On left hand side, remove rear foot board and plastic cover ,you may remove battery and in behind their is a block which has 2 - 30 amp fufuses . That is your solution . Check and replace as required.
1st check the fuse(s) including the main fuse on the starter solenoid.
Then check battery connections are tight.
If OK then check wiring & connections from battery to starter solenoid to ignition switch, but with no meter it will have to be a visual check for bad connections or squashed wires
Hope this helps (if so please mark as very helpful)
Ride Safe
Bike-Doc
