2wire 1700 failing; can you coach?
2wire 1700hg failing. Believe it to be the power 5v 2.1a power transformer. Cany you suggest a repair, low cost power supply replacment sources or low cost replacement sources for the whole 1701 unit?
  • 807 Answers
It does'nt have to be 2.1 amp as long as that it delivers at least 2.1 amp. It could be 3, 4, 5, 6 or even 7 amp as long as it's not less than 2.1 amp and the voltage is 5v. That gives you more options. The only other thing is the plug that goes in to the 2Wire box. Usually the hole (center pin) in the plug is the positive and the outer sleeve is the negative. Some but not many are the opposite way round.
Look here
http://www.surplustraders.net/a/0298.shtml
Scroll down and look down left hand side.
Posted on Mar 20, 2008
SOURCE:
I have Jump Starter JNC 660 1700 Peak AM. I want to take with me to Europe. My question is how I can charge it in the Europe
I wouldn't take it to Europe, what's the point it would cost you more to get it there than buy one there. If you do take it, you will need a 240V / 120V transformer of converter
Feb 23, 2015 | Solar JNC660 Jump-N-Carry 12 Volt Jump...
Model # P529265 T.V. will not turn on. What is the problem?
Hello jana_john219,
Welcome, and thank you for using FixYa!
Your issue is with one of three things. All of which will have to be examined by a TV Repairman, if you want to spend the money fixing this set.
1. 5V high/low power transistors are dead (1 or both)
2. Flyback Transformer is dead
3. Cold soldier joints around the three parts I just listed.
Most repairs will cost close too or more than a replacement TV. Your choice.
Have a great day!
Sep 11, 2011 | RCA Televison & Video
Tv turns on but sometimes shuts off without pushing the on-off button
I recommend taking this TV to your local TV Repair Center and have them test for "Cold Soldier Joints" near the Flyback Transformer or 5V Power supplies. This is caused by these soldier joints warming up and breaking contact. Over time of them heating up and colling down, the joints flex and contract, which causes cracks in the joints.
This can be just the first step to the repair. They may have to replace the 5V low and high transistors.
Aug 30, 2011 | Sharp 32K-S400 32" TV
Power supply
i believe you will getting a difficult time on finding one. i suggest to buy the whole unit
Apr 19, 2010 | 2wire (1000-400108-001) Router
Xbox 360 wireless adapter wont connect to my 2wire
Have you tried removing all security protocols on the 2wire and trying to connect?
Good Luck!
Jesse
Jan 05, 2010 | 2wire HomePortal 1800HG Router...
Hp Pavilion getting no power after relocating pc.
the Power transformer has diferent outputs, +5V,-5V,3V,12V and so on.., but has a standby output a low power 5v to power button function.
Your PC have Power supply Defective,
so your must find a usual spare power supply on the market, compatibilty as 115V input and more of 350W power, to have stabilty.
Nov 29, 2009 | HP Pavilion a1519h (EX271AA) PC Desktop
Where can I get a new power cord for 2Wire wirless modem (ATT)
You can buy replacement AC adapters from AT&T here....
http://store.att.com/ & towards left bottom you would have Adapter option below Network equipments.
I hope this would help to resolve your query.
Oct 19, 2009 | 2wire Computers & Internet
Daewoo DVRS04 DVD Recorder
problem is on your power board,replace elco on +5v ,-5v 12v, 24v
Nov 28, 2007 | Daewoo DVRS04 DVD Recorder/VCR
JVC DRMH20 "Loading problem"
voltages on CN5303 should be 12V and 5V. I found 5V to be2,5....3V.Check input of regulator MM1665A(should be 6V). If 6V ok,remove connector CN5303 and check if 5V ok.If so,here is my way to fix this "loading" problem.(create a new regulated 5V circuit)
Replace C5206 with 1000uF/25V,C5306 with 100uF/25V,isolate anode of D5213 from transformer,
wire one and an half turn around transformer,connect one end to ground and the other to the anode of D5213,remove MM1665A and replace with 7805 on appropriated radiator.
Input on 7805 is around 11,8V reason why you need to install it on a radiator.
Triphasé
Nov 15, 2007 | JVC DRMH20 DVD Recorder
Open Questions:
AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR... AvAst customer care pHoNe {@}{+1888/499/5520;-] nUmBeR...
Oct 15, 2019 | Computers & Internet
Angeles @!~~ {#^l_855^892-OO6O } APPLE Customer SeRvice NumBer @ sdfsdfd @ itunes TeCh Support Phone Number Apple is a great platform for unlimited entertainment, only having a membership plan; you can dive deep into the entertainment world. But is this always possible? Not at all, you have to face various issues with this every now and then, but you will be happy to know that Apple Prime Customer Support service is 24*7 active to assist you whenever you experience any sorts of issues with this. Yup! No hassle, no waiting, your every single issue related to Apple will be resolved instantly at a single call to customer support. chat with Apple customer service.USA DAIL Itunes customer Care number our ensured specialists are available constant to offer most sensible courses of action immediately even by methods for our toll free number for Canada and USA.is advancing strong responses for the customers by methods for customer organization as it appreciates the burden and frustration a customer needs to encounter. It is advancing game plans by methods for different sources so the customer can pick the right one according to his tendencies. Itunes technical support. Our submitted gathering of is just a phone way and accessible immediately relentless. Itunes customers can come to us to benefit answers for any of their issues including the ones referenced here under Itunes best without toll number, there are 4 outright ways to deal with associate with them.The accompanying most perfect way to deal with banter with their customer reinforce gathering, according .Ipad Support Avail Ipad Support To Quickly Resolve All Ipad Errors Independent Ipad Support Phone number for Ipad Help The line of tablet computer designed, developed and marketed by Apple Inc.
Oct 15, 2019 | Apple Computers & Internet
Mark @!~~ {#^l_855^892-OO6O } APPLE Customer SeRvice NumBer @ sdfsdfd @ itunes Support Phone Number Apple is a great platform for unlimited entertainment, only having a membership plan; you can dive deep into the entertainment world. But is this always possible? Not at all, you have to face various issues with this every now and then, but you will be happy to know that Apple Prime Customer Support service is 24*7 active to assist you whenever you experience any sorts of issues with this. Yup! No hassle, no waiting, your every single issue related to Apple will be resolved instantly at a single call to customer support. chat with Apple customer service.USA DAIL Itunes customer Care number our ensured specialists are available constant to offer most sensible courses of action immediately even by methods for our toll free number for Canada and USA.is advancing strong responses for the customers by methods for customer organization as it appreciates the burden and frustration a customer needs to encounter. It is advancing game plans by methods for different sources so the customer can pick the right one according to his tendencies. Itunes technical support. Our submitted gathering of is just a phone way and accessible immediately relentless. Itunes customers can come to us to benefit answers for any of their issues including the ones referenced here under Itunes best without toll number, there are 4 outright ways to deal with associate with them.The accompanying most perfect way to deal with banter with their customer reinforce gathering, according .Ipad Support Avail Ipad Support To Quickly Resolve All Ipad Errors Independent Ipad Support Phone number for Ipad Help The line of tablet computer designed, developed and marketed by Apple Inc.
Computers & Internet Logo
Ekse
Alun Cox
