Question about Xerox Phaser 6120/YN Laser Printer
Xerox phaser 6120 colur laser printer
The paper feeder does not allow the printer to pick up the paper and hence the jam sign illuminates everytime
    President:
  • 2,072 Answers
Not sure how long you have had that machine. But remove the paper and the tray. Dampen a slft cloth with some soapy cleaner, such as fantastic or Formula 409. Look into the paper feed area for the rollers and clean them well. Maybe 2 or 3 times. Then if you have some handy wipe them again with some alcohol.
Your feed rolls, depending on how many pages you have run, may be worn out and need replaced. But that should not occur with less then 40-50 thousand prints on it.
I suspect just some contaminant on the feed rolls.
Let me know please.
Posted on Mar 20, 2008
Says paper jam and there is no paper jam
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Feb 19, 2012 | Lexmark X2600 InkJet Printer
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Top feeder jam
Yes. When removing a jam, it is never wise to "aggressively" remove the paper, as it can break switches, gears, etc. maybe any switches or gears had damanged, need replacement of that parts.
Feb 25, 2010 | Samsung SCX4824FN Mono All-in-One Laser...
Says there is a paper jam everytime i try to print
Hello
Check within your paper feeder rollers there might be something stuck inside it like paper clips, coins or anything small and solid. If you can find way to open the printer without braking it, that would be nice.
Hope this helps.
Jan 12, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Jam in the document feeder
get rid of that hp piece o crust. demand your money back.
Mar 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
I think I found my answer. You don't have to un do any screws. Lift up the cover to the automatic feeder. You will see a spring on the side of the mechanism towards the front; remove the spring; that will allow you to lift up the little arm the spring was attached to and remove the roller or bar and the light blue/green plate just under it. Then you will be able to see the jammed paper, which which I was able to carefully pull out with a pair of tweezers. Some was under rubber rollers, but when I pulled the paper sideways it slipped out. Now it works!
Jan 23, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Xerox Phaser 6120/YN Laser Printer Logo
235 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
