Kyocera Mita FS9500DN print shifting
This printer has an internal hard drive and when printing large documents it seems to get confused. When I print one copy 99% of the time it works fine but when I print 10 at a time several of the documents will have the header and all of the text on the page shifted up on the paper. This occurs at various pages throughout the document and never the same page as it reprints the next document. For instance, it will print fine to say, page 65, then all the text will shift up ½” and then at page 150 will shift back to where it should be on the page. All very random.
I have tried reloading the document on the hard drive and nothing changes.
Any ideas on a solution would be appreciated.
Thanks
knarf77
  • knarf77 Mar 24, 2008
    Now I know why put those replacement rollers in the maintenance kit! Last time I installed the kit I was busy so I didn’t install the rollers, shame on me.
    Your diagnosis was right on the money, hasn’t had the first problem since replacing the rollers. I also found the tray guides on the top tray to be loose, seems the little gear is broken.
    Thanks for the help!
    Knarf77
  • Kemal Muderiz May 11, 2010
    try to format hdd from printer panel, also try to format with KM-NET Printer Disk Manager.Did you have this problem when printing without hdd ?
    Problem Solver:
  • 10 Answers
The FS9500 does shift margins unfortunately. I curently maintain 12 of them in the market. You need to ensure that the paper is 100% fitted to size in the trays. Also make sure that ALL the feed rollers are cleaned on a regular basis. If you pull out the trays you will see the feed assembly on the LHS of the printer. One screw holds it in. Undo the screw and pull out the assembly. Now you can clean the rollers much better. Make sure the bushes are well lubricated on the duplex unit as well. There are alot of axles in this printer and they all affect the printing margins when sluggish. This is 100% hardware problem. Not HDD. Let me know if you succeed. Udo
Posted on Mar 21, 2008
  • Udo Gehring
    Udo Gehring Mar 24, 2008
    Cool, if you need more help on the 9500 give me a shout. I know these printers backwards.
Kyocera KM2550 printer prints test page but cannot print word documents and pdfs
Try loading paper in the bypass on the left hand side of the machine.It may be that you are trying to print a document that is a different size to the paper that you have loaded in the copier.
Jan 13, 2014 | Kyocera Mita KM-2550 All-In-One Laser...
Black lines print on black and white printing
Sounds as if the drum needs to be replaced if it does this on copies and prints.
If it just happens on copy when using the document feeder then try cleaning the narrow piece of glass that is located just to the left of the large piece of glass.
Jan 09, 2013 | Kyocera Mita KM-2550 All-In-One Laser...
My printer prints 1/3 part of the document. Even when I disconnect and print a self test print using the green button it still does the same. What could be the problem? I do I solve it? I am worried.
The problem is with interface cable. Remove the cable and connect it again. Change the ports while connecting the cable and try to print the document. If this does not work, please visit kyocera mita site and contact the dealer for rectification.
Webmaster
www.incomeinnet.com
(An online encycopedia on earning money through internet legally)
Jun 14, 2011 | Kyocera Mita FS 1010 Laser Printer
When printing multiple pages last few pages come out garbled
You may need to increase the amount of ram in your printer. Or turn it off then on, then try printing the large document. Do this before every print job, if it fixes your error, then you need more ram.
Mar 01, 2011 | Kyocera Mita FS 1010 Laser Printer
How do I make my kyocera mita 4035 printer print without the need of pressing go
change paper size from printer properties maybe the paper size is LTR so you have to change it to A4
May 21, 2010 | Kyocera Mita KM-4035 Printer
Hi I have a kyocera C5015Nand it keeps telling me to load MP 4 try can you help please
to get the print press down arrow key it will show use alternative paper ? in display then press two times enter key it will print.............
its is the problem with the document page setting which one you giving print .......... its shows because its asking the paper according the document page setting ..........
Oct 17, 2009 | Kyocera Mita FS 3800 Laser Printer
Can't print entire pdf documents only first page.
There may be a few possible things for your to try. Below is the list of things you can try.
1) Reinstall the PDF software that you use to open your pdf documents. (reader or acrobat) *restart machine after reinstall.
2) Remove the printer from your list of printers and faxes then add it back again
3) Restart the spooler service
click start -> run
type services.msc then ok
on new window, look for print spooler, right click and select restart service.
May 29, 2009 | Kyocera Mita FS-C5016N Printer
Kyocera fs-1030d wont print frames on MSWORD2000
wrong... the kyocera only prints what you send to it... you need to go into your print settings and make the adjustments so it can print frames borders/ shadings... this has been my experience with explorer and photoshop... not very much fun but necessary...
Mar 06, 2009 | Kyocera Mita FS-1030D Laser Printer
Printer not printing - showing 'processing' but nothing happening
Reinstall the driver again, if it doesnot work, you have to update the firm ware of the machine, you can find this on kyocera website.
Nov 25, 2008 | Kyocera Mita KYOCERA/MITA - FS-2000D Mono...
Problems with Kyocera Mita FS-1920
Make sure that your paper sizes match in the control panel of the printer in Windows. It will not only cause the duplex not to work but could cause jamming problems as well. When printing in duplex mode, make sure it is turned on.
Jul 23, 2008 | Kyocera Mita FS-1920 Laser Printer
162 people viewed this question
jasbo
jasbo
