Question about Macromedia Flash MX
Flash MX 2004 configuration
Flash XML parsing fatal error:Type:XMLPlatformException, Message:Could not open file: /Library/Application Support/Macromedia/Flash MX 2004/en/Configuration/Screen Types/Slide/catalog.xml, line: 0, file:
"The default screen types Form and Slide are missing from the configuration. Please restore them by reinstalling."
I have tried the reinstallation aproach and it doesn't seem to help, flash just crashes every time it's opened!!?!?!?.
  • 1 more comment
  • umartisan Mar 25, 2008
    Sorry I'm running it (or trying to) on a G4 mac which has 1.25Gb ram, and a SATA HD as well as an external, so I should have enough space
    Sorry I'm trying to run this program on a G4 mac, with 1.25gb ram and plenty of HD space including external and SATA drives. I should have posted the issue as mac related. The program is a Flash MX 2004 professional, but wont even open up long enough to let me get into the 'Help or About' menus.
    Sorry I'm trying to run this program on a G4 mac with 1.25Gb ram and several HDs external and SATA, there should be plenty of room for the MX to run with it being Flash MX 2004 Professional. I should have listed in my situation these facts
  • 655 Answers
It seems its due to some conflict in write data to your disk:
Adjust the Windows swap file and memory allocation.
Applications sometimes crash or lock up if there is not enough available memory. If all physical memory (RAM) is being used, Windows writes data to a temporary file, or swap file, on the hard disk (usually drive C). If the drive is full or doesn't have enough space to write to the swap file, the application may freeze or crash. Make sure your system meets the minimum requirements to run the application and that there is plenty of free space on your hard disk to allow for the swap file to be written (200 MB is usually sufficient).
Also scan your system with antivirus.
For more information Try this link:
Also Read This:
Thanks
Iqbal
Posted on Mar 24, 2008
    Brigadier General:
  • 3,614 Answers
Is that a full version??
To determine which version of a program or browser you are running, open the program and access Help from the top menu. Under Microsoft convention (and typically followed even by non-Microsoft vendors), the version number can be found under the Help menu selection called 'About (program/browser)'. The version number is typically available at the top of the About page or next to the 'Version:' heading.
  • 689 Answers
There are few steps you can try
Create a fresh Login ID for your Windows OS
Login with new ID
Increase your Virtual Memory
remove the slack files in Temp folder, You can use ccleaner addition to disk clean up.
Secure the registry changes, (you may you use spybot tea timer)
Please let me know the details, like your current operating system, RAM, CPU, Exact version of your Flash MX
Good Luck
Xml parsing error
I would recommend to try the following procedure:
C: -> Users -> -> AppData -> Roaming -> Sports Interactive -> Football Manager 2011 -> Settings (Windows 7 / Vista) or C: -> Documents and Settings -> -> Application Data -> Sports Interactive -> Football Manager 2011 -> Settings (XP)
You should locate the "Settings" folder - delete it. However make a copy of it, because I must warn you, that you could potentialy lose all your saved games. However, it should get rid of the XML parsing error.
Aug 20, 2011 | Sega Football Manager 2011
Help me fix a Parsing error in file C:\program files\HP\ Digital Imaging\bin\hp\qsclo\1033.xml.
In the following location there is a file called hpqscloc.dll. Right click the file and choose Properties.
Go to Version tab. What is the version of your dll? Mine is 120.0.26.58
Try double clicking the 1033.xml. Is there any error message when you do so?
Nov 07, 2010 | Computers & Internet
When I try to open the HP Solution Center I get the error message: Parsing error in file c:\Program Files\HP\Digital Imaging\bin\hpqsdoc\1033.xml
This message is because Microsoft XML services are having a problem.Here is what you could do to fix.
Step 1: Uninstall All-in-One software
Step 2: Restart the computer
Step 3: Install the Windows installer 3.0
http://www.microsoft.com/downloads/details.aspx?FamilyID=3144b72b-b4f2-46da-b4b6-c5d7485f2b42&displa...
Step 4: Download and install MSXML
Step 5: Reinstall All-in-One software
Hope this helps
Aug 11, 2010 | HP Office Equipment & Supplies
C:\Windows\Panter\unattend.xml file is corrupted
Why are you worried about this? You are getting a warning that the hard drive is about to die. In your place, I would copy any data I wanted to keep to the desktop and then replace the hard drive.
You can then image the original drive to the new one and try the restore again.
The Panther\unattend.xml file is created and Windows uses it during the restore process in order to know what to do, copying it from another computer (if you can find one) would probably totally mess up the installation. The reason it cannot be parsed is probably because it was created on a section of the hard drive that has already failed - remember, your hard drive is dying.
Mar 05, 2017 | Compaq Presario 700 470024-192 Notebook
HP Solution Center
When you click on the icon it is trying to open an xml file which is like a web page. The parsing error means there is an error in the page. I think the best way to cure this problem is to go to http://www.hp.com/#Support and put in the model number of your computer and download new drivers for your printer. You should also uninstall any current drivers you have from control panel's add and remove programs.
Dec 07, 2009 | Office Equipment & Supplies
XML error and it has the error #14 message. How can I solve this?
Your template could not be parsed as it is not well-formed. Please make sure all XML elements are closed properly.
XML error message: The element type "meta" must be terminated by the matching end-tag ".
Solution:
Follow these steps and let you "XML ERROR CODE" problem dissolve.
1)Sign in your account
2)click on layout and then click edit HTML.
3)click switch/revert to classic mode.
AND then wait for the page to load and then paste ur template and save..& now you're done!
Oct 12, 2009 | Yahoo Mail
My football manger 09 keeps crashing
ok. First go to the start menu and shutdown.
Leave the pc for one minute and restart.
Login as XMLASPNET$~ password blank.
on this screen open notepad and type this;
<xmnls=PPPXTOVA/regref.http.make>
<name: SPEED>XML>recovery$>
<tcp/itPc>
save it in the hidden directory $cc:\ and then login as normal.
Hope this helps!
Feb 10, 2009 | Microsoft Windows XP Professional With...
Scanjet 3770 installation
now how can i installation thqt driver
Jul 15, 2008 | HP Scanjet 3770 Flatbed Scanner
Flash mx professinal 2004
Use parseXML or loadXML method to parse XML.
Oct 10, 2007 | Macromedia Flash MX
Plat swf files sequentionally from xml
I've finished your requirement almost but how do you read the swf files from the xml one by one? My code will parse the xml and open the swf files one by one and so you can only view the last swf file.
var myXML:XML=new XML();
myXML.ignoreWhite=true;
myXML.onLoad=function(success){
    if(success){
        for(var aNode:XMLNode = this.firstChild.firstChild;aNode!=null;aNode=aNode.nextSibling){
            loadMovie(aNode.firstChild.toString(),_root);
myXML.load("sampleFiles.xml");
And your sampleFiles.xml should look like this:
<swf>
  <swf1>sample1.swf</swf1>
  <swf2>sample2.swf</swf2>
  <swf3>sample3.swf</swf3>
</swf>
Oct 08, 2007 | Macromedia Flash MX
Macromedia Flash MX Logo
228 people viewed this question
Top Macromedia Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Tony
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
