Question about Kodak EasyShare C613 Digital Camera
Help my camera has a lens problem,it is very wiggly, i bent it back into shape though. then whe i take pictures the pictures come out all blury and has yellow lines throgh it.
    Scholar:
  • 110 Answers
Unfortunately, it would cost more to repair than to replace.
Posted on Mar 20, 2008
Why are my pictures coming out blury. first the lens didnt want to open but now its opening but the pictures are all blury
Hi there its a problem of your lens. The lens guide pin is damaged or dislocate. Thats why the lens can not able to focus properly. Replace the guide pin. Thanks.
Mar 24, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
NIkon D60 - blury lens
for the close up photo u have to use micro or close lens set
Apr 25, 2009 | Nikon D70s Digital Camera
My AF-S Nikkor 55-200 lens will not take a picture in autofocus mode( D-40 camera). The motor will adjust the lens but the picture will not take. It will take a picture in manual mode The autofocus works...
Hi, I had this problem and found that the level inside the camera for the exposure shutter was bent inwards. This was preventing the lens from adjusting the exposure and also from autofocusing. To fix I just bent it back outwards
Sep 13, 2008 | Cameras
CAMERA LENS STUCK OUT
chech and make sure that your lens isnt bent to the side, because i had the same problem and as soon as i bent my lens back it turned on and worked like new
Aug 26, 2008 | Samsung S630 Digital Camera
My daughter dropped the digital camera and the lens will not close so the camera will not work.
try pushing it back in and after you do that turn it on and see if the pictures aare blury ....
Jul 11, 2008 | Cameras
Blur image
I am having a problem with blury pictures. Every one I take is blury and it also seems the flash wont go off. Now the pictures are blury even in the daytime. Anyone that can help me please do!!!!
Mar 26, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
BLURRY PICTURES
I am facing the same problem on one HP E317. I openned the camera just now and it seems there is a mechanical problem in the Macro mecanism, I am trying to find out what plastic is broken os bent.
Mar 04, 2008 | HP Photosmart E317 Digital Camera
FD 200 MAVICa won't focus
Do yopu remember if the front (lens) area received a hit, even though with low force?
I am asking because in most MVC-FD cameras I opened to fix them about the same focus problem, I did find that an internal bracket that holds the lens assembly, it was bent due to an external force or hit in the front.
The bent bracket really was not the problem. The reason of the focus issue was that when the bracket was bent, the flat ribbon cable of the lens was pressed against a mounting screw, causing that the flat ribbon cable was damaged (punctured) affecting 2-3 traces of it, and preventing the lens to operate properly.
Repairing such problem requires to either replace the damaged flat ribbon cable, or the whole lens assembly.
You can get your hands in a broken camera with good lens assembly, and swap the parts.
Best regards,
Feb 25, 2008 | Sony Mavica MVC-FD200 Digital Camera
Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Olympus FE-140 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
