Question about Toshiba Tecra M1 PC Laptops
Bios Password Can you help me find the place of battery to be removed for 5 minutes i have dismantle the laptop but i cant find the battery ?
    Problem Solver:
  • 10 Answers
Unplug everything from the laptop, and take out the battery. Hold down the power button for 20 seconds, then plug everything back in and turn it on. It should reset the CMOS.
Posted on Apr 22, 2008
SOURCE:
I locked my hard drive and cant remember the password
Only way is a long shot and you will have to dismantle your laptop....disconnect the bio battery for about 5 minutes.....
Mar 30, 2012 | Acer Computers & Internet
Password for phoenixbios 4.0 release 6.0.5
If you've lost the bios password, you'll probably have to 'flash' the bios. If you feel comfortable enough, you can dismantle the laptop and remove the motherboard battery for several minutes, then replace it and reassemble the system, see if the password has been cleared. (Note: The motherboard battery is NOT the laptop battery; you have to remove both!)
Dec 12, 2011 | IBM ThinkPad A21m 2628 Notebook
I forgot my bios password of my laptop hp 6730s and cant even reformat it ? any help plz ? thank you so much .
You need to clear the cmos. This is accomplished by removing the cmos battery for 5-10 minutes.
1. Remove the battery 2. Remove the keyboard 3. Remove the LED switch cover 4. Remove the cmos battery cable from the motherboard 5. slide the battery out of the brack
Reverse the step after 10 minutes and the bios should be reset. On first boot you are going to need to reset your clock, settings etc.
Jun 28, 2011 | HP Compaq 6730s Notebook
How do i reset bios password on hp nx6125
1) dismantle laptop and remove laptop BIOS battery (as per HP documentation)
2) attach power adapter and power on laptop WITHOUT the battery in place
3) reassemble laptop and enjoy the reset BIOS
May 28, 2011 | HP Compaq Business nx6125 Notebook
Password bios
Resetting the BIOS password for a laptop can be difficult. A typical way to reset the BIOS password is to remove the CMOS battery from inside the computer. By removing the CMOS battery, a small battery inside the computer that looks like a watch battery...it should clear out the password. Often times with a laptop though, the CMOS battery might not be easily accessible.
I have done this before by unscrewing the bottom or back of the laptop, and then looking for the battery. You remove the battery for lets say 5 minutes, and let the laptop sit. Then carefully put the battery back in, and reboot the laptop, and see if BIOS password is gone.
I would recommend letting someone from a local PC repair place try this, as it can be a delicate procedure. Otherwise you need to follow up directly with Dell and probably send it off to them.
Alternately, you could try and take main the battery out of the laptop to try and reset it. I'm not sure though this would clear a BIOS password.
Hope this helps.
May 17, 2011 | Dell XPS M1330 Notebook
How to reset laptop compaq nx6325 bios password
To remove the bios password you need to clear the CMOS.
Open your laptop casing look at your motherboard. locate the CMOS jamper it is near the battery. To clear remove the jamper and turn your computer on with in 5 to 10 seconds and turn it off. Reinsert the jamper back to there proper place and try to turn go to BIOS if there will be a password box appear.
You need to open your laptop and look at the motherboard and locate the CMOS battery. Just remove it with in 5 minutes to clear BIOS password.
Nov 30, 2010 | HP Compaq nx6325 Notebook
My kids setup a bios password on my new HP laptop and they cant remember it. How do i remove the password without knowing the previous that was set by them. Please guys help me.
The only way to do this is to reset the CMOS/BIOS memory.
  1. Remove the back cover of your laptop to "reveal" motherboard.
  2. Make a way so that you can see the a bigger portion of the motherboard ESPECIALLY the small lithium battery powering the CMOS chip.
  3. If this battery is reachable, remove it in place.
  4. After 3 minutes or more, place the battery back.
  5. Place the covers back and power on your laptop.
  6. The bios password now should be removed since the content of the CMOS memory is cleared.
Jun 06, 2010 | Computers & Internet
Missing Toshiba Satllite m55 Bios Password
Apr 12, 2010 | Toshiba Satellite M55-S135 Notebook
I have locked my computer,so when i try to turn it odd it goes back to the password screen. can any one help. cheers ****
Depending on the brand of the laptop, you can reset the BIOS password juts by removing ALL power sources: AC Adapter, main battery and BIOS Battery for a t least 5 minutes. The BIOS battery may require some disassembling, but loook in the usual places: memory compartment, hard disk compartment, and WiFi compartment.Some brand laptop can be render useless due to a BIOS Password. Your laptop manufacturer can reset your password for a mere $200 or so. Give them a call.
Apr 16, 2009 | Computers & Internet
Toshiba password
I assume youve tried everything.
you have 2 options.you havent said what type of password this is but these methods will sort all.
if its a bios password you need to find rtc(requires dismantle)
and remove battery for 5 minutes then replace battery.reassemble and restart.if its just a personal password reinstall window os
Mar 03, 2008 | Toshiba Tecra M1 PC Laptops
Toshiba Tecra M1 PC Laptops Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
