ntrcpu01backfuses.jpg
Posted on Mar 30, 2008
1998 Jeep Laredo continuous clicking sound passenger side under dash it runs battery down ignition is off continuous clicking please help thank you
A number of people in the link report the same problem on the Jeep Forum and there are a number of fixes.
I also found this for you.
The problem seems to be a short in one of the rear dome lights, which seems to be affecting two fuse circuits. The temporary solution was to remove one fuse and replace another (blown), and remove the bulb from the bad dome light. I had to remove "fuze#5-15 amps-Interior Lighting", this stopped the clicking noise, I replaced blown fuze#8-15 amp-Overhead Console, keyless Entry ..." This fuse also seems to effect the alarm system (contrary to the documentation), and I think that was what was killing the engine. The problem existed before fuse#8 blew. Removing fuse#5 may have solved the problem, but the other fuse blew while I was testing the dome lights, and the jeep will not start without it.
Found lots of wires bare or broken in all the door wiring harnesses ( in rubber boot that goes to the door)I first checked both fuse 5 and 8 but both o.k. After fixing the broken wires found fuse 8 had blown. Replaced that and all is well again. Thanks for the advise got me looking in the right direction.
. Fuse box located in passenger side door jam...check #8 fuse if its not blown check others...if it is blown, check your radio, and interior lights for good ground
Clicking noise under passenger dash Jeep just shuts down
Jan 10, 2016 | Jeep Cars & Trucks
With some loads even very light ones the dryer stops and must be rest every 5 min or so
This is usually caused by a thermal fuse. There are several through out the dryer to ensure it doesn't overheat/cause a fire/damage clothes/ damage parts. Some are a one time fuse and requires repair to get it working again. Since it does come back on after a few minutes, it is probably the thermal breaker on the exhaust line out of the dryer and can usually be fixed by a thorough cleaning of the lint trap to the exhaust ouput, usually outdoors. If this doesn't work, a partial disassemble and deep cleaning of heating elements, squirrel cage, motor etc. I can seem intimidating but not too hard if you take pictures as you disassemble. Don't forget to disconnect the power/turn off the gas.
Aug 17, 2015 | Dryers
Need to find fuse box on a1993 saturn sc1
there is one fusebox under the hood in the engine compartment next to the battery and then theres one inside the car in the center of console, heres a diagram to help you locate the inside fuse box and also the fuse locations, the underhood fusebox will have a label with fuse locations on the cover. good day.johnjohn2_142.gifjohnjohn2_143.gif
Aug 17, 2011 | 1993 Saturn SL1
2002 saturn sc2 won't disengage out of drive
These cars have a safty measure that if a fuse in the fuse box that gets blown or removed it will lock out the tranny..check the fuse box located on the passenger side of the car next to console
Jun 03, 2010 | 2002 Saturn S-Series
MY PS3 WONT TURN BACK ON
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
My wii blew a fuse and i want to know what to look for
hello the fuse inside is made of glass if you open the wii up you should see the power supply the fuse might have a cover over it, if the fuse is black it's blown, if you put a nother 1 in and blows again the then you have a dead short somewhare make sure the power off. good luck.
shaun
Nov 13, 2009 | Nintendo Wii Console
Where is the thermal fuse locates in the sony KDF-e60A20?
Hi, the thermal fuse i located right next to the lamp is actually mounted on the lamp casing, deep inside the tv, you will need to disassemble the tv in order for you to get to it, if don't have any skill is better that you call the repairman and you are looking at $250.00 repair.
good luck
Jun 22, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
I have a ge microwave # JES1358WK. i think the 15 amp ceramic fuse has blown. Question is : would like to know how is the best way to open the case. are there any free online exploded views I could get an...
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
Here are some links you or someone you know can use (in order given) but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
In many models there is a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting, testing, and locating components.
Jan 12, 2009 | GE JE2160 Microwave Oven
CD PLAYER NOT WORKING IN 2005 EQUINOX
The radio fuse is located in the center console fuse block. The fuse block is locacted on the passenger side of the center console near the footwell. Its under the round cover. The cover is labeled on the inside for he location of the correct fuse.
Good Luck
Dec 06, 2008 | 2005 Chevrolet Equinox
Nintendo DS Lite Console Logo
37 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
