Iomega HDD External Desktop (32660) 80 GB Hard Drive Logo
Posted on Apr 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hard drive not recognized
My external hard drive is no longer recognized by my laptop. During the loading of the drivers, the drive was unplugged
Anonymous
Level 3:
  • Master 1,768 Answers
  • Posted on Apr 16, 2010
Anonymous
Master
Level 3:
Answers
1768
Questions
0
Helped
528667
Points
5915
1. your hard drive may have come to what is call "end of life" cycle
2. You didn't designate if you have a internal / or USB drive.
3. If this is an IDE ( internal Drive) then you will have to enter the PC cabinet to check.
4. IF this is a USB drive some time the electronic controller board is malfunctioning and will not transfer data from the processor on the data board to the USB cable.
5. If it is USB the usb cable it self is damaged due to strain at the strain relief.
6.The PC Mother board may have lost it's ability to recognize the hard drive.
Cant see my passport external drive on new windows 8 laptop
Try unplugging from usb and plugging it back in. Also, you may need a SAS driver for your computer to recognize the drive. Some drives have internal encryption and require a driver before the computer recognizes them. Check the Mfg website to see whether this drive requires one.
Laptop no longer recognizes my iomega external hard drive
How old is your OS maybe driver needs for that device for that device is corrupt try to localize and reinstall driver for external HDD
Computer not recognizing external HD
1st try a different computers make sure its not your Hard drive!
2nd if that works then go to the hard drive maker and download a software driver for it that should fix the problem
My SimpleTech 320GB external hard drive is no longer recognized
trying using it on another system and and see if it happens like that. if it does, you may want to get a driver for the hard drive. it is likely the driver is corrupted. try it on another port also.
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
SimpleTech hard drive not found by my computer
This may or may not help, but it worked for me! After about 4 hours of trying everything (Device Manager/Uninstall, Disk Management, etc..) nothing at all would work. The USB external hard drive would power up but when you plug it in, the New Found Hardware will pop up and search unsuccessfully for drivers for a PLUG AND PLAY external drive!?!?!
In any event, I simply plugged another USB drive into my laptop (and desktop) and viola! The new hard drive was recognized and installed immediately as 'plug and play' should do. I then unplugged the new drive and tried plugging in the one that was recognized and all of the sudden....IT WORKS AGAIN!!!!
This fix might not help anyone who doesn't have a second USB external drive, but you could try plugging another USB device in and get it to load and then unplug it and try your drive. It worked for me on my laptop and then I did the same thing to my desktop (which also wouldn't recognize it) and it worked on the desktop too! Problem solved for me, thank GOD!
Hopefully, this bypass can save you a few hours of google time and unwanted anguish. Like I said, you may not have another USB drive but try plugging in any other USB device until it loads and then unplug it and then plug in your USB drive that wasn't working. It worked perfectly for me.
Hope it helps!!!!
-BIRDMAN - BIRD ^v^
External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
Top Iomega Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Jerry Naidoo
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
