Question about Samsung HLR5667W 56" Rear Projection HDTV
Samsung dlp tv
My tv has developed a 2 inch wide vertical shadow on the left side of the screen. could this be a cause of a child throwing a ball against the side of the tv? the image is still visible but has a shadow over it.
  • Anonymous Mar 29, 2008
    I have the exact same problem, but my TV did not get bumped by a kid. Can the mirror screws be adjusted?
  • 59 Answers
Yes, it could. There is a light pipe in the light path that could now be broken from the bumping or it could just be out of line from the bumping. Another problem could be the mirrors in the projection path could just need adjusted by the 3 screws that are beside the mirrors. This may also happen when bumped.
Posted on Mar 22, 2008
There has been a gray shadom on left side of screen, maybe 3 inches wide, for the entire length of the screen. I can see through the shadow, but it is noticeable.... any thoughts?
This tv have a colors wheel design in it.Flashes or discolors on this shadow?Tv making any humming sound or motor noises.Yes,mean the tv colors wheel is dying and spinning out of it motor axis.The color wheel,is the problems.Colors wheel sit way back of the tv,must take out alot of mechanical parts to get to it to replaced.U have no mechanical skills,don't tries this.Hire a tv tech to replace the colors wheel.
Jan 17, 2011 | Samsung DLP HL-P5663W 56" TV
3 problems 1. TV shuts off and on automatically. 2. 2 inch band on left side of screen 3. No picture at all
The band or shadow on the left side of the screen definitely sounds like a defective light tunnel.As for the intermittent pix and shut down this could be the lamp if you have not already changed it.
Oct 15, 2009 | Samsung DLP HL-P5663W 56" TV
My dlp tv has a shadow about 6'' wide and full ht of tv
Hello: The problem is that a small mirror on the light tunnel has fell off causing a shadow in the picture,. In the past the only way to repair this problem was to replace the entire Optics Engine. But Samsung decided it was replacing entirely to many light engines so they decided to allow and train technicians on how to do it. It involves removing the color wheel and behind it is the light tunnel where light from the lamp shines on to a maybe 1 1/4 inch small block with three mirrors on all sides, your problem is that one of these mirrors has come loose from its side, causing a shadow with the pic still in the background. So if you call a technician to come, if he has'nt had the training from samsung on how to do the procedure then he will want to replace the entire optics engine which is the expensive way of doing it.
So when calling as if they know how to replace light tunnel. There are some adjustments that also needs to be done once it's replaced. To verify what i am saying go to this site to find out more. http://www.avsforum.com/avs-vb/showthread.php?t=758625
Call if you need more info will be glad to help..
Delhielectronics@live.com
Phone: 702-418-1389
Sep 26, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a vertical stripe on the left side of the screen that comes and goes. It appeared after my wife and I watched a vhs video on our Samsung 42' lcd hd tv.
first of all hello!
look i need to know a little bit more of your problem so i can help you!
let's see first of all how often is the problem happening ? after a wile the lines go away or they are always there? please let me know because i think i now what is the problem i just want to make sure!
yeah have a good day!
Sep 22, 2009 | Samsung HL-S5087W DLP TV
Optoma RD-50 DLP has dark vertical shadow on right side of screen
turning off the main can be very harmful to rear projectors if you dont wait for the cooling off period, for instance when you turn off the tv from the remote, the fans inside are still on in order to dissipate the heat given out by the lamp. as a result some of the lens inside the engine may have burns-in caused by excess of heat.thus leading to shadows on the screen.
hope this helps
please rate me!
Mar 19, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Dark transperant vertical line, left side of screen
Your light tunnel is bad. This requires partial disassembly of the light engine. Suggest contacting a tech
Dec 30, 2008 | Samsung HL-R4264W 42" DLP HDTV
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Samsung HLR5667W 56" Rear Projection HDTV Logo
167 people viewed this question
Henry  Thomas
Henry Thomas
