Question about Apple iPod touch
Does not get internet
My ipod doesn't get any internet at all it. shows a screen asking for passwords or ip adress or something.
  • Anonymous Mar 22, 2008
    when I try to connec to internet it asks me for a password to the netowrk listed but how do I know what that password is as I have never joined a network?
You are probably not hooked up to any wifi survace. try clicking on the settings and then general. than click the wifi settings and chose your wifi program.
hope this helped!
Posted on Mar 21, 2008
Hi, I bought a TP-Link TL-WA701ND (Wireless Lite N Access Point) today, and am having troubles getting it to work. The Quick Installation Quide gives directions for Windows operating systems XP and Vista...
You must setup manually your acces point. First go to control panel, under network and internet you'll find a task, view network status and tasks click on it and in next page go to change adapter settings, find local area connection and right click on it and go to properties, in next window highlight internet protocol tcp/ip then click on properties in next window click on use the folowing ip adress and write in ip adress box an ip from 192.168.1.2 to 192.168.1.253 at your choice in subnet mask box just leave 255.255.255.0 (this apear when you click in these box). Now connect your acces point to the computer via network cable. Then open your internet browser and type in adress box http://192.168.1.254 and hit enter, a pop up will apear and ask for user name and password, write admin in both boxes user and password and hit enter, after that you will be able to manually configure your acces point and setup a name and password for your wireless network, change your user and password for acces your device. Good luck!
Mar 23, 2011 | ASI TPL WL TLWA701ND 150Mbps AP Wireless...
IPod touch Wifi problem. I got a new iPod touch 4g and my dad got new pocket wifi so I tried to connect my iPod to the internet and it would work for about five minutes but then it would disconnect...
hi this sounds like the pocket wifi firewall or push is stopping you from connecting, it will show connection when the password is put in correctly, but unless your either ip, or mac address is registered with the unit it will not let you connect to the net, you will have to see if there is a start ip and an end ip address in the wifi unit, as this might have restrictions to ip address numbers..for example..wifi ip start address might be 192.168.0.1 and wifi end address might be 192.168.0.4 where as your ipod might have an ip address of 192.168.0.7 ( just an example ) so even though the password is ok, it will let you connect for that few seconds, as it has verified the password and is correct, but the ip handling has not allowed you access and the firewall then steps in and blocks you.... hope this helps
Jan 01, 2011 | Apple Computers & Internet
Hi i had a wireless internet connection on my advent laptop till about 2 weeks ago and it doesn,t work anymore i have a internet conection as i,m using a different one and work perfect but this one...
Hi Friend, In this case as you have told me that you have other laptop which is working fine wirelesly. I would like you to check the IP address of the system in which you are facing the issues.
To check the IP address: 1) If system has XP Click on "Start" and then "Run". Type "cmd" in Run and hit enter A black screen will pop up, in that type "ipconfig", where the cursor will be blinking Check the IP adress under " Ethernet adapter local area connection" & " Wireless adapter"
2) If it is Vista/Win 7 Click on Start again and in Search field type cmd and hit enter Same black screen will pop up and repeat the same above steps in the black window and check the IP adress
Dec 07, 2010 | Computers & Internet
Pease help...i have a belkin wireless modem/router.model F5D8636 My provider is bigpond we have 2 new laptops which keeps asking for a security key no. I dont have 1 so neither laptop can connect to...
Dana on the PC that can connect to internet open the start menu and see if there is netwirk button to klick on. If so click it and see if it shows your Belkin Router icon if it does right click the icon and you should see a option to go to the router web page witch should look something like this.
See first pic below.
Find the security section on left side and go there. Should look something like second pic below. You will see the security key no in the password slot.
You can also get to the routers web page by typing its ip adress in the internet browser if you know your PC's ip adress (example 178.162.5.9) the routers ip will be the same but use a 1 where the 9 is. Hope I helped you good luck.4a682e3.jpgcae57f2.jpg
Sep 17, 2010 | Belkin Computers & Internet
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
Unable to configure router. I am using Netgear router, WGR614
first enter to your network connections in control panel, double click local area network, properties, internet protocol(TCP/IP), and tick Obtain an IP adress....Obtain DNS server..... and after that ok...ok..ok.
Now open an internet explorer window and type in the adress bar 192.168.1.1 and press enter . if you are asked for username or password try writing admin on both. good luck!
Oct 27, 2009 | NetGear WGR614 Wireless Router
Locking the connection
you will need the ip adress of the router and the user name and password enter ip adress in enternet browser it might ask for user name and password Then you would find a seting to protect it by a WEP password.
Jan 02, 2009 | Linksys WRT160N Wireless Router
8gb ipod touch will not connect to internet when i have a full wi
You shouldn't need to change the Address or DNS.
On your wireless router, make sure of your Firewall settings (if there is any form of blocking) and it's security settings (eg, network name, password and security type etc). Once you are sure of it's settings, on the iPod go to Settings, then Wifi. In there turn off then on wifi. Allow it to scan then if it comes up with your network, select it then type in the password when requested and tap Join. If it doesn't show you need to enter it manually. To do this tap on Other then type in the Network name. It should now request a password (if one is set) and you are then connected indicated by the wifi logo in the status bar.
For more info refer to your ipod touch manual pages 90-91.
All the best.
Sean
PiDigital
Dec 27, 2008 | Apple iPod touch
RG54SE II
In your wireless router,U want to configure the ip adress of internet,may R u static ip R dynamic ip address,
1. Statis ip customer means, configure the static ip address in your wireless router,
2. Dynamic ip customer means, configure the ip address of the ADSl modem ip.
May 20, 2008 | MSI Wireless-G RG54G3 Router
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
