Question about Pioneer AVH-P6500DVD Car DVD Player
DISC STUCK AND ERROR 02 MESSAGE
Please help!!! How can I remove the disc stuck in my in-car cd player???
  • logielow Apr 09, 2008
    A cd is stuck in mine too.... i tried the reset button, that sidn't work... I'm really thinking about takin it apart... i'm not sure though.... help me
  • j933 vrd Apr 09, 2008
    i also have same problem. any advice??? please
Hi, i have a kenwood kvt_725(or did have before some scallywag robbed it) i had a simular problem when ejecting discs i found that if you turn power off and removed face plate and turned ignition off it eventually ejected the disc and worked, or a simular routine with the face plate then ignition etc etc. i know it seems a lame solution sorry but hope it helps.....
Posted on May 28, 2008
How to remove disc error message for my lg ht303su-a2 dvd cd player because it plays some dvds and other dvds wont play
Check a CD. If it plays, the Optical Pickup for the DVD is worn out and will need to be replaced.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Dec 22, 2014 | LG HT303SU Theater System
How to remove a jammed cd out of a car cd player
I hope you don't use the DCM-360 in your car. You should be able to eject the CD, with pressing the eject button, several times. It could be the eject mechanism is defect, or someone pressed the CD too far, r even some debris came in the player, after the ce was inserted.
In most cases, you really should remove the player en open it. to avoid more damage than already exists
May 02, 2014 | Denon DCM-360 5-Disc CD Changer
Getting error 02-9e with avr p4000dvd
this is commonly your laser mechanism being bad although the code is for an unreadable disc. play the disc same disc in another player in order to rule out bad cd. if cd plays bring radio in for repair or replace.
if helpful please rate 4 thumbs
Dec 31, 2010 | Pioneer Car Audio & Video
Car MP3 player error
I believe that error 6 means incompatable disc format or disc read error.
Jun 12, 2008 | Clarion Car Audio & Video
Disc removal
Try pressing the reset button on the front of the unit, you will need a pen to get at the button.
Feb 19, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
Dec 24, 2007 | Marantz CC-4300 5-Disc CD Changer
Jeep 10 disc changer; now only error message on dash.
I had this same problem on my 2000 Jeep GC Limited. Today I decided to open it up after looking all over the net and found no help, but spend $500.00 on a new unit. I removed the unit and used canned air inside all the areas I could. I hooked it back up and was finally able to make the CD cleaner disc work. Once that was done I loaded it with 10 cd's and it is working again. I'm so happy! I saved my hubby 500 big ones.
Oct 26, 2007 | Cherokee Jeep Grand CD Changers - 10-Disc
Error message
got the smae problem gc 02. error msg in display..any tips?
Rpd 552 cd reader problem
Message Possible cause Recommended action
E-01 Dirty disc. Clean the disc.
Scratched disc. Replace the disc.
Up-side-down. Check the disc.
E-02 Focus error. Try ejecting and re-inserting
under normal temperature
conditions.
E-03 Data and focus error. Under normal temperature
conditions, eject and
insert clean, undamaged
disc properly.
E-04 Mechanical problem. Eject and re-insert.
Oct 17, 2007 | Blaupunkt RPD 552 CD Player
Pioneer AVH-P6500DVD Car DVD Player Logo
375 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
