Question about RCA Audio Players & Recorders
RCA AMP 5 DISC CHANGER MODEL RS2952
HI
My 5 disc changer bites the dust I have no output I took it apart and there is two blown fuses which says it all.The no on the fuse is 5s5a would that be a slow blow 5 amp fuse. What do you think might have taken it out I jumpeed the fuse tempoary and notice the transformer gets hot and the large diodes after the fuse start to get hot.I get audio noise out of the speaker.Would there be a short in the output causing the diodes and the xformer to get hot.
Thanks
SOURCE:
SOURCE: 5 DVD disc changer doesn't open
are you using discs with labels that you out on your self? I had a similar problem before and my label peeled off in the player causing it to get stuck., you might just have to take it apart, and get the label out.
Posted on Nov 06, 2007
  • 4234 Answers
SOURCE: Sony CD Changer does not recognize cd
The C601 will not spin up the disc unless one is detected. If the optics are bad and do not realize that the disc is there...
Try cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the optics are bad. The optics in this unit are KSS-240 (I think). This part costs about $30-$40 depending upon where you get it. You can try to replace it or have a shop replace it for you. Add in the local labor rate for the total repair cost. This is a relatively simple repair. I have done 100s. It usually takes about 45 minutes plus the testing time.
Dan
Posted on Apr 15, 2008
SOURCE: i have a Bose acoustic
I called Bose service. Jason said to unplug for 1minute then plug back in. If the changer does not reboot and operate properly....you call Bose service. They will exchange your cd changer for a new one.
$75 plus tax and return your cd's to you. They will give instructions for the exchange when you call.
Posted on Oct 31, 2008
  • 3 Answers
SOURCE: AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Posted on Nov 13, 2008
SOURCE: rca rs 2620 power but no audio
I need to see if the manual has any method of button pushing to get the sound back on. Otherwise, I am not an electronic type of guy that has soldering tools, can tell a resistor from a plug, etc. if that is what is needed to get the thing going with sound.
Posted on Dec 15, 2008
How can I get my RCA 5 disc CD changer stereo to work right?
I have an RCA 5 Disc Changer, purchased at Target. The first one had a prolific issue of skipping on discs. It would play part of song on the first disc then suddenly change to the next disc. However, it did not ALWAYS do this, just sometimes, seemingly at random. Then one day, it would suddenly work just fine on all 5 discs. Eventually it simply would not play an entire song at all, so I took it back (within the time of the warranty). They had 1 of the same left on the back shelves so was able to get that one. This one started doing the exact same thing within the month. Now, it will not READ discs. It will simply read, 'Read"..and then when it comes up showing the disc number it has all zeros. I tried skipping to the next disc and then the next, and suddenly it read. That was fine for two days, then it would not even do that. I tried using compressed air inside all of the open disc drawer, and on all the discs but to no avail. Just now I tried tilting the entire unit Back at about a 30 degree angle and while in that position hit the 'disc change' button on the remote and suddenly it read. How long will this work? Have no idea. Very irritating - and it's hard to find this kind of player anymore, apart from a Component System which is a whole new playing field. Amazingly , I had bought my first changer, a 6 CD changer, cheap one at wal mart long ago and it lasted me about 10 years and never had a problem. It was a no-name brand too, I would expect better from RCA but alas, tis not the case.
Jun 05, 2014 | RCA Audio Players & Recorders
Won't play any disc on any of the 5 slots boom box also has casette player that records
Laser is either dirty, so a lense cleaning disc required. Or the cd transport is kaput. Uneconomical to repair if this is the case
Apr 11, 2014 | RCA RP8085 5-Disc CD Changer
My RCA RTD 206 5 disc changer wont play DVD's. It stays on Disc 3 or just says close. I called the # in the manual foe help, but its no longer in service.
If it plays the same disc without issues, you have a mechanical(or the electronics powering the motors and such) problem. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | Audio Players & Recorders
Rca 5 disc changer
What model RCA 5-disc changer?
Aug 11, 2013 | Audio Players & Recorders
Rca 5 disc changer
What model RCA changer?
Jul 19, 2013 | Audio Players & Recorders
RCA 5 disc Changer RS2600 stop reading the cd and and shows "no disc"
The reading eye is most likely dirty and doesn't see the disc clearly. If you can clean it with alcohol on a long QTip, you might get it work again for a while. Dirt & dust are the worst on the opticals. If you can clean it yourself great. Many can't be done without taking the case cover off.
Nov 24, 2012 | Audio Players & Recorders
Can i install a clarion cdc635 6 disc changer in a stock car radio
You sure can. Pull the radio out and then install a Line Output Converter to it. They look like this - http://www.google.com/search?sourceid=chrome&ie=UTF-8&q=line+output+converter#q=buy+line+output+converter&hl=en&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=tgKHTfzhNsG20QGfu-nSCA&ved=0CDYQrQQ&biw=1600&bih=799&bav=on.2,or.r_gc.r_pw.&fp=f3631e0cf306c035
From $10 dollars on up. Simply hook the speaker wires up to the converter and then run the RCA cables from that box to your CD changer. That's it. this is a simple project.
Mar 21, 2011 | Clarion DCZ625 6-Disc CD Changer
I have got a rca 5 disc changer rp 8055c it want play my cd
RCA 5 DISK CD PLAYER AND RADIO CANT HERE MUSIC LIGHTS COME ON CD PLAYS BUT NO SOUND.
HELP
Aug 16, 2009 | RCA RP8078 5-Disc CD Changer
Will one of these disc changers hook up to the new decks?
According to the manual at sony's web site, the sony cdx gt520 deck does indeed use RCA style hook up cables.
May 15, 2008 | Sony CDX-646 10-Disc CD Changer
211 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
