Question about Mitsubishi WS-55807 TV
Horizontal bowed lines
I have a Mitsubishi ws-55807 that has horizontal lines displayed in each CRT color. Red is the most visible. In the middle of the screen the line is about flat but above that they arc upward and below that they arc downward. If I turn down the brightness enough the aren't very visible, but when set to decent viewing levels they are definitely visible. I have some pics if you need to see them, but I don't know how to post them here. Any help or direction would be greatly appreciated. Thanks.
  • 3 more comments
  • gumbyguitar Mar 21, 2008
    I'm sorry, I don't know. I bought the TV in this condition.
    Here are some pics of what I am talking about. See the bowed red lines? Thanks.
    That's kind of what I was thinking Troy, and I can remove the lines by turning down the G2 levels enough, but then the picture lacks brightness. If I brighten it with the "Brightness" control the lines will reappear. the CRT's were replaced a little over a year ago so I don't think they are tired.
    Could there be something else in the video gain stage that would cause this? I have done a reset of the system settings per the repair manual, but I can't find any instructions on setting G2 levels. Do you have any advice on setting those or any other relevant settings?
    Thanks Troy. From messing with it the other night, I remember that all 3 CRT's produce the lines (are those what they call retrace lines?). So, when you said move on to the main board, what should I be looking for there? An adjustment or a bad component? Thanks again.
  • gumbyguitar Mar 22, 2008
    Troy is the man. I got the three G2 adjustements set and it looks great. Glad I didn't go the convergence IC route.
    Guru:
  • 1,894 Answers
This is a convergence problem i think
Posted on Mar 23, 2008
  • 4,889 Answers
You can click on the second button from left(above the post comment window) and browse for the picture.. The pictures would certainly be of some help..
Posted on Mar 20, 2008
  • eagle338
    eagle338 Mar 21, 2008
    Looks like some of the convergence ICs are signing off! Now.. before we proceed further i just want to make sure that you are familiar with electronics and good at soldering and desoldering.. If you dont then you will have to seek the assistance of a tech.. Let me know so that we can proceed further
  • eagle338
    eagle338 Mar 22, 2008
    You have sent me a request right? Please follow up there..
    http://www.fixya.com/support/t458651-ele...
    Genius:
  • 1,153 Answers
Can u email me the pictures?
  • 3 more comments
  • Lashawn Robinson Mar 21, 2008
    What this looks like to me is your G2 Screen voltage is up too high. Inside your set you have Screen and Focus controls on a block, see if you can turn down starting with blue, because it looks more like blue from the picture.
    or Maybe Red, it's hard to tell. (Screen)
    Yes, first I would say if you turn down each crt screen control and bring up one at a time do you see the retrace lines on each color seperate? If so then you would need to move to main board, if the lines are in 1 or 2 and not all then the CRT board would be suspect. Try this first, never mind the brightness now check the crt's screen control, keep in mind that if you turn any of them up to the max it will show lines, but try to get a normal picture and see if the lines are there? Let me know what happens
    Yes they are retrace lines, but what you need to check is make sure you are not turning up too high, once you start seeing video then that's enough. White picture, you can go to the service menu, "MENU 8257" use the audio button to select "VIDEO CHROMA" adjustments, Use the video button to select ITEM "68 - AG1", Use the adjust button to change the setting to 0 if not already, Then press the Enter Botton to STORE the Change. Try this first before going to main board.
  • Lashawn Robinson Mar 22, 2008
    glad to have helped
    Master:
  • 377 Answers
Since when you experience the problem? what is the first initial problem before you got that one now?
Thanks
pincer
Green light is on but no picture visible, black screen
lack of raster : test the power supply b) horizontal output c) output transistor d) HV rectifier e) Flyback.
God bless you
Sep 25, 2012 | Mitsubishi WS-55807 TV
Distortion, blinking, dark screen - now nothing
at the horizontal deflection yoke! maybe you have defective flyback! or horizontal yoke!
Sep 20, 2007 | Mitsubishi WS-55807 TV
The screen has bowed lines and different colors no sound
If the model as indicate here (WS-55807) YOU may have two problems: Convergence and a audio problem.
In customer menu select convergence and with the Mitsubishi remote try to adjust the grid of lines so no red etc--if bowed it will not adjust.
This would mean the two stk-392-570 convergence chips this model uses need to be replaced(I have free start to finish instructions for that).
The no sound may and is likely a second issue: speakers in the menu may be switched off etc.
If both happened at the same instant this model has a hard reset(not from front of set but with a 4 digit code and done with the Mitsubishi remote) This sets everything except convergence adjustments back to factory original.
It is called the OPTION menu.
So, did both issues happen at exact same time or what?
Parts for the convergence repair are under 30 dollars total and I can tell you where.
Questions?
Mar 28, 2012 | Mitsubishi WS-55807 TV
Horizontal hold does not seem to work. horizontal lines in pic
hi,
Is there is white horizontal thine line on all over the screen then the screen voltage of you TV is high. Can be caused by bad base socket in the picture tube neck, faulty focus/screen block. Check the two things. You can see the base socket at the picture tube neck replace all the three base sockets for the three CRTs. if problem remains then you have to replace the focus/screen block. focus/screen block is one through which you can adjust the screen voltage and focus voltage. If the potentiometer in side it have some problem then this problem can occur. Have added the image for two items for your reference.
ok
Jun 09, 2011 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 Horizontal line in screen, no sound
it sounds like you may have a faulty frame chip. but could be capacitor. who knows for shure, exept an engineer?!?!?
Jul 19, 2009 | Mitsubishi WS-55807 TV
I have a Mitsubishi WS-55807 and the colors started to separate - you can reset it by turning if off and on again and it goes away but in time returns, starts getting blury then the colors split up - just...
In your On Screen Display menu (OSD), you should have a place that says "convergence". As a sub heading to this it will say "Auto-Convergence". This is where you want to be! Hit OK under AUTO, and watch the magic happen! If your set happens NOT to have AUTO, you'll have to do it manually. You're going to make the lines all match up doing one color at a time until all three colors are done! It's not hard at all. It may take a little patience at first, but just think of all the money your saving by not having a TV tech come out to your house and you'll be fine!
May 31, 2009 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807
Good Day, Bocinga;
I hope you solved this concern by this time but if you have not;
Your TV is experiencing a convergence problem.
If you are not a tech type, call an authorized service center and have them give you an estimate.
Good Luck, big IRISH.
Jun 15, 2008 | Mitsubishi WS-55807 TV
Convergence problems WS-55807
On this model if the fuses that protect the convergence circuit would open up, then the set would not come on. The convergence ICs probably have a cracked solder joint on the foil side of the circuit board.Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. Hope this helps.
May 12, 2007 | Mitsubishi WS-55807 TV
Mitsu 55'' screen
The convergence ICs probably have a cracked solder joint on the foil side of the circuit board. Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. To fix this yourself, you will need to be able to identify the two convergence ICs (STK392-570), have a basic knowledge of electronics and be able to use a soldering iron.
Feb 17, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
