Question about Lexmark X2470 All-In-One InkJet Printer
LEXMARK X2470 ALL IN ONE
I BROKE THE LATCH THAT HOLDS DOWN THE ARM THAT SECURES THE INK CARTRIDGE, DO YOU KNOW WHERE I CAN GET THE REPLACEMENT PART? STEVE
Nu am drive
Posted on Mar 23, 2008
Don't have a manual, just need to know how to change ink and toner cartridges:)
Step 1
housing beneath. If done correctly, the print cartridge carrier should move into the loading position near the center of the unit.
Step 2
Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
Step 3
Pull the spent cartridge from the printer.
Step 4
Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
Step 5
Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
Step 6
Close the cartridge lid over the new cartridge until it clicks into place.
Step 7
Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
Step 8
Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Step 2 Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
  • Step 3 Pull the spent cartridge from the printer.
  • Step 4 Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
  • Step 5 Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
  • Step 6 Close the cartridge lid over the new cartridge until it clicks into place.
  • Step 7 Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
  • Step 8 Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Read more: How To Change the Ink Cartridge in a Lexmark X2470 | eHow.com http://www.ehow.com/how_6646584_change-ink-cartridge-lexmark-x2470.html#ixzz0wg8UCkTs
    Aug 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
    Questionb about installation disc
    Hi you can go to www.driverzone.com and download all your drivers for free. Now this printer does not support windows vista or mac os.
    Jan 08, 2010 | Lexmark X2470 All-In-One InkJet Printer
    How do i change the ink on my lexmark x2470
    Changing a print cartridge
    Removing a used print cartridge
    Make sure the printer is on.
    2 Lift the scanner unit.
    The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
    3 Press down on the lever to raise the cartridge lid.
    4 Remove the used print cartridge.
    Good luck
    Oct 04, 2009 | Lexmark X2470 All-In-One InkJet Printer
    Broken the bottom print cartridge holder - blueish gray
    The part has been broken in my printer for over a year now. I hold the cartridge in with a rubber band.
    Apr 08, 2009 | Lexmark X2470 All-In-One InkJet Printer
    Lexmark X2470 (aka piece of junk)
    To solve the printing problem..
    # Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
    # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
    # Continue doing this until it looks clean.
    # Then dab the cartridge on the towel to make sure the ink is flowing.
    # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
    1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
    2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
    # Reinstall the cartridges, making sure you snap them correctly into the printer.
    Mar 22, 2009 | Lexmark X2470 All-In-One InkJet Printer
    Piece to hold in ink broke
    went to lexmark.com and chatted with agent , he said i had to replace entire printer. they don't make spare parts! isn't that a bunch of ****!!!
    Nov 03, 2008 | Lexmark X2470 All-In-One InkJet Printer
    Replace cartridge how
    I BROKE THE BLUE CLIP THAT HOLDS THE CARTRIDGE IN PLACE CAN THIS BE FIXED OR DO I NEED TO BUY A NEW ONE? HELP PLEASE THX
    Oct 13, 2008 | Lexmark X2470 All-In-One InkJet Printer
    Printer won't close
    You'll need to replace the blue fastener. Try calling Lexmark tech support...
    Sep 04, 2007 | Lexmark X2470 All-In-One InkJet Printer
    Lexmark X2470 All-In-One InkJet Printer Logo
    143 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
