Whirlpool GZ7730XGS Stainless Steel Kitchen Hood
Problem for Whirlpool GZ7730XGS Stainless Steel Kitchen Hood
Neff extractor fan not working
By Electridiot on Mar 20, 2008
Hi - I have a neff extractor fan which hasstopped working. The light and fan have both stopped working. Do youknow where I can find the fuse as I suspect that this may be the problem. If you/ don't think it is the fuse would you be able to suggest anything else please
The type is D-AY25-8 If there is another number that is more helpful please let em know. thanks
Same Problem
Sep 19, 2009
-   After changing the 3amp fuse, changing the the bulb was simple. The plastic covering (NEFF built in) slid out really easily. So if it is not coming, then you probably need to push it another way. -   markthierry
Jan 02, 2009
-   Dito, really need some help with same problem.    -   Guest
Nov 03, 2008
-   I too have the same problem!-   fixit9
Nov 03, 2008
-   does anyone have a solution for this as i also have this problem?-   Guest
Aug 02, 2008
-   I have the same issue with both the fan and the light not working. Did you manage to find an answer to this?-   Guest
Best Solution
posted on Jan 29, 2009
Very Helpful)
unpractical
Rank: Apprentice
Rating: 100%, 1 votes
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Whirlpool GZ7730XGS Stainless
Questions and Unsolved Problems for Whirlpool GZ7730XGS Stainless
Do you recommend Whirlpool GZ7730XGS Stainless Steel Kitchen Hood?
Answer
Answer
need wiring diagram for Whirlpool GZ7936XHS1 Ventilaror
Answer
what is the root cause to my fuse blowing in the cooker hood? I have installed 3amp, 5amp but still... (More)
Answer
switch for a vulcan rangehoodmodel 7227
Answer
my viking downdraft vent isn't working. I didn't have the vent cover on right and when it retracted... (More)
Answer
i need the conrol buttons and filter for a miami carey vent model #rh4500 serial # 5500
Describe your Kitchen Hoods problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Hood Experts
Top Range & Oven Repairmen
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
