Question about HP Compaq Presario V2000 Notebook
My laptop won't display
My laptop will only pull up certain icons and will not pull up the internet unless i access it through another way. As in, now i had to open my norton antivirus just to get the web browser. It also won't let me access my C drive or anything. Anyone know of a solution?
    Genius:
  • 1,913 Answers
Hi
i m not sure but perhaps u select the hide desktop items show if so right click the desktop and choose show desktop icon.
also other way to access c drive go start menu run the c: u get c drive
Posted on Mar 20, 2008
SOURCE:
How to Disable Internet Access?
Disabling Firewall Access for Windows Programs
  1. Go to the Control Panel. Click the "Windows" key or the "Start" icon, then click on "Control Panel". ...
  2. Open the Security Center.
  3. Open Windows Firewall settings. Open the "Exceptions" tab. ...
  4. Open the program and try to access the Internet.
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Oct 18, 2016 | Computers & Internet
How do I access Internet Explorer 10 from myitlab
I don't think you can unless your tablet is made by Windows.
If you're running windows 7, just press the icon that looks like a letter e....or says "Internet Explorer"
Hope this helps.
Mar 03, 2015 | Internet Computers & Internet
My laptop won`t charge unless it`s dead and in an outlet I have not used yet with my laptop
Go to control panel, click on Pen and Touch and follow the instructions. Click on the battery icon, you will see your power options, check on each one to set your power options, I suggest you set it to battery saving mode or any mode you prefer.
Nov 07, 2013 | ASUS Computers & Internet
My laptop won't connect to wifi
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you. If not you may need to turn on the wifi on those devices. Usually those setting can be found in menus like Network Settings. Once it recognizes the network you will need the password if it is required. Just enter that in and you are set. Where you enter the password is usually in the same menu in which you turned on your wifi enabled device. if still no connection Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. Click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
Feb 26, 2013 | Computers & Internet
No screen when pull up
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 28, 2012 | Acer Computers & Internet
My VGA cable won't let the image on the screen stay on unless I hold it a certain way
Either the ribbon cable is faulty or it is not making proper connection to the motherboard.
Try reseating the video cable to the motherboard before you try getting a replacement cable.
Apr 12, 2012 | Acer Computers & Internet
Why is my Gateway 4028GZ screen black
The display on this laptop is backlit. What that means, in a nutshell, is that the image on the display prevents the output from a constant light source (the back light) from showing through, thus giving a usable image on the screen. From your description, the backlight is no longer operating. This can be an issue with the LCD display panel, the backlight power module, our (less likely) a power trace on the motherboard. Repair would likely cost as much or more than replacing with a used laptop and just transferring your hard drive. If you choose to replace and swap hard drives make certain that the interface on the new laptop is the same as your Gateway's.
Jun 08, 2017 | Gateway 4028GZ Notebook
Desktop icon are missing & display is not
Try to uninstall and reinstall the display drivers. For the desktop icons, right click desktop->Arrange icons by->show desktop icons.
May 29, 2010 | Dell Dimension 2400 PC Desktop
Can't set up belkin wifi
You can only access http://192.168.2.1 if your pc has an active connection with your belkin. You don't need internet connection to access that. You are only accessing the belkin configuration page. Check ip address of your pc, IT SHOULD BE 192.168.2.X. if you are not getting this ip your pc is not connected to the Belkin network
Jan 14, 2008 | Computers & Internet
Wireless Internet Access
Hi, Normally there should be an Icon at the system tray (lower right) which is for the WiFi. Placing your mouse over the icons would tell you what the icon is for. Right clicking on the WiFi icon would show you whether it is enable or disabled. Double clicking on it would give you the WiFi access window where you can select which WiFi network you can connect to. Some of these wireless internet cafe would grant free access while others would need you to check-in with their admin or somebody and on certain cafes for a fee. Hope this be of some help to you and pls post again how things turn up. Kind regards.
Jul 19, 2007 | Toshiba P205-S6267 Notebook
HP Compaq Presario V2000 Notebook Logo
46 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
