Question about Nokia 7610
Not able to access memory card
I can't able to access my memory card
  • 2 more comments
  • MacWayne Apr 26, 2008
    i formatted my nokia 7610 phone using hard format now i can't access my memory card it askes me for password.but i did not protect it with a password
  • Shri1980 May 09, 2008
    my nokia 7610 was not functioning well when i switched it on nothing came on except nokia and went off again. Then I went to Nokia Service Centre and after Formatting (Not sure, whtever they did with my Mobile) now I am not able to access memory card as it is asking for password which is not set by me... and perhaps, we have tried it more than 5 times, It is showing locked memory card... Please suggest
  • Totski May 17, 2008
    i cant install applications from the mmc & cant view pictures from it.. it always says "retry or all data will be lost.. i tried reformat my memory card & the phone.. but still i cant make use of my memory card can you help me with this?..
  • Anonymous Jul 29, 2008
    i can't access the memory
    President:
  • 1,017 Answers
The default security code for Nokia is 12345.
If you changed it, and have forgotten it:
You can recover the password. The best way is to download a file manager to your phone. I use Best Fileman for my N70, from http://www.smartphoneware.com/ It's for series 60 and 40. The trial version should be enough, it's only £5.60 anyway.
In the file manager (when installed on your phone) you'll find under- C:\System\mmcstore -the file you're looking for, you have to rename the file- mmcstore.txt -then send it to another mobile (best way) or your PC via bluetooth or USB, open it on the other phone and your password will be revealed.
Rename that file- mmcstore.txt -to just- mmcstore -there might be another file named- mmcstore.txt -to view your password rename one or the other- mmcstore1.txt -one is for your phone PIN number the other your MMC card.
Clear enough?
Posted on Mar 24, 2008
SOURCE:
On pokemon XD it keeps saying that the save file currupts I have alot of room on it but it still crrupts so what do I do to fix this
  • Fully Corrupt:
    When the entire save area of the Memory Card becomes corrupt, the system will inform the player that the Memory Card is corrupt and offer to format it. The card must be formatted before gameplay begins or when the game attempts to access the Memory Card. The exact message may vary from software to software.
    Follow the steps for formatting a memory card.
    For specific issues with the Memory Card 1019, please click here.
  • Suggestion: It is always a good idea to copy your most important files to a second Memory Card as a back-up.
  • Data Area Only Corrupt:
    When only the data area of a Memory Card is corrupt (not the entire Memory Card) the game may not detect this until the Memory Card is accessed. Once it is accessed, the game will inform the player that the file being accessed is corrupt and must be erased. The game will only delete the one file being accessed and will not format the entire Memory Card (Other saved game files on the Memory Card may be OK).
    Follow the steps for deleting a file.
  • Memory Card is Damaged:
    If the Memory Card has been physically damaged, or has been damaged beyond repair, you will get this message. The Memory Card will need to be replaced. The system may attempt to format the card, but if it cannot it will give the error Memory Card is Damaged. There is no way to recover the game data from the memory card.
    Please use our convenient repair options.
This procedure is only used if a corrupted Memory Card is inserted into the Nintendo GameCube.
If required, this procedure will begin automatically when you select "Memory Card Screen" from the main menu. You cannot use this procedure to erase files from a useable Memory Card.
  1. After selecting "Memory Card Screen" from the Main Menu, if your Memory Card requires formatting, a window will appear to ask for confirmation for formatting.
  2. Use the Control Stick to select "YES" and press the A Button
  3. A window will appear to notify you that all data will be erased and ask again for confirmation for formatting.
  4. Use the Control Stick to select "YES" and press the A Button.
NOTE: When you format a Memory Card, all data will be permanently erased and unable to be recovered.
Jan 11, 2011 | Nintendo GameCube Console
When I try to save replay,s on the gamecube game: tony hawks pro skater 3 I have a problem, First i play, then i save a replay,Then i go to main menu, options, load replay, i see a list of all my...
Memory Card Error Messages
Fully Corrupt:
For information on locating replacements for older products, please click here.
Dec 12, 2010 | Nintendo GameCube Console
My 7610 supernova memory card has been locked how do we get it unlocked
We enable a password security on our Nokia phone to keep the data on the memory card private and not accessible to others. However, many times you may have come up across a situation wherein you have completely forgotten the password of the memory card or simply the access to the memory card is denied.
Even though you have tried your best to come up with all the combinations of the passwords that strike in your mind but all your efforts seems to be going in vain. Instead of panicking in such a situation, you can stay calm and perform a few troubleshooting steps to access the phone’s memory card.
One of the easiest ways to unlock or access a blocked memory card of your phone is to rename the memory card. Here are the steps you can take to rename the phone’s memory card:
  • On your Nokia phone, press the Menu button and go to Gallery> Memory Card (Please note the location of the Memory Card on the phone’s software may vary with different models).
  • Do not open the Memory Card folder but only highlight it and then select Options > Rename and put a new name to your Memory Card by replacing the old name and press OK.
  • Restart the phone and you will be able to access your cell phone’s memory card easily.
Sep 11, 2010 | Nokia 7610 Supernova Cell Phone
Cannot access to my memory card files???
try to format the memory card or scan it with the kaspersky 2010
May 29, 2010 | Samsung SGH-G600 Cellular Phone
Memory Card not accessible
try to use oher memory card.... af same thing happens try to change memory card IC..... located near the memory card slot....
sexy-ym
Sep 10, 2008 | Nokia 6681 Cellular Phone
Not exes memori card
u cannot access directly from the memory card.you have to get access through tools - multimedia - audio or video
Jul 19, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Memoru card password
I had purchased a Nokia 6233 recently. I want to change the password to access memory card but it asks for Old password.
I do not know the old password... I am able to access the memory card.
Jun 25, 2008 | Nokia 6233 Cellular Phone
Access to memory card
You need a good recovery tool (software)...this can danage the memory card...
Jun 16, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
SD MICRO MEMORY CARD 2GB
Memory card (Menu 6.6 of the Samsung SGH D900
Use this menu to access the files stored on a memory
card. This menu is shown only when a memory card is
inserted into the phone.
Memory status (Menu 6.7)
You can check the total amount of memory for media
items and the amount of memory currently in use in
each media box.
• Your phone is preset to use FAT16-formatted memory cards.
If you insert a FAT32-formatted memory card,
the phone will ask you to reformat the memory card. If you do not, you will not be able to access the card from the phone.
• If a folder on a memory card has subfolders which
exceed the maximum folder depth supported by
your phone’s file system, you may not open or
delete the maximum depth subfolders on the phone.
Feb 24, 2008 | Samsung SGH-D900 Cellular Phone
Nokia 7610 Logo
107 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
