Sata II jumper selections
Would like to know where to place the jumper on seagate sata II 500gb 32 mb for best performane as on it displays 2 positions, 1 for 1.5 gb and 1 for 3.0gb.
Not sure if removing it will be if not same as any above.
  • hybrid1001 Mar 20, 2008
    That is as it depics on the unit but some how have displaced the jumper.
    Would it still work and how?
    If any can tell me
  • hybrid1001 Mar 22, 2008
    Actualy recorrecting the above as:
    with jumper on in one position enables the 1.5 gb mode as with it off
    enables the 3.0 gbs mode.
    Wondering what could other combinations be as there are 4 pins, and the jumper is a 2 pin, meaning 4 possible modes:
    jumper place on the 2 right=1.5 gbs
    jumper removed=3.0 gbs
    jumper placed on the two middle= does not say
    jumper placed on the 2 left=does not say
    If only the 2 modes for it useable then there would only be the 2 pins (jumper on and jumper off)
    Really would like to know what are the other two combinations for it as it does not say.
  • 4,234 Answers
If the majority of hte actual data transfers are small, you won't see significant difference. The 3 GB position is to enable higher transfer rates which will only be noticed when transferring large amounts of data at a time. If you are doing video processing the higher rate should provide better overall performance.
Dan
Posted on Mar 20, 2008
  • ABRsvcs Mar 23, 2008
    All drives controllers are created with expansion in mind as the time for development and testing is long. There are often changes in technology that can significantly change what is available. In this case, perhaps there are soime drives in development that can transfer at higher rates. The extra options will have no effect on the existing drive, but leave expansion capabilities for future ones.
    One other possibility (probably the correct one for this case) is that the 4 pin jumper selection part is less money and easier for automatic parts injection machines.
    Only a rep for the drive manufacturer will know for sure.
    Dan
SOURCE:
Cannot detect Seagate Barracuda 7200.9
The motherboard has two SATA connectors but they only go up to a 150 MB/s data transfer rate.
Your Seagate however, is engineered for 300 MB/s data transfer.
Download the Seagate manual for this drive and you will see the diagram on the last page that shows how to place a jumper on the drive to make it work at 150 MB/s.
Mar 21, 2010 | EPoX EP-8HDAI PRO VIA K8T800 CHIPSET...
Im just about to buy a SATA II 500GB hard disk for this MB, i need to know if this would be compatible with the MB??! Thanks
SATA 2 (SATA 300) is not backwards compatible with a SATA (SATA 150) controller. In order to use a SATA 2 drive on a SATA (SATA 1?) controller, the hard drive must have a jumper position to restrict it to using SATA (SATA 150), and a jumper must be installed. Some drives have the jumper position available (e.g. some recent Samsung), some don't (e.g. some recent Maxtor).
This information can also probably be easily found on your hard drive manufacturer's web site.
If your drive does not have the jumper position available, you must return it and get a SATA 2 one that does, or a SATA drive.
Jan 11, 2010 | Abit KW7 Motherboard
Epox motherboard and SATA disk
According to the hard drive manufacturer Maxtor, motherboard host controllers using the VIA and SIS chipsets VT8237, VT8237R, VT6420, VT6421L, SIS760, SIS964 found on the ECS 755-A2 manufactured in 2003, do not support SATA 3 Gbit/s drives. To address interoperability problems, the largest hard drive manufacturer, Seagate/Maxtor, has added a user-accessible jumper-switch known as the Force 150, to switch between 150 MB/s and 300 MB/s operation.[9] Users with a SATA 1.5 Gbit/s motherboard with one of the listed chipsets should either buy an ordinary SATA 1.5 Gbit/s hard disk, buy a SATA 3 Gbit/s hard disk with the user-accessible jumper, or buy a PCI or PCI-E card to add full SATA 3 Gbit/s capability and compatibility. Western Digital uses a jumper setting called "OPT1 Enabled" to force 150 MB/s data transfer speed. OPT1 is used by putting the jumper on pins 5 & 6. http://en.wikipedia.org/wiki/Serial_ATA
Dalius
Mar 30, 2009 | EPoX EP-8K9A7I Motherboard
Hard drive crash on dell 2400. Bought new Seagate 500gb hard drive. Installed with sata port to motherboard connected. On BIOS setup enabled sata port to auto, only two selections off/auto. On atempting to...
you will have to install a driver before it picks your sata drive up. when your cd starts to install youll see an option F6 to install sata drivers from a floppy
http://xphelpandsupport.mvps.org/how_do_i_install_windows_xp_on_a.htm
let me know if that guide helps
Aug 11, 2008 | Computers & Internet
PCI Card for SATA I VS SATA II
There are many PCI SATA controller cards out there. Just know that the SATA will not run at the SATA II standard. This is because you're motherboard may not support the bus speed for the SATA II or SATA I. If you current motherboard does not have a SATA port built on it, than your not going to see the speed the drive is able to run. Click this link (a Google search for PCI SATA II controller cards). http://www.google.com/search?hl=en&q=PCI+SATA+II+controller+cards&btnG=Search
Watch out for PCI-X. This is not the same as a PCI slot.
PCI-X slots are only found on motherboards that have SATA I & SATA II slots on them. These PCI-X slots are the smaller SATA slots found inbetween PCI-Express sloted boards.
Promise controller cards make some of the best controller cards on the market.
Mike
Jul 26, 2008 | Computers & Internet
SATA drive not detected in BIOS and windows does not boot up
i have same problem with WD 250GB sata HDD. with same bord K8V-MX,  i all reday update BIOS with 0502 version.
plz plz plz help me.
CC me [email protected]
Feb 21, 2008 | ASUS K8V-MX Motherboard
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Sata, ide
Update: SATA II drives do have jumpers to make them backwards compatible with 1.5 Gb/s (SATA II drives are 3.0 Gb/s). So if your system is older and can only handle SATA (first Gen) then you have to add a jumper (Seagate has the jumper setting on the drive but sometimes supplies no jumper i.e. you have to have your own).
Sep 30, 2007 | Computers & Internet
Open Questions:
Computers & Internet Logo
201 people viewed this question
Ekse
Alun Cox
