I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
SOURCE: Our Clothes smell musty and the washer smells too
I checked the whirlpool web site and typed in "musty washer" for a search of the site. They gave directions on how to run a cleaning cycle on the machine (whether your washer has a special button for it or not) This REALLY helped my machine. They also had trouble shooting tips for keeping the musty smell away.
SOURCE: Clothes smell musty like wet towels after washed and dried.
check your detergent you are using, it should be a HE detegrent for High Efficency machines, too much regular detergent will suds up and nver be removed from clothing causing such a smell.a quick test to see if your using too much detergent, grab a sock form oyour drawer(clean one) place it in a glass of water and swish it up and dowen a few times, if soapy bubble wateris present then youre over soaping!
SOURCE: Clothes smell musty when dried
SOURCE: My clothes have a musty smell after being washed
Make sure there are no leaks from the machine. Look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose and door rubber is completely clear of debris and soap scum build up and check that the filter is clean.
You can initially use a bathroom mould and bacteria cleaner to get rid of the immediate problem or wash using a bleach solution made up from 1 part household bleach to 10 parts water. Place this in an aerosol spray bottle and spray the affected area and leave for 10 mins then wipe away and rinse with clean water.
SOURCE: Clothes do not get clean. Washer twist clothes in
My pant legs and long sleve shirts twist into a knot, every time. How can I stop this from happening?
