No sound on television
I have just purchased a samsung 37" lcd and a samsung theatre sys ht-x200r i connected the two together with a hdmi and i have no sound through the speakers .
  • ezeflier Sep 08, 2008
    I have a Aquaos HD TV and a Harmon Kardon AVR 130. I ran a Optical cable from the TV to the AVR 130 Digital Optical Input. Now the problem, there doesn't seem to be a "set up' in the menu for the Optical cable. i.e. CD, DVD, TAPE ect. Please help!
  • Randy Sheppard May 11, 2010
    need a lot more info. from what you are telling in your problem, that is not possible. i need to know everything that you have in your system and how it is hooked up and with what type of cable. i would also like to know a list of the inputs and outputs of the componats (how they are marked on the back of the unit) that you are useing.
    Scholar:
  • 146 Answers
The next thing that you need to do is to check the setup of the stereo. Look at the owners manuel to find out how to set up the optical inputs.
Posted on Apr 01, 2008
I used an optical audio lead to play sound through the theatre sys not the audio out to audio in as suggested at the retailers. thanks
Posted on Mar 23, 2008
DAV-DZ777 no longer plays TV sound through home theatre. DVD, radio etc still works...
The hdmi needs to be ARC compatible and connected to the HDMI connected labled Arc.
Sep 10, 2016 | Sony Home Theater: DAV-DZ777 CODE FREE...
Tv sound cuts out after 30 secs from surround
The Controller is Defective and you need to get it replaced. Since it is new, it should be easy... This is one of the problems with purchasing something REFURBISHED from some of the outlets... But seeing that it is new, just bring it back to the store and get a replacement.
Mar 03, 2014 | Televison & Video
I have bouight a samsung home theatre system that comes complete wiht a DVd player - i also have a samsung blu ray player - naturally ithought they would be compatible!! how wrong i was!! the connections...
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
Jun 19, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Trouble hooking up sony components..Bravia, Home theatre, blu-ray
Got your post, I will work with the model #s. Get back with you soon. Also a tip for now: HDMI carries true digital video and audio so you may not need the optic cables.
Lone99star
Jan 30, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
I have no surround sound when watching normal T.V
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
Nov 17, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Audio video converters
click on this link if you cannot just copy and paste to your browser and go to the site. Dynex makes the converter you need to go from composite video to s-video.
http://www.bestbuy.com/site/olspage.jsp?skuId=8470139&st=composite+video+to+svideo&type=product&id=1184768166778
Nov 04, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Sep 11, 2007 | Samsung HTP-1200 System
107 people viewed this question
 Grubhead
Grubhead
