Cause code 31 - Audio Players & Recorders
  • 4,234 Answers
There is nothing to go on here. Can you update this with a make and model as well as what you do to get this message? Does the unit work at all? Trying to start it do you get an initial click followed by this error?
Thanks,
Dan
Posted on Mar 20, 2008
Error code 31 CD ROM driver not available how to install this driver
  1. Restart your computer if you haven't done so already.
    There is always the remote possibility that the Code 31 error you're seeing was caused by some temporary issue with Device Manager. If so, a simple reboot might fix the Code 31.
  2. Did you install a device or make a change in Device Manager just before the Code 31 error appeared? If so, it's very possible that the change you made caused the Code 31 error.
    Undo the change if you can, restart your PC, and then check again for the Code 31 error.
    Depending on the changes you made, some solutions might include:
  3. Delete the UpperFilters and LowerFilters registry values. A common cause of Code 31 errors is the corruption of two registry values in the DVD/CD-ROM Drive Class registry key.
    Note: Deleting similar values in the Windows Registry could also be the solution to a Code 31 error that appears on a device other than a DVD or CD drive. The UpperFilters/LowerFilters tutorial linked above will show you exactly what you need to do.
  4. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 31 error is a likely fix for this problem.
  5. Replace the hardware. As a last resort, you might need to replace the hardware that has the Code 31 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you're convinced that hardware isn't the cause of this particular Code 31 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those before you try replacing the hardware, but you may have to give them a shot if you're out of other options.
Applies To
The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Aug 16, 2016 | Computers & Internet
Mazda 6 2014 what is airbag fault cod 31
The car should still be under warranty if a 2014 model so you should be taking it to a dealer to have it checked and rectified.
Code 31......Side Impact Air Bag Sensor Connector Poor Connection Passenger's Side
Sep 26, 2015 | 2014 Mazda 6
CODE 31 HOW TO FIX 95 TOYOTA CAMRY
That means trouble with the manifold pressure sensor, which causes trouble with injection and ignition timing. See here p372
http://www.turboninjas.com/camry/eg1.pdf
Jul 20, 2012 | 1995 Toyota Camry
Area code of south korea
This is how you call South Korea from the U.S. or Canada: You dial 011 + 82 + area code + phone number. For a cell phone it is 011 + 82 + 1? ???? ???(?). Please note that some south korean phone number are not 9 or 10. They vary from 6 to 12 numbers. The area codes are
Ansan 31 Iksan 63 Posong 61 Anyang 31 Inchon 32 Pusan 51 Changwon 55 Koyang 31 Pyongtaek 31 Cheju 64 Kumi 54 Songnam 31 Chongju 43 Kunsan 63 Seoul 2 Chonju 63 Kwangju 62 Suwon 31 Chonan 41 Kwangyang 61 Taegu 53 Chinju 55 Masan 55 Taejon 42 Chunchon 33 Mokpo 61 Ulchin 54 Dangjin 41 Pohang 54 Wonju 33
May 06, 2011 | Kitchen Ranges
I want to know the area code of korea?
South Korea's Country Code is 82. It's Area Codes (considered "City Codes") are:
(To call S. Korea from the US or Canada, you'd dial: 011 82 City_Code Phone_Number.)
Cheers!
Oct 15, 2010 | Computers & Internet
Check engine codes for a 1997 stratus the codes coming up are 12 31 and 55
12 Recently disconnected the battery (always stored)
55 End test.
CODE 31... depending on the model, code 31 can refer to two different systems. Please choose from one of the above links for specific information on each system.
Wastegate Solenoid Circuit Error
The ECM regulates turbocharger boost by opening and closing the "wastegate" as necessary. (The wastegate is a vacuum operated bypass valve that limits the ability of the turbo to provide boost.) The Wastegate Solenoid regulates the vacuum supply to the wastegate for proper operation.
Fault Code Description
  • 31 - Wastegate Solenoid circuit error
Symptoms
  • Lack of power or engine "ping" due to overboost by the turbocharger
Common Problems
  • The wastegate solenoid would be the most common cause for code 31 to set
  • Code 31 does not indicate a problem with the turbocharger or wastegate
Gear Position Switch (PRNDL) Error The Gear Position switch tells the ECM which position the shifter is in. The ECM will use this information to inhibit starter operation, change the transmission shift pattern as necessary, and provide the information for the electronic shift indicator display on the dash.
  • 31 - Gear Position switch (PRNDL) error
Symptoms
  • Engine may not crank over in Park or Neutral
  • Electronic shift indicator may flash
Common Problems
A maladjusted or failed Gear Position switch would be the most common cause for a code 31
Hope helps with this (remember rated this post).
Jun 30, 2010 | 1997 Dodge Stratus
Hi, I have a emachines by acer laptop and it does show me that windows 7 have an error code 31. I have tried already to fix it by doing the system restore, I dowloaded the drivers that have being deleted...
Please let me know if you've fixed a Code 31 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Applies To The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Jun 18, 2010 | Computers & Internet
Sony 5 changer dvd player won't work. displayed code 31
Hi:
This may be caused by one or two causes. The laser pickup assembly is bad or the most common failure for DVD and CD players is the spindle motor. This motors bushings fails over time and does not spin the disc at the right speed so the unit times out. You can repair the by purchasing what sony calles the Mech Assembly it comes with new laser and stepper motor as well as the Spindle motor.
Mar 14, 2010 | Sony DVP-NC600 Multi-disc DVD Player
Shows code 31 22 and will not record
reel sensor is the problem of your camera... sometimes it is a poor connection of the sensor to the socket at the main board..clean the contact of the wiring using a pencil eraser and also check the pitch roller of the mechanical if it is install cause it might be loose at it post cause of the lock has been broken already....
Dec 06, 2007 | Sony Handycam CCD-TRV37 Camcorder
49 people viewed this question
 Grubhead
Grubhead
