Question about Food Mixers
ANTONIO I HAVE A MIXER " A 200 " WHEN DON'T HAVE CHARGE WORK, BUT I PUT FLOOR STOP
    Master:
  • 788 Answers
The installation manual is here: http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/672E1D1B118EA85485256E27006B35BE/$File/F24855.pdf
If your model number is one of these: A200 ML-104567
A200T ML-104568
A200DT ML-104569
A200FT ML-104570 then the instruction manual is here: http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/95A2AE6F314AF7C3852568E1006A9A03/$File/F-19354%20Rev%20A%20(06-98).pdf
If you model number is one of these: A200 ML-104859 (without Timer)
ML-104858 (with Timer)
ML-104863 (Deluxe Finish with Timer)
ML-104861 (Floor Model with Timer) then the instruction manual is here: http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/C607FD46A3A5BC8E85256ECF0047B7B3/$File/F-34387%20(02-00).pdf
The manual for the accessories is here: http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/ECE4E2A48386C6AB85256F15005FB447/$File/F-20064(8-03).pdf
Is this what you needed? Your question wasn't specific.
Posted on Mar 20, 2008
    Master:
  • 377 Answers
You mean it was not working now?
I've got a brand new Kenwood mixer and I cannot make the head-release lever work!
A model would be helpful. Put it on the floor, lean your weight down on the head and try to move the lever at the same time.
Dec 29, 2016 | Kenwood Food Mixers
I just bought the ice cream maker attachment and the metal collar on the beater shaft is stopping me from attaching the ice cream maker driver. How do I remove the metal collar from the beater shaft?
You need a small steel hammer and a pin punch. Do not try to drive
out the Groove Pin any other way (i.e. don't force it out with a regular
size hammer and a screwdriver), you will only damage the Planetary plate
and/or the Agitator shaft. Lay your mixer down on the floor and support
the Beater shaft with a wooden block before driving the Groove Pin out.
Jul 30, 2011 | KitchenAid 5KSM150PS Mixer
How do i put back togeather Hobart 300-d mixer
http://www.hobartservice.com/Parts/
Go to this page and click on Hobart Smartparts System. Select Food Machines, Floor Mixers, D300 and you will eventually find parts breakdowns.
Feb 25, 2010 | Hobart D300 Stand Mixer
I have a very old kitchenaid that stopped working. It's at least 30 years old, still have the "Hobart" name on it. Any ideas where I can bring it to get fixed?
Hi, FIGSONWHEELS, Sorry, but you don’t have a KitchenAid mixer. You have a Hobart mixer, which is another brand altogether.
You might try the Hobart website and seek assistance directly through them. They tend to be very close lipped about releasing information on how to fix their mixers by yourself, as they have a whole business unit that services their industrial/commercial floor mixers. You can click on this link for the Hobart Service website: http://www.hobartservice.com/Locations/
I hope this will at least get you pointed in the right direction. Good luck, Howard – Burke, VA
If this solution was helpful, please rate it, thanks! - hslincoln
Dec 13, 2009 | Food Mixers
Mixer quit working
Quite likely you overloaded the capacity of the motor and it simply overheated. The brushes inside the motor may be burned out/corroded. I suggest putting a light load on it and seeing how it performs. Often, when this kind of thing occurs, a bit of light duty use will get the motor back into good working order. But be careful to not over-tax the unit again. There are several different KitchenAid mixers on the market, some nothing more than ornamental, all the way up to commercial-grade.
Sep 07, 2009 | KitchenAid K5SS Heavy Duty Commercial...
West Bend mixer 41036 stopped working, any parts available?
check the service section in your manual.
If you don´t have one, check here:
http://manualfox.com/link/westbend.htm
They can get you any West Bend manual. Just send them a request.
Dec 25, 2008 | West Bend 41036 Mixer
Hobart A-200 First Gear is Having Trouble
If the mixers are older the dive key shaft,spring or key are broken,if they are newer the key is sheared.Also check the nuts near the beater shaft and make sure there not too tight.
Nov 13, 2008 | Hobart A200 Stand Mixer
? Hobart A200 Mincer/Mixer wont work
What kind of bang was it ? an electrical or mechanical. The A-200 has a stator and rotor assy with a start capacitor and relay behind the back cover at the head of the unit. You can access the retaining nut for the rotor (motor) shaft by removing the small 2 inch cover and getting a wrench on the nut and spinning it by hand. The handle you mentioned with the three numbered selections are your speed settings and everything is driven through a planetary drive. Hobart A-200 have been around longer than I have (im 48) and are work horses and in my opinion, are the top of the line for mixers. Put it this way, I would take a 25 year old A-200 over a brand new Varimixer or other brand name. You can access parts manuals and break downs on Hobarts web site with model # and M/L # any other question e-mail me capt_rick1912@yahoo.com if you cant find what you are looking for I will e-mail you a wiring diagram (found behind the small gear selection cover on side) Good Luck......Rick
Apr 06, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
181 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
