Question about Hotpoint WMA35 Front Load Washer
Hotpointfront loader when it spins it makes an awful noise, very loud roarin noise
  • 108 Answers
It is very likely that the bearings have failed. I have had a hotpoint wma33 fail at 23 months and had hotpoint fix it...
This is not an easy task to undertake on your own I spent a while looking into this.
If you have warranty (machine is less than 1 year old) or paid for extended cover then call hotpoint to replace... (They will do the whole drum its quicker). This should be free.
If you don't have warranty (your machine is older than 1 year) then still call Hotpoint - you will be charged £90 callout but parts are free for machines less than 5 years old. This is what I recommend.
or - do it yourself ( NOT RECOMMENDED)
I know two people who have purchased the bearings and spider kits - and wasted about 3 days because these things are really awkward to remove and refit. They both swear that £90 is a bargin after buying the spider and bearing see:
http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=954798&brand=&model=wma33&part=spider
This spider costs 61.25 + delivery - ouch.
As hotpoint will fit half a drum or full drum (Depending on what is on the van for £90) the actual cost of a half drum is 75.99 + delivery see: http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=639770&brand=&model=wma33&part=drum
and a full drum costs 176.96 + delivery
see: http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=639763&brand=&model=wma33&part=drum
They take away all the rubbish at the end also!
I hope this helps
Please dont forget to rate me as a fixya.
Posted on Mar 20, 2008
Front ballast wt falling of from plastic tub
Posted on Jun 05, 2008
SOURCE:
My front load washer is making a scraping noise and loud noise during the spin cycle
Could be bearing failure. It's quite common in front loaders.
Feb 23, 2018 | Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Maytag front loader makes a loud noise in spin cycle
If its a loud knocking noise it could be either the transit brackets are still in place or the machine needs levelling or the springs/dampers on the drum are faulty or the bearings to the drum need replacing
Apr 22, 2012 | Maytag Washing Machines
Washer making a loud noise on spin cycle..cabrio model top loader..
If you lift the outer cover you should see 4 supports at ech corner if one fell off it would spin un even and make a lot of noise
Sep 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Loud noise in slow down spin mode.
when it is in high spin then you stop the washer it makes a thumping noise until the basket stops sort of like a flat tire sounds to me like you need a drive block
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Hotpoint WMA35 Front Load Washer Logo
283 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
