Question about Philips SpeechMike Pro 5274 Handheld Voice Recorder
At Wizard setup, the error: "Unknown BC" appears
No sound is picked up from the device at wizard. It worked perfectly fine. The following actions resulted in gettting the message "VORStop" in the recorder bar: Start->settings->Sounds and devices Properties->Voice->Voice recording-> default device: select Speechmike.
After getting the VORStop message, I reverted back to original voice recording device, but VORStop message remains
DDMaster
  • 10 Answers
SOURCE: won't playback or transcribe
2 things to check:
1. is the speechmike set as default playback device: go to Control Panel--> Sounds and Audio Devices; and in the opening window, go under the Audio tab; in the Sound Playback, the default device should be set to SpeecMike II if you want the sound to come out of the SpeechMike.
2. Playback volumes: still in the same tab, click the Volume button of the default device; it opens a set of volume controls; you need to ensure that for the WAVE, and Speaker (or Volume Control), the Mute box isn't ticked; you also want to set this volume to something not equal to zero (i.e. move the cursor up to at least 1/3 of the level).
I hope this helps.
Posted on Jun 11, 2009
My daughter purchased a Logitech C160. It seems to work fine but no picture with skype. The sound is perfect, exceptional actually, but no picture. when i go to OPTIONS-VIDEO SETTINGS it keeps giving me...
See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
Feb 14, 2011 | Logitech Webcam
Printer will not respond to laptop
Please follow the troubleshooting steps and check the operation:
  • Ensure that the supplied USB cable is firmly connected to both the printer and computer side. Please refer the below picture to view the port on the printer.
  • Ensure that the USB driver for the printer has been properly installed. Please follow the steps to ensure that:
  1. Turn ON the computer and then printer.
  2. The Add New Hardware Wizard window will appear on the Computer screen.
  3. Click the Next button
  4. Insert the installation CD in to the CD/DVD drive on the Computer.
  5. In the Add New Hardware Wizard window, click to select the CD-ROM drive.
  6. Click the Next button.
  7. In the Finish Setup dialog box, click the Finish button.
  • If the USB driver for the Printer has already been installed, uninstall and then reinstall the driver.
Follow this procedure to reinstall the device driver using the Device Manager utility.
IMPORTANT: This procedure must be performed while logged in as Administrator or to an account with Administrator rights.
  1. Click the Start button, and then click Control Panel.
  2. In the Control Panel window, under Pick a category , double-click the Performance and Maintenance icon.
  3. In the Performance and Maintenance window, under or pick a Control Panel icon, double-click the System icon.
  4. In the System Properties window, click the Hardware tab.
  5. On the Hardware tab, in the Device Manager box, click the Device Manager button.
  6. In the Device Manager window, double-click the category icon of the device to be removed.
  7. Under the Device Manager category, click to select the device to be removed.
  8. On the menu bar, click Action.
  9. On the Action menu, click Uninstall .
  10. In the Confirm Device Removal window, click the OK button.
  11. Restart the computer.
NOTE: For some devices the operating system will display a System Settings Change window. Click the Yes button to restart the computer. When the computer restarts, the operating system will find the device and install the driver. If the operating system is unable to automatically find the driver, have the installation wizard search the C:\WINDOWS\I386 folder.
  • Remove and reconnect the printer.
Jan 27, 2011 | HP PSC 1350 All-In-One Thermal Printer
I have a new MCP6P-M2 mother board. I have tried to install the lan drivers manually because there is no such option on the autorun disk. i still get the following error when using the Network Setup...
Install it from the Device Manager, but before you do that, if possible extract the driver and save it in a specific folder so that it'll make you easily locate when you browse from the "Found New Hardware" Wizard. Good luck.
May 21, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
The logitech pro 9000 microphone option is not available and the microphone icon is faded and i am unable to click it. the audio wizard lets me change the settings but they are not saved once i finish the...
Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone or Headset.
Click OK and it should work.
Then to use it on the Web, do this.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
On the VIM sign-in window, click on Edit.
Microphone
Speaker
Camera
conversation before running setup. Would you like to disconnect now? Click the Yes button.
Notes:
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Feb 28, 2010 | Logitech QuickCam Pro 9000 Web Cam
Hi there i have a medion akoya which ive had nearly for a year, the problem i have now is that it seems the sound isnt working however when i connect headphones it seems to work perfectly,how do i fix...
These are steps to setup the Audio, and restore the drivers for the Audio: Part (1) Click on 'Start' button. Go to, and click in the (right, pane) Control Panel. Scroll to find, "Ease of Access (or) Speech Recognition Options. " Click, on" Replace sound with visual cues." In the See also (Category), click, on Audio Devices, and Sound Themes. Click, Playback, next, click on the Active "Speakers". Click 'Configure' to "Audio channels" The (Speaker Setup) "wizard", appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. The (Advanced), not recommended! In, the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: Click OK to all changes, 'Save' and Apply!, before exiting. Restart Computer!
Jan 21, 2010 | Computers & Internet
My blackberry is just sayingblockerase6 Reset
The Block Erase 6 Reset error may result from corrupt data on your BlackBerry device.
