Question about Frigidaire Ovens
Oven Problems I have a frigidaire wall oven that i need the contols for. It is a model fsc96cw-1. Do you know where I can get thes. Thank you.
SOURCE:
  • 3 Answers
SOURCE: frigidaire single wall oven
We had a similar problem. When the repair person arrived he turned of the electicity to the oven then turned it back on. The control panel is a computer and he rebooted it.
Posted on Jan 08, 2008
  • 750 Answers
SOURCE: Oven heating element
Hello rvready
Welcome,
You said, We have an OLD (1950-60) Frigidaire wall oven, model # RBG-94. Bottom heating element has gone out. Oven is still in good shape so we'd like to be able to find an element replacement, but have had no luck finding one.
unfortunately,
I am not able to find this part either.
Anywhere. This oven is to old for parts. But most important is that it is causing you high utility rates!
Today's appliances save you the arm and the leg that such an old oven is costing you.
You have no idea how it is sucking your money out of your pocket!
It is unfortunate, that no one told you about this years ago!
You payed for more than one oven with your utility bill if you had it since it was new. My advice is do not put good money into bad!
Shop for a new one and see your bills go down.
my wife was telling me to replace the air and furnace for 7 years and I said, it's not broken. But it was over 20 years old. She was right, cause the new one saved me $100. a month!
That means I threw away $7000. in 6 years with my old world attitude.
Yes I am old fashion and always fix it!
But after 25 years of marriage. i finally realized she is a good evaluator and I was a fool to not appreciate her gift for all these years! And out tons more money than I told you about!
Hope I saved you some bucks with my real life stories!
Don't tell your wife!!!
Huuum
Posted on Oct 17, 2008
aborcass
  • 2651 Answers
SOURCE: Replacing a 30 inch wall oven -
a number of solutions for your problem a little smaller better then a little larger, iv seen depending on surrounding cabinetry, either wood fill strips, lexan(plastic) strip added as a filler. depending on what the installation guide recommends for opening , that is all that would be required what you fill if with will be a purely asthetic choice
Posted on Nov 13, 2008
  • 130 Answers
SOURCE: Frigidaire Wall Oven
It is telling you that your oven has an issue. Check your owners manual for the fault code definitions. If you have a model number I may be able to find it for you.
Posted on Jan 26, 2009
localwonder
  • 6784 Answers
SOURCE: oven not heating
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Posted on Jun 23, 2009
Desperately searching for User Manual for Tappan Wall Oven Model 12-4990-00-04.
Hello Owner, thank you for your inquiry!
I understand that you need the use and care manual for your Tappan wall oven, 12-4990-00-04. If the model is older than ten years old manufacturers will not keep that information available. You might be able to perform a search for antique models online for any additional information. -Matt
Jan 11, 2016 | Frigidaire Ovens
How to use self-cleaning on 1996 frigidaire electric oven
Thank you for your post, Jewell!
From the information you have provided you would like a manual for your Frigidaire oven. I would be happy to research and see if that information is available. In order to research for any available manuals I would need your model number. You can locate the serial tag (which lists your model number) on the door frame of your oven or on the inside left hand wall. Once I have that information I would be able to better assist you. -Matt
Dec 04, 2015 | Frigidaire Ovens
What do the error codes for frigidaire elite electri clean oven
Hello friend, thank you for your post!
I see you have a Frigidaire wall oven and you are searching for error codes. Do you have a specific error code that your oven is giving you? Also, could I get your model number please? With that additional information I would be able to provide you more assistance. I look forward to hearing from you. -Matt
Aug 02, 2014 | Frigidaire 24" Built-in Single Electric...
What would be causing my frigidaire wall oven
sounds like you have problems with the main pcb,or clock.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 10, 2010 | Frigidaire FEB27S5A Electric Single Oven
I can't find an owners manual for my very old Frigidaire RE-94 wall oven. the oven powers on, but the heating element does not get hot-- so trying to assess if a new heating element would do the trick or...
I have the same oven. works perfectly since 1976. I have the owner's guide and the schematic which will direct you to the solution. you will need to pull the oven 1/3 out of the wall in order to access the electric controls and use a VOM to check voltages.
Let me know what you need.
Curt
Oct 14, 2009 | Frigidaire Ovens
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
[email protected]
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Element in top oven not heating up all the way.
Yes needs a new element.they burn out. easily.you know this because they sell them seperately.its there way to make money off of you.anytime they sell you something and the parts are readily available especially sold seperately you know its going to need to be replaced eventually..If you replace 1 replace them all to avoid furthur issues.
May 29, 2009 | Frigidaire 30 in. Electric Gallery Series...
FGB24L2ABB Frigidaire wall oven
local outlety to buy rack for oven
jeff
May 20, 2008 | Frigidaire 27 in. Electric Double...
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
42 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Ekse
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
