Question about Brother ML-100 Typewriter
How do I.........?
How do I save new setting (pitch change and add bold) so that when I turn off and then turn the typewriter back on they are maintained? Thank you
    New Friend:
  • 120 Answers
Change the batteries. (2 AA ) They hold your settings.Lawrence
Posted on Mar 22, 2008
How do I change the size/font of the letters? Bold and underline too?
To change font and pitch, you need to buy a different printwheel. machines came with a prestige elite 12 printwheel. Prestige elite has small letters and 12 puts 12 charactors per inch. Letter gothic is larger size letters. Google search for ibm wheelwriter printwheel, also called a daisy wheel.
Mar 03, 2016 | IBM Wheelwriter 30 Series II Typewriter
How can I get my typewriter back to its intial settings
There is no keystroke pattern to reset the EM series typewriter. There are two methods to reset this typewriter.
1.You can reset the daisywheel and remain on the same line of type, simply lift the top cover and then close it back down. The carrier will move to the left, reset the daisywheel and return to the last space typed.
NOTE: This will not affect the format settings (bold, underline, etc)
2.If you want to abandon the current typing position; turn off the typewriter, wait 10 seconds for the power supply to reset and then turn the typewriter back on. The typewriter will reset and the carrier will return to the beginning of the current line.
NOTE: Turning off the power will restore the format settings to standard default settings (bold, underline, etc).
Mar 15, 2013 | Brother EM-630 Typewriter
I can't get the print to go back to regular from bold. I have bold and extra bold but no regular.
There should only be one BOLD setting. Find the bold key on your keyboard, hold down the code button while you hit the bold key to turn it off or on. The other key you're speaking of is probably the impression control and won't make as big a difference.
Dec 06, 2010 | Brother GX-6750 Typewriter
How to change pitch on wheelwriter
To change pitch change the printwheel the printwheel sets the pitch.
They are labeled 15, 12, 10 or PS.
DickyO
Jan 27, 2010 | Lexmark Wheelwriter 3 Typewriter
How do you change the pitch or size of the type? The typewriter has 3 pitch settings, but we cannot figure out how to make the adjustment.
hold down "code" key and press 6 for 10 pitch. "code" key and press 7 for 12 pitch. "code" key and press 8 for 15 pitch. to change type size or style you have to replace the daisy wheel.
Nov 10, 2009 | Smith Corona Wordsmith 100 Typewriter
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
Changing the pitch
The pitch is set by the printwheel to change the pitch you must change the printwheel.
DickyO
Mar 17, 2009 | Lexmark Wheelwriter 10 Series II...
What do I do when I strike one letter and another is printed?
First make sure that the the pitch selector on the keyboard is set to the correct pitch for the printwheel , if there is a pitch selector on this typewriter. Also try taking out and reinstalling the printwheel then turn the typewriter off and back on so it can rehome the printwheel.
Mar 12, 2009 | Brother GX-6750 Typewriter
Need to change the font size
you would have to buy a new printwheel and change the pitch setting (which is a switch on the left side of the keyboard tha has 10, 12, 15, PS printed next to it) or just changing the pitch setting may get you the desired results. it won't hurt anything to change the settings, it just changes the spacing. The PS setting only works on a PS printwheel, any other kind will just print the wrong letters.
Nov 18, 2008 | Swintec 7040 Typewriter
Change Size of Type (Pitch to 12)
The pitch is set by the ptintwheel. To change it install a P/W with a 12 pitch i.e. prestiege elite 12.
DickyO
May 20, 2008 | Lexmark Wheelwriter 1000 Typewriter
Brother ML-100 Typewriter Logo
52 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