To resolve this problem, you need to complete the steps:
Reload the BlackBerry Device Software by following these steps:
  1. Install the BlackBerry Device Software on your computer.
  2. Connect the BlackBerry device to the computer.
  3. Open BlackBerry Desktop Manager.
  4. Complete one of the following:
    1. If the Application Updates Available window appears, click Update Now. The Application Loader wizard appears.
    2. If the Application Updates Available window does not appear, double-click Application Loader. The Application Loader wizard appears.
  5. Click Next.
  6. If prompted, enter your BlackBerry device password and click Next.
    When the Application Loader wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation.
  7. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  8. Click Next.
  9. If the On the Device Backup screen appears, choose whether or not to automatically back up the BlackBerry device.
  10. Click Next.
  11. Click Finish to begin loading the BlackBerry Device Software.
  12. Click Close when the software is finished loading.
Inspite of this if you find the same error, you need to follow the steps:
  1. Remove the battery from the BlackBerry device.
  2. If a media card is inserted in the BlackBerry device, remove it.
  3. Connect the BlackBerry device to your computer using the USB cable.
  4. Open BlackBerry Desktop Manager and click Option > Connection Settings.
  5. In the Connection Settings window, click Detect. Make sure the BlackBerry device is detected.
  6. Close the Connection Settings window.
  7. In BlackBerry Desktop Manager, double-click Application Loader.
  8. In the Application Loader wizard, click Next to start the loading process. The Device Application Selection screen appears displaying the applications available to load onto your BlackBerry device.
  9. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  10. Click Next. The Completing the Application Loader Wizard appears listing the applications to be installed and removed from the BlackBerry device.
  11. Click Advanced.
  12. Select the Erase all application data check box, and then click Next.
  13. Select the check box beside Do not automatically backup the application data during the loading process. This check box is selected because the data on the BlackBerry device may be corrupt.
  14. Reinsert the battery into the BlackBerry device.
  15. On the Application Loader wizard, click Next to proceed with the loading process.
  16. When the process is complete, the Application Loader wizard will display the following message: The loading operation was successful.
  17. Reinsert the media card if one was removed earlier.
  18. Close the Application Loader wizard.
Nov 16, 2009 | RIM BlackBerry 7290
Setup
a driver must come along with your sound card..shutdown PC..open casing and insert sound card in appropriate slot..turn PC on...right click My Computer..properties...hardware then device manager..on device manager click action then scan for hardware changes..the new found hardware wizard should pop up upon detecting the newly installed sound card..insert installer CD and follow instructions on the wizard... when finished restart and enjoy..
Jun 19, 2009 | Intel RME968PAD Sound Card
Sound controller won't install
MORE INFORMATIONThis section lists the error codes and possible resolutions for the error codes.... loadTOCNode(1, 'moreinformation'); This section lists the error codes and possible resolutions for the error codes. The error codes are listed in numeric order.
Before you continue, make sure that you have the error code available. You can view the error code in the device Properties dialog box available in Device Manager. You can also resolve many of the errors within Device Manager.
To start troubleshooting, follow these steps:
  1. Make sure that Device Manager is open, and that the device that has the problem is selected. You can perform some recommended resolutions through Device Manager.
    1. Right-click My Computer, and then click Properties.
    2. Select the Hardware tab, and then click Device Manager.
    3. Double-click the device type that has the problem. For example, if you have problems with your modem, double-click Modems to see the devices in that category.
      A list of devices appears. If a device has problems, the device has a red exclamation point next to it. If a device is unknown (usually because of missing drivers), the device has a yellow question mark next to it.
    4. Right-click the device that has the problem, and then click Properties. This opens the device Properties dialog box. You can see the error code in the Device status area of this dialog box.
  2. Use the Troubleshooting Wizard, if it is available, to help you diagnose and resolve your problem.
    1. On the device Properties dialog box, click the General tab.
    2. Click Troubleshoot to start the Troubleshooting Wizard. The wizard asks you some simple questions and provides a solution to your problem based on the answers that you provide. If the Troubleshooting Wizard is not available, go to step 3.
    3. Follow the resolution steps provided by the wizard to resolve the problem.
    4. Check the Device status area of the device Properties dialog box to see whether the error is resolved. If the error is resolved, you are finished. Otherwise, go to step 3.
  3. If the Troubleshooting Wizard did not help you resolve your problem or was not available, locate your error code in this article.
    Note If you cannot locate your error code in this article, contact Support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus (http://support.microsoft.com/contactus)
  4. Follow the recommended resolutions for that error code.
    • Check the Device status area of the device Properties dialog box to see whether the error is resolved. If the error is resolved, you are finished.
    • If the problem still occurs, unfortunately, this article did not resolve your problem. For your next steps, you may want to ask someone for help. Or, you may want to contact Microsoft Support to help you resolve this problem. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus
Dec 06, 2008 | Computers & Internet
Low volume on webcam
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
Jun 10, 2008 | Logitech Webcam
Philips SpeechMike Pro 5274 Handheld Voice Recorder Logo
369 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
