Points gap setting
I need the points braker gap setting for a 1974 Ford Escort Mk1 1300L
0.6 mm
Posted on Jun 16, 2009
6ya staff
SOURCE:
How do adjust valves on a 1997 ford escort 2.0 4cyl
You will need a feeler gauge also you will need the specs for the gap set. Specs usually found ok Google
Jun 05, 2016 | 1997 Ford Escort
I have a 1974 Caddy. Eldo. 500 cu. I need to know were to set the gap on the points i just put in. I have a dwell meter ready to go.
.018"-.022" if memory serves. If you have a dwell meter to dial it in once you get it running 18 -20 will get you started
Jan 21, 2011 | 1974 Cadillac Eldorado
Settings for points for 454 engine86 chev c30 scotsdale one ton truck
You have a 1986 454 engine with an old style breaker point ignition distributor, GM has not used a breaker point ignition for their V-8 engines since 1974, is that an older distributor or something after-market?
The ignition points dwell angle for that engine should be set at 29-31 degrees dwell (a dwell meter would be the most accurate way to set the ignition points), or a .019 in. point gap.
The spark plug gap for that engine would be .035 in. and the timing should be set at 10 degrees before top dead center.
Jun 29, 2010 | 1986 Chevrolet Chevy
I need to know how to set the points on a 1976 360 yamaha
gain access to the points, behind the side engine case. once you can see them, turn over the engine slowly, till you see the points at there biggest gap, top dead center. loosen the one screw that lets the points pivot, and adjust to the correct gap, about 14 thou, or a cardboard buisness card is the correct thickness also
May 23, 2010 | 1974 Yamaha DT 360
What is the points gap for a 1970s Ford 400 truck
the thickness of a match book cover is how i always did it and worked perfectly,hope this helps you.
Feb 13, 2010 | 1982 Ford F 250
I have a 73 ford 1.6 industrial motor. need electronic distributo
Look on E-bay for an electronic CD unit that fires from the original points, but generates about 400 volts to fire the standard coil. My guess is that there is no all-electronic ignition system available even as a racing option. Ford used this engine in the Pinto line of cars from`'71 to `73, and all of them used points and condenser distributors. The points and condenser units work fine if in good order and the point gap set at .025". Hope this gives you an assist!
Jan 16, 2010 | 1998 Ford Escort
Spark plug setting 1998 escort 1.8 zetec
The Spark Plug Gap .054 (In thousandths of an inch)
Caution! Gap is not adjustable on certain plug brands
Aug 08, 2009 | 1998 Ford Escort
Whats the spark plug gap settings for a 200 zx2
If u buy plugs from autozone, or any other parts store, they're all ready pre-gapped. don't mess w/ them, and you'll be fine.
Apr 19, 2009 | 2001 Ford Escort ZX2
My 1974 ford pickup/F250 3/4 ton loses power and backfires
It sounds like the timing is off but moore likely it's caused by the point gap being to close due to wear on the rubbing block.
The gap of the points effects the timing.
You probably need to clean and adjust the points.
If that doesn't work try replacing the points and if the old one are pitted, replace the condenser also.
If that doen't work check the coil.
Jan 08, 2009 | 1982 Ford F 250
Open Questions:
SBCglobal MAil Online SuPPoRt {1=855={536}{5666}#[email protected] TOLL FREE SbCgLoBaL MaiL Tech Support Number @+1{{855*536%5666%}} USA Login Repair service center to resolve all SbCgLoBaL MaiL customer service phone Number products.SbCgLoBaL MaiL is an American multinational company which was founded by Michael SbCgLoBaL MaiL using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, SbCgLoBaL MaiL support number, and selling of computer-related services and products. SbCgLoBaL MaiL Tech Support Phone Number Recently, SbCgLoBaL MaiL has been named the number SbCgLoBaL MaiL technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SbCgLoBaL MaiL customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, ortonand Phone . Enter a SbCgLoBaL MaiL Service Tag or a SbCgLoBaL MaiL Get SbCgLoBaL MaiL Technical Support Phone Number and Customer Services. SbCgLoBaL MaiL is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. SbCgLoBaL MaiL Tech Support Number @+1{{855*536%5666%}} USA Login Repair service center to resolve all SbCgLoBaL MaiL customer service phone Number products.SbCgLoBaL MaiL is an American multinational company which was founded by Michael SbCgLoBaL MaiL using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, SbCgLoBaL MaiL support number, and selling of computer-related services and products. SbCgLoBaL MaiL Tech Support Phone Number Recently, SbCgLoBaL MaiL has been named the number SbCgLoBaL MaiL technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SbCgLoBaL MaiL customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, ortonand Phone . Enter a SbCgLoBaL MaiL Service Tag or a SbCgLoBaL MaiL Get SbCgLoBaL MaiL Technical Support Phone Number and Customer Services. SbCgLoBaL MaiL is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services. , the company offers computer related products and services.
Oct 23, 2019 | The Computers & Internet
Computers & Internet Logo
429 people viewed this question
Ekse
Marvin
Marvin
