Question about IBM Wheelwriter 30 Typewriter
Wheelwriter 3500 only printing top half of letters
Our church's school has a IBM 3500 wheelwriter which started only printing the top half of the characters. I pulled the ribbon and it looks like it is being lifted to the correct position as the imprints are in the middle of the ribbon but is only the top half. I have pulled the type wheel and it looks ok and locks in place correctly. I manuall move the hammer and it looks like it it hitting correctly but not sure.
Help and thanks,
Jeff
  • 3 more comments
  • BMoorman Dec 16, 2008
    My wheelwriter 15 is doing the same thing. I have put both the letter wheel and the ribbon in another machine and they work fine. I would try the solution already suggested but what is a platen?
  • Anonymous Feb 19, 2009
    WHAT IS PLATEN AND SOLONOID?
  • Bookssu Apr 14, 2009
    MY IBM WHEELWTITER 30 SERIES 2 TYPEWRITER IS ONLY TYPING THE TOP HALF OF THE LETTERS. I HAVE CHANGE THE WHEEL, THE RIBBON, THE ERASER RIBBON AND CLEANED THE STRIKER. ANY SUGGESTIONS?
  • makesomebull May 20, 2009
    I also have the same exact problem, the ribbon is correctly in place and the wheel is working well, but the only depression that is made on the paper is the top half of the letter.
  • Anonymous Mar 26, 2014
    Half of the letter show up only.
  • IBM Master
  • 3,594 Answers
Sounds like the platen is not fully seated in the side frames, align the black latches with the frames and press firmly on both sides of the platen. the latches do occasionally crack in witch case you may need a platen replacement.
DickyO
Posted on Mar 20, 2008
  • cnward Jul 06, 2011
    The Platen is the big black roller that the paper wraps around so the hammer can strike the character against the paper solidly. The solenoid is the cylinder that drives the pin to push the arm that swings the hammer.
    DickyO's solution worked for my Wheelwriter 15. I also cleaned stickers out from underneath it and cleaned ink off of the pressure rollers located under the platen.
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
Wheelwriter 30 series II. was typing OK but now get only less than half of letter to print. replaced ribbon same thing. tried adjusted ribbon (now sure was in right area) and still only printing less...
If it is printing only the tops of the letters the platen has worked loose. Press down firmly on both ends it should snap into place. If the print is generally bad the plastic print solenoid cap is probably broken. We sell them for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
May 21, 2011 | IBM Wheelwriter 30 Typewriter
I am only getting half of the letters, and it is stuck on del,typing how can I get it off delayed typing?
I'M assuming this is a wheelwriter 30 or similar. On the R. side of the keyboard is a key that says print mode press that and the dl prt will go off on the display. If you are only printing the tops of the letters the platen is probably not fully seated in the side frames press down firmly on both ends it should snap into place.
DickyO
Mar 16, 2010 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter 2
You need the plastic on the print solenoid.
We sell them for 20.00 including inst. & handeling.
216-241-0027
DickyO
Apr 08, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwriter 1000
Try snapping the plate down, by lightly pushing down on each end the have a habit of working loose.
Jul 23, 2008 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 5
Most likely the plastic cap on the print solenoid is broken they are available but are a bit tricky to install.
DickyO
Mar 27, 2008 | IBM Wheelwriter 30 Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter 30 Typewriter Logo
524 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
