Question about Dell Dimension 4600 PC Desktop
My wireless keyboard and mouse stopped working on my computer
I got some sort of usb error and now i have to plug in a usb mouse and keybaord. I tried to rediscover the bluetooth devices but it doesn't see anything. Drivers seem to be functioning.
Upgrade the Bios and make all the critical updates of your Hardware from the Dell site. Check also that the bluetooth is enabled through bios. Try also to make all the updates to your OS.
Posted on Mar 20, 2008
6ya staff
SOURCE:
I have a Trendnet TK-209 KVM switch. My keyboard and mouse (MS wireless) that worked well for a year stopped working through the switch. they work well if connected directly to each computer.
I can confirm the same problem happened with me just now. I have TrendNet USB/KVM TK-207 and was flawlessly working with Logitech K260 Wireless Mouse and Keyboard Combo, but today on both computers all I can see is the error:
USB Device not recognized - The last USB device you connected to this computer malfunctioned and Windows does not recognize it.
I unplugged the usb wireless adapter and connected it directly to the PC - it worked like a charm again. I have tried to connect the wireless adapter to the mouse port hoping that the keyboard USB port is causing problems, but all I got was the same error. I have tried to conect a normal USB keyboard, but again the same error I get for both - the mouse and keyboard, so it is more than obvious now that the USB ports of my KVN Switch are malfunctioning. I will try to leave it for a while if it got hot somehow as it was connected for more than 6 months working perfectly fine, but if not, I am heading to the store for support/replacement.
May 02, 2011 | Trendware TK-207K 2-port USB KVM Switch
I bought a gateway zx series computer 3 weeks ago. the wireless keyboard and mouse that came with it has stopped working for no apparent reason. the computer says that it doesn't recognize the device. i...
hi Karnarc.
How do I troubleshoot my Gateway wireless keyboard and mouse? How do I troubleshoot my wireless keyboard and mouse?
If you are experiencing issues with your wireless keyboard and mouse not working properly, perform the following steps to troubleshoot the wireless keyboard and mouse.
  1. Make sure the USB connector from the receiver is properly plugged into a USB port on the computer. Some systems ship with the receiver already preinstalled in the unit itself. Please check your mouse to see if there is a receiver inside of the battery compartment door.
  2. Make sure wireless keyboard is not on a metallic surface.
  3. Ensure that the receiver is 8-inches from other electrical devices.
  4. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
  5. Check the batteries in the keyboard and mouse to make sure they are installed correctly.
  6. Test the batteries to ensure that they still have a charge.
  7. Verify the On/Off switch on the keyboard and mouse are switched to On.
  8. Some receivers, keyboards, and mice may have a connect button. If so, follow the steps below:
    1. Plug the USB receiver into a USB port on your computer.
    2. Press the connect button on top of the receiver and the button will blink.
    3. Press the connect button on the bottom of the keyboard to activate the wireless connection.
    4. Press the connect button on top of the receiver and the button will blink.
    5. Press the connect button on the bottom of the mouse to activate the wireless connection.
Dec 03, 2017 | Gateway Computers & Internet
How to install hp g2 keybaord
plug in the usb dongle to your computer and it will detect your keyboard and mouse. be sure your keyboard and mouse have fresh batteries. then you are ready to rock and roll.
Please rate me. Thank you
Mar 06, 2011 | HP DC170B Keyboard
Cordless Keybaord - Some keys not functioning
Could be interference from a wireless device using the same frequency. Locate any other wireless keyboard/mice from the vacinity and try it again. Also, push the connect button on the bottom of the keyboard and see if that helps. Also make sure the base station of the keyboard is close enough to the keyboard/mouse.
Jun 25, 2010 | Logitech Wireless Access Duo Optical...
ET2203t eee mouse and keybaord wont work
Make sure you "synchronize" the wireless
unit(s) with the base unit(plugged into computer)-click buttons on each to sync: first one, then the other-This needs to be done each time batteries are replaced.
Hope this helps.
Mar 04, 2010 | ASUS Eee Top ET2203TB0317 216Inch Black...
Memorex wireless keyboard programming problem
after replacing the batteries u will c a small connect button on the wireless usb receiver on the computer as well as the connect button on the mouse and the keyboard,,press it on the adapter and then on the keyboard and teh mouse to get all of them resynchronized
best of luck,giva good rating,,keep me posted
May 19, 2009 | Memorex RF 6000 (32021432) Keyboard
Hp dv2000 with vista
Power off and power back on your computer if you haven't done so. Sorry I have ask. Try USB mouse and keybaord and see if that work.
Jul 29, 2008 | HP (H50092)
Microsoft vista and wirless mouse problem
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the software program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jul 27, 2008 | Microsoft Wireless Notebook Optical Mouse...
Wireless keyboard & mouse not working
First download and run regscrub xp and ccleaner to clean up your system then try uninstalling and reinstalling the logitech setpoint software and try the keyboard and mouse again. Let me know if this works.
Oct 23, 2007 | Logitech Wireless Access Duo Optical...
Dell Dimension 4600 PC Desktop Logo
Ekse
Clive
Clive
Alun Cox
