How do you go about "Setting up the All-in-One".It says follow the set-up sheet which I do not have.
    Guru:
  • 1,463 Answers
Which printer/model have you ?
did any cds come with this ?
if so have you inserted the cd and let it run and follow on screen instructions.
riz.
Posted on Mar 20, 2008
SOURCE:
Printer prints portrait landscape setting
Are you confirming the settings in both the PC/User settings and the defaults on the Ricoh device? The printer will normally only follow the commands given by the user/PC. If somehow the properties or page settings are set for 2 images to a page, it will produce such results.
Apr 17, 2014 | Ricoh Office Equipment & Supplies
C390
[C390] Auto-toner sensor-C abnormality (Cyan)
<Color toner low density>
When you check the printing status to find out that the color printing ratio isless than 5%, color toner low density might be the cause.
Turn the code 08-2692 "Prevention of color toner low density / ON/OFF setting" to ON, and then set number of sheets to be judged at the code 08-2693 "Prevention of color toner low density / Judged number of sheets setting".
If the color printing ratio is 5% or more, check the following.
(1) Is the developer unit installed properly?
(2) Check if the connector CN340 on the LGC board isdisconnected from the auto toner sensor or the harnesses are open circuited. Correct if necessary.
(3) Check if there is any foreign matter such as toner in the drawer connector of the equipment and fuser unit or the connector of the auto toner sensor. Remove if there is and reconnect it.
(4) Service or replace the auto-toner sensor.
Apr 04, 2014 | Toshiba E Studio 2330C
To stop auto calibration in toshiba color mfd
Better not to turn off the calibration, otherwise it will cause other errors.
If your colour printing is less than 5% ration, perform following. Turn the code 08-2692 "Prevention of color toner low density / ON/OFF setting" to ON, and then set number of sheets to be judged at the code 08-2693 "Prevention of color toner low density / Judged
08-2693 u can put higher value such as 20 or above to delay the colour calibration.
Mar 25, 2014 | Toshiba E-studio 2330c 2830c Color...
HOW TO SET TIME AND DAYS SWITCHES
Copy following link for instructions setting analog timers:
http://waterheatertimer.org/How-to-set-timers.html
CU750 appears to be Mr Steam with 30 minute digital timer, or 30 minute spring-wound mechanical timer.
Copy links following links to download Instruction manuals for these timers:
CU 99216DIG timer manual:
http://waterheatertimer.org/pdf/Diehl-652-Operating-micro-II.pdf
CU 99216B timer manual:
http://waterheatertimer.org/pdf/039_FF-series-sell-sheet-with-wiring.pdf
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 22, 2012 | Hardware & Accessories
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
Canon mx850, paper jams when reloading for two sided copies. once the 1st side is printed the paper is released, recaptured and starts to feed back into the prt. 1/3 into the feed it jams, paper is...
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 11, 2009 | Canon PIXMA MX850 multifunction InkJet...
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
Printer alignment
From Brother's website, I found the following regarding alignment:
Setting the Alignment:
  1. Press the Ink or Ink Management key on the control panel.
  2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
  3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
  4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
  5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
  6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  7. Press Stop/Exit.
The webpage for this is:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000059/faq000259_007.html?reg=us&c=us&lang=en&prod=mfc420cn_us
I hope this resolves your problem.
May 20, 2008 | Brother MFC 420CN All-In-One InkJet...
Samsung DVD-P171 Player
Follow the instructions on the following page to change the zone of your player:
http://www.answerbag.com/q_view/775274
I followed the instructions without updating the firmware and it worked for me. Hope this helps.
Jan 19, 2008 | Samsung DVD-V90K Multisystem DVD/VCR
Card stock won't feed
HI,
SOLUTION:
  1. Perform a semi-full reset on the all-in-one by following the steps below
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the all-in-one.
  3. Wait 30 seconds, and plug the power cord back into the wall outlet.
  4. Press and hold the # and 6 buttons on the numeric keypad.
  5. While still holding the buttons, plug the power cord back in to the all-in-one. Continue to hold the buttons for two seconds, and then release them.
  6. Allow the all-in-one to re-initialize. This may take a minute or two.
  7. If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information.
  8. Insert the card back into the appropriate slot.
  9. If it does not begin to print a proof sheet automatically, press the Proof Sheet button and follow the normal process for your model to print a proof sheet.
  10. Once the proof sheet begins to print, press Cancel to stop the proof sheet from printing.
  11. Use the On button to turn the power off and then back on again.
    The problem should be corrected. If the problem still exists, service your product.
Thanks
Dec 16, 2007 | HP Photosmart 2610 All-In-One InkJet...
Open Questions:
Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}
Oct 16, 2019 | AVG Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
