Question about Vacuums
Bosch buc11700gb the motor that drives the brush doed not work, i havr checked the rest switch and the on off switch to no avail is there a 3rrd switch that operates when the handle is tilted back and where is it located?
    Scholar:
  • 74 Answers
Why did the brush roller stop spinning?
With the cleaner unplugged, turn the unit over and look inside the opening where the brush is located. Do you see the clogging of the brush with lots of hair? If so, you will need to disassemble it to remove the hair. In any case, you will probably need to take off the cover to see if there is an obstruction jamming the brush. Also, check to make sure that motor for the brush is getting power. If there is an electrical cable on the outside connecting the brush housing to the rest of the vacuum cleaner, check if it is disconnected. When you have the cleaner on, do the lights glow? Do you hear the motor running? Try the above and report back.
Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
Bosch 2607022999
Can't replace the brushes on t his DC motor. Have to get a replacement motor. They run about $70 at ereplacementparts.com at this writing. Direct Current Motor
Nov 19, 2013 | Bosch 2607022999 Direct-Current Motor
Dismantle bosch buc11700gb
What is this unit??
Nov 02, 2013 | Vacuums
Dyson dc24 roller brush stopped spinning
There are two switches to check. The push button switch on the handle and the other one that turns brush roll on when you recline the handle back.
Feb 02, 2018 | Dyson Ball DC24 Bagless Upright Vacuum
Bosch 2604320913 Carbon-Brush Set
No If the saw is running the brushes must be working. Maybe the front end grease has dried causing too great of load on the motor. if not the motor must be defective (lost a winding in the feild) don't know how much you paid but unless its worth is greater than $150 I sugest buying another
Sep 18, 2012 | Bosch 2604320913 Carbon-Brush Set
I have a bosch bagless jet 12 amps/1450 W which I got secondhand. the switch to operate the powerhead (the rug brush) no longer gives me any results. I don't have the right tools to unscrew the plates and...
quite likely it has no actual motor .many of these newer machines use an AIR MOTOR that when the suction is great enough it spins the brush quite well . dog hai and human hair wraps around the ends of the brush shaft and eventually get tight enough to stop the brush totally .
Dec 05, 2017 | Bosch Vacuums
Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I have a Hoover Savvy Bagless Upright. The beater bar does not turn. It does not appear to be the belt.
The Savvy has a brush roll motor, whcih could be bad. There also is a circuit board near the brush roll motor, a circuit board underneath the tool holder, and the switch asm. in the handle. Any of which could be the cause of the brush roll not turning. Just needs to be checked to find what is causing the problem.
Jun 11, 2008 | Vacuums
Bosch vacuum
check the belt, it might be stretched or broken
or carpet fibers and hairs may have clogged up the brushes to keep them from rotating
let me know if this isn't the problem
Mar 22, 2008 | Bosch Turbo Jet Bagged Upright Vacuum
Eureka the boss the brush wont go around
Hey there scrappy13, I would suggest you unplug the unit, turn it upside down and remove the bottom plate uncovering the brush assembly. Inside there should be a belt which drives the spinner brush. If that is in tact, then the brush itself may have been unseated when you pulled the rug out. It should be obvious to find the correct placement. Reseat, ensuring the belt is attached properly to the motor as well as the brush. If the belt has broken, a replacement is available at a registered repair facility. Good Luck!
Jan 29, 2008 | Vacuums
Vacuums Logo
182 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
