Question about Hitachi 57F510 57" Rear Projection HDTV-Ready Television
DH Channels How do I get my tv to pick up all the HD channels I do a channel search and it picks up the local channels fine just not sure if I have not set something up right so it will pick up those HD channels. I have an antenna the goes at fifty feet in the air so I do not think that would be the issue.
Is there a setting for hdmi cable on this tv
Posted on Dec 18, 2008
You need to purchase a HD antenna, you can get one for 20 or 30 bucks. I had the same prob and i finally got the antenna
Posted on Oct 25, 2008
I cant get all my channels on my tv. I do my channel scan but all i get is 13 channels
Posted on Sep 05, 2008
Step by Step instructions on How to run set up for my RCA flat panel antenna to pick up local tv channels
connect your antena first then go to setup on the tv and selct channel search it will scan and find all the channels that you can pick up with your antenna
Aug 25, 2014 | RCA Digital Flat Panel Antenna
Need to scan channels
you can do the auto search channel. just press the tv menu and then find the channel search and select auto search. so that all available local channel will tuned.
Aug 30, 2012 | Insignia NS-LTDVD19-09 LCD TV
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Unable to pick up local ''free'' channels following digital change over. Using RCA DTA800 converter and Phillips 2750/27 antenna. Can pick up only one local channel, but signal loss is more often the...
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Oct 11, 2009 | Televison & Video
Auto Search for Local channels not responding
Hi elmergdavis,
Check and make sure your tv is set to CABLE and not to AIR or ANTENNA. This setting is usually just above the Auto Search utility on the meNU.
Let me know what you find and I can provide further assistance.
Lone99star
Jan 29, 2009 | Vizio GV42L 42 in. LCD Television
Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
Dec 06, 2008 | Dell W4200 42 in. HD-Ready Plasma...
Digital TV not picking up all channels
TV is searching for over the air channels. Select in the main menu to go from over the air to cable channels and you should be fine.
Nov 19, 2008 | Televison & Video
NO HDTV
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Nov 15, 2008 | Toshiba 57H94 57" Rear Projection HDTV
Television only locates 7 channels????!!!!!
Hi there!
If you cannot receive all channels it may be a fault with the antenna or the tuner may be faulty. If you have a VCR, you can tune that into the TV first and then tune the VCR to see if you then receive all channels. If so, use the VCR position on the TV to view and select or change channels on the VCR only. Good Luck,JUS004
Mar 07, 2008 | RCA F32649 32" TV
Hitachi 57F510 57" Rear Projection HDTV-Ready Television Logo
349 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
