Question about Cisco 7940 IP Phone
Inline power problem: cisco ip phone 7941G
I am using seven 7941G IP Phones on Catalyst 3750G switch. The problem is that three of my ip phones are not powering up after replugging the ethernet cable to the ip phone. I checked the switch interfaces on these ports and it shows line & protocol down. The same port starts working when i plug the ethernet cable into the PC. Please help me in this regard.
    Sniper:
  • 58 Answers
You need to ensure that each port that has a phone plugged into it is configured with power over ethernet configured switched on.
Posted on Mar 21, 2008
    New Friend:
  • 26 Answers
Could be issues with the PoE power source on your switch. Sometimes the PoE components stop working and do not generate voltage on all ports. You could try using a Cisco 48V AC Adapter and see if the phones still display the same issue.
Posted on Dec 05, 2012
I have a problem with my phone
Posted on Oct 11, 2008
SOURCE:
I need to modify the settings of my cisco ip phone 7941
Complete these steps:
  1. Unplug the power cable from the phone, and then plug in the cable again.
  2. Immediately press and hold # and while the Headset, Mute, and Speaker buttons begin to flash in sequence, release #. ...
  3. Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash.
Aug 04, 2015 | Cisco 7941G-GE IP Phone
I cant test my 7941g because i keep getting a small bullseye on the bottom left corner of the screen
Your phone is trying to connect to a TFTP server address to download a firmware and/or config file update. You need to figure out what IP address it is trying to connect to (You may have to use wireshark or another packet sniffer to determine this).
Once you know the IP it is trying to connect to, you'll need to set up a small network with a TFTP server running on that same address, and feed the phone a firmware update and/or config file. It will likely not fully boot unless it gets a firmware update.
Cisco Phone 48V Power Supply
Dec 05, 2012 | Cisco 7941G IP Phone
How power need Cisco 7941G-GE IP Phone
These phones can take their power from a Power over Ethernet switch, where all you need to do is plug the phone in to the switch and it gets its power from there.
You can also get power cubes for these phones, but they do not come with the phone as standard, as most people like the convenience of having the power coming from the switch, and not needing to use up a further power socket in the floor/wall.
Hope that this helps!
Nov 06, 2010 | Cisco 7941G-GE IP Phone
Dell latitude e6500 disconnects ethernet after 20-25 minutes. tried changing power save settings, sleep, and hibernate settings. nothing works
Control Panel>Add/Remove Programs>Dell Control Point System Manager
select change> next> click modify> Internal Network Card Power under Power Manager> “This feature will not be available”
Nov 28, 2009 | Cisco 7941G-GE IP Phone
CISCO 7941 IP PHONE disconnect you out after certain time
Unfortunately this is a very common problem with Cisco's IP Phones. It can be caused by either a faulty hookswitch or a damaged jack. Both of these problems can be remedied by contacting IdacomUSA.
Apr 06, 2009 | Cisco 7941G-GE IP Phone
CP 7941G issue
Try configuring CCM IP address either trough DHCP parameter, or Network configuration on the phone.
Oct 08, 2008 | Cisco 7941G-GE IP Phone
7941G-GE Locking Up
This can be caused by corrupted firmware, or possibly damaged circuitry. IdacomUSA is your best bet. Your phone will be completely refurbished, and sent back to you within two weeks and comes with a 2 Year Warranty on the phone.
May 12, 2008 | Cisco 7941G-GE IP Phone
Ethernet Disconnected message in POE 7941G IP Phones
the first problem will be to check or replace the cable that you use to connect the phone or check the jack that you use
Jul 12, 2007 | Cisco 7941G-GE IP Phone
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
527 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
