M2N-e mb looses usb functions at random
My usb stops working for no reason. can't predict when it will happen. i have a m2n-e with the latest bios, ati hd2400 with 2 gigs of ram
  • chuckster173 Mar 23, 2008
    running xp sp3. problem was happening before installing sp3. other clues are that i can't seam to stream video over 2 minutes using ie7. sys either locks / freezes or auto softboot.
    President:
  • 2,351 Answers
You running Vista?
Posted on Mar 20, 2008
Hi I've a Asus m2n mb and i have the bad bios
what is the msg you get
then someone might be able to help
Jan 23, 2013 | Computers & Internet
Will an Asus m2n-e sli run an AMD Athlon X2 7850 2.8GHz am2+
As you can see here
http://www.cpu-upgrade.com/mb-ASUS/M2N-E.html
if you have the correct BIOS, yes.
Dec 24, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS m2n-e SLI video adaptor problem or pretty much shot
I had one of these motherboards. The USB shorted out and fried everything.
I would suggest returning whatever you can before its too late.
Dec 17, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
M2N MX Am2 Socket
Have you tried updating the BIOS?
Sep 09, 2008 | ASUS M2N-MX Motherboard
Require latest version of bios for Motherbd M2n-MX SE Plus
Motherboard : M2N-MX SE Plus
BIOS latest version: Version 0503
Description :
Fix when using AM2+ 9550 or 9650 CPU, there is incorrect information in "Revision" of "CPU Configuration" in BIOS Setup.Fix that PS2 mouse can not work without PS2 keyborad under VISTA HOME Basic Change the CNQ Function default to DISABLE.
Download:-
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=M2N-MX%20SE%20Plus
BIOS Recovery Step :
The CrashFree BIOS2 feature now includes the BIOS auto-recovery function in a support CD. Users can reboot their system through the support CD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional ROM.
Thanks & Regards
Rajesh
Jul 14, 2008 | ASUS Computers & Internet
Setting up SATA
You need to enter the bios. Use the M2N-E SLI manual to help make some changes. Start up the PC & begin to press the Delete key every two seconds. Doing this will open the bios. Open you're manual to page 4-29. All four SATA's should be set to Disable. Save & exit the bios. The SATA drives will still function but you should no longer get the screen to setup a RAID.
Enjoy!
Mike
May 30, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Usb Rumblepad 2 problems on a asus m2n-mx
Are the drivers for your device Vista compatible?
Head for the manufactuerer's website and get the latest software. There might be bug fixes that will solve your problem.
Apr 03, 2008 | ASUS M2N-MX Motherboard
Usb cannot recognized
Reinstall your USB drivers:
Navigate to Device manager, find a branch named "USB Controllers" or similar
Right click the one thats the problem (or all of them if you dont know which), select Uninstall
Reboot your machine and windows will autodetect the USBs and reinstall their drivers
Check the BIOS and see if they are enabled...
Disable power management on the USB hub To preserve power, Microsoft1.gif Window XP tries to disable USB when a device is not used. Under certain circumstances this function does not work and may cause USB devices to fail to respond when called. To resolve this issue, disable power management on the USB hub by doing the following:
  1. Click Start , and right-click My Computer .
  2. Click Properties , then click Hardware .
  3. Click Device Manager .
  4. Double-click the Universal Serial Bus Controllers branch to expand it.
  5. Right-click USB Root Hub , and then click Properties .
  6. Click Power Management .
  7. Deselect Allow the computer to turn off this device to save power .
  8. Repeat Steps 5 through 7 for each USB Root Hub.
  9. Click OK , and close Device Manager .
Jan 17, 2008 | ASUS M2N-MX Motherboard
Asus m2n-e sli Cpu changed settings on boots up
I could not find BIOS ver. 1302 for the M2N-E Mb. What I do know: Your dual core 4200 showing up as "unknown". Asus says:
This is because the BIOS does not have the relative CPU uCode to support this processor. Please simply update your BIOS to version 0902 or later to resolve this problem.
BIOS 0902 can be downloaded from the link below:
http://dlsvr01.asus.com/pub/ASUS/mb/socketAM2/M2N-E%20SLI/0902.zip
Once you cpu shows up correctly, chances are that your over clocking will work and the bios will stop sending you back to change your settings.
Dec 11, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Computers & Internet Logo
395 people viewed this question
David Payne
David Payne
