I have just loaded DVD X burner programme but cannot open it. Error run time Tristana exeption occured Can you help Many thanks Sue
  • 55 Answers
JUST FOR OPEN I CAN SAY ON THE FRONT PANEL OF THE
DVD UNIT THERE IS A HOLE  WHERE THERE IS A SWITCH FOR
OPEN AND PUT UP CD OR DVD IF YOU PRESS THE SWITCH
(WHEN PC IS FUNCTIONING) WITH A LITTLE  THING HOW IS A PIN O NEEDLE - DELFO
Posted on Mar 20, 2008
SOURCE:
IT IS A NEC 6650A MODEL.IT IS STILL WRITES CD'S, PLAYS DVD BUT CAN NOT BURN DVD WITH ANY PROGRAMME OR DVD LABOR.THE MESSAGE THAT COMES UP IS:WRITE FAILED-CAN'T FIND WRITE STRATEGY AT SECTOR...
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
in left panel extend the events there you will see errors in red right panel you will no what exactly what the error was and at what time it occured you might be able to work your way through the problem until you know what type of error it is you cant find a fix for the problem
also you might try
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 08, 2011 | NEC ND-6650A DVD RW Dual Layer Burner
MY DVD-RE IS NOT READING ANY CD OR DVD..WHEN I M INSERTING ANY DISK IT KEEPS ON READING IT
Try using a Iris eye cleaning disk. Mosxt times when constant reading occurs or it says no disk it is the iris inside that has become occluded with dirt. Checkl that there are no finger marks on the disk and it is clean too
Once you have run the cleaning disk use a non scratched clean disk to check its load and read ability before trying in the disks that you had trouble with.
If they still give trouble then the problem will be with those disks and not the laser in the unit.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Samsung SH-S202J 20x DVD?±RW DL IDE Drive ...
I have LG DVD Writer installed and CD with Nero Express,Power DVD,when I installed CD message came up,not compatible with WINDOWS7.The CD loaded but will not let me open programmes,is there any software I...
did u try to use any other CD on ur computer.. there may be a possibility if the CD ur trying to use is not compatible with ur computer.. check this first.. and let me know if problem persists.. regards, guru
May 06, 2010 | LG GMA-4020B Super-Multi...
Rimage 360i image read problems
Have you copyright protected the file as you have burnt it, have you burnt it as a dual layer, or DVD 9 DVD (some programmes will not read these)? Also have you finalised the disc? It should not be a codec as all DVDs are vobs and there is a back compatibility with all, other wise they'd never load in normal DVD players.
Apr 14, 2008 | Rimage 360i DVD-R/CD-R (53050131) Burner
Won't record playlist error occurs
Can you elaborate more on exactly what is your procedure, are you able to burn data files? Will be happy to help you
Aug 29, 2007 | Adaptec (uv-cdrw-ide-f) CD-RW Burner
Need player for dvd-rom
you don't need a programme to run a dvd rom, you use windows media player, or if you mean burning software, try some of these free programmes http://en.softonic.com/search/win-dvd-player
Jun 11, 2007 | Compaq (294415-B21) DVD-RAM Burner
BUS DEVICE RESET FUNCTION
the bus settings may be the settings that have been changed by roxio, if you havent uninstalled the previous burning programme. Try uninstalling any burning programme you have, restart the pc and install the programme you require. If it continues you may need to uninstall the drive, by way of :- my computer>properties>hardware tab>device manager and look down list to dvd/cdrom drives and click '+' sign to your dvd line and right click and uninstall. Restart pc and it will automaticaly install again, ready for use.
May 11, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
DVD+RW Not recognized as a writable drive
There could be a few things going wrong here, firstly when you send a file using Windows poor inbuilt writing programme, i think you need to use a re writable disc, although i could be wrong, but thats worth a try. Also go to My computer, right click on your dvd drive and go to properties, then along the top row of tabs, the end one should say 'Recording', click on the tab and make sue that 'Enable CD recording on this drive' is ticked, and just below make sure that the dvd you use is showing in the drop down window. Finally if you still have trouble, my advice would be to use a dedicated programme for writing to cd and dvd for example Nero burning Rom or Nero 7 being the later version. In this nero you use your drive as a 'floppy type' drive, where you right click on file and send to and it writes straight to the disk and also enables you to change the file or delete, unlike windows programme.
Feb 27, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Open Questions:
Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...Avast ANTIVIRUS 1[=888=499=5520]O'# Norton CUsToMeR ConTACt...
Oct 15, 2019 | Norton Computers & Internet
Computers & Internet Logo
22 people viewed this question
Ekse
Alun Cox
