Screen does not light up - Computers & Internet
  • mijoca1 Jun 13, 2008
    The same thing just happened to me this week. What did you end up doing?
I just purchased a used HP Pavilion dv9000. I worked it before I left the shop. I got home (smooth ride), put it on my desk, hooked it up to AC, opened the lid, hit the powew switch (upper left side), and all the little blue lights come on (blink often), but the screen stays totally black, not lighting up. Whats up? The dealer was closing and said bring it back tomorrow, but I need it tonight! HELP
Posted on Apr 10, 2009
I have same problem. I tihnk you need to replace the screen as the tube has blown behind the screen. depending on the age of your computer, it may not be worth it. check out the cheep oldish laptops on ebay
Posted on May 05, 2008
Having issues with screen, everything with computer works and lights are all turning on but screen wont light up and shows no image.
This sounds like a faulty hardware. i would suggest taking it to sony if its still under warranty and get it replaced. if not contact a local technician.
May 31, 2015 | Sony VAIO Duo 11 SVD11225CXB 11.6"...
If the touch screen wont light up on a falcon 4220 does that mean the touch screen itself is bad?
THE TOUCHSCREEN/DIGITIZER IS A DIFFERENT PART FROM THE ACTUAL SCREEN , YOU JUST HAVE A BAD SCREEN .DIGITIZER IS GOOD .
HOPE THIS HELPS ,IF NOT I CAN HELP YOU MORE
Nov 19, 2014 | Datalogic PSC Falcon 4220 Data collection...
Why does my Janome MC9000 screen not light up, it sews ok, needle works up and down.
It depends on the screen; a few have a small light or lights behind them, but I believe for most modern screens, the lighting is in the screen itself. It sounds as if yours is not working, but it CAN be replaced, and it's not a hard job to do so--although the part may be a little pricey. It's roughly equivalent to the screen of a laptop not working.
This is definitely a job for a technician.
Sep 13, 2014 | Sewing Machines
Tv wont turn on
does the light stay or blinking and how about the screen display totally black or a white screen. you can see in a dark room if their is a white screen. if totally black screen then with sound the cause is could be bad inverter board or screen back light. if a white screen it was the t-con board not working good.
Oct 04, 2012 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
When my computer boots up sometimes the screen is ok, but more often the screen fades and goes black. If I switch the monitor off and then on again the screen shows the icons etc for about 2 seconds and...
This could be that the screen topback light or bottom back light is bad or the inverter.
the topback or bottom back light could also be seing as the flouricent of the screen that light up the screen to enable display visible.This top back light or botom back light as the name implies is positioned at the top and bottom side of the screen.It takes an expertize knowledge for one to be able to change the flouricent when comfirms bad.The same is applicable with Inverter.
Jan 06, 2011 | Proview PL913S 19" Flat Panel LCD Monitor
Screen on laptop won't light up
There is a board called an inverter behind the screen besel. The inverter is like a balast in a flouresent light. The inverter supplies the power to light the screen.
Oct 20, 2009 | Toshiba Satellite Pro L300-EZ1005X...
I have a problem with my psp I can't see nothing in the screen but i can hear the sound of the psp
Hi
i have had a similar problem,
this could be one of two things
1 your screen back light is damaged
2 your LCD screen has been very badly cracked
dose your screen light up at all?
if it dose light up then you would need to replace the screen
if it doesn't light up you may just need a back light.
Aug 27, 2009 | Sony PlayStation Portable (PSP) Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
OPC/DL light flashing Same problem of black screen and green lights flashing at power and OPC Help....
WHEN FLAT SCREEN SHARP LCD IS ON .. BLIKNING ON BOTTOM OF SCREEN SAYS OPC
Dec 08, 2008 | Televison & Video
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
