HP Director malfunction
In my Officejet 5500 series Model No.5510 HP Director is not functioning despite reinstaling the CD driver The reinstallation does not take place .
When I click on HP Director following message is displayed: "CLR error 80004005 The program will not terminate"
    New Friend:
  • 166 Answers
Error:CLR 80004005 For XP only
Fix.
Right click on the programs exe. File (ex. Quick quote Icon) go to properties, click on compatibility. Uncheck “ Run this program in compatibility mode for” Click apply, and then OK.
Posted on Mar 21, 2008
Yes it did it
Posted on Aug 19, 2008
Need a new power cord, how much ?
Here you go:
Compatible Part No:
  • HP 0957-2094
  • HP 0950-4466
Compatible Printers:
  • HP OfficeJet PSC 1350
  • HP OfficeJet PSC 1355
  • HP OfficeJet PSC 2410
  • HP OfficeJet PSC 2410xi
  • HP OfficeJet PSC 2450
  • HP OfficeJet PSC 2510
  • HP OfficeJet PSC 2600
  • HP OfficeJet PSC 2610
  • HP OfficeJet PSC 5510
  • HP OfficeJet PSC 5510 all in one
  • HP OfficeJet PSC 5850
  • HP PhotoSmart 1315 all in one
  • HP PhotoSmart 2510
  • HP PhotoSmart 7960
  • HP PhotoSmart 7960w
  • HP PhotoSmart 7969
  • HP PhotoSmart PSC 2510
  • HP model numbers Q3435AR, Q3435A, Q3501A, Q3087A, Q3090A, Q3094A, Q3020AR, Q3020A, Q3023A, Q3024A, Q3021A, Q3022A
  • HP Bundle PSC1315+M307 Q5776A
  • HP OfficeJet 5500 Series All-in-One Q3434A, Q3435AR, Q3435A, Q3435P, Q3436A, Q3437A, Q3438A, Q3440A
  • HPPSC 1300 Series All-in-One Q3492A, Q3493A, Q3495A, Q3500A, Q3501AR,Q3501A, Q3502A, Q3503A, Q5532A, Q5534A, Q5763A, Q5765A, Q5766A, Q5767A,Q5768A, Q5769A, Q5770A, Q5771A, Q5772A
  • HP PSC 2410 PhotoSmart All-in-One Q3087A, Q3088A, Q3089A
  • HP PSC 2500 Series PhotoSmart All-in-One Q3094AR, Q3094A, Q3095A
  • HP PhotoSmart 7900 Series Printer Q3020AR, Q3020A, Q3021A, Q3022A, Q3023A, Q3024A Q3090A
For HP 0957-2094 PhotoSmart 2410, 2510, 5510 Printers and much more.Come with power cord. Power Rating: 32V 940mA and 16V 625mA
Note: Amps and Watts are maximum load tolerance. Devices only draw as many Amperes or Watts as they needed
For purchasing you might also contact this link below:
http://cgi.ebay.com/Adapter-For-HP-0957-2094-0950-4466-32V-940mA-16V-625mA_W0QQitemZ250414311173QQcmdZViewItemQQimsxZ20090427?IMSfp=TL090427149005r21586
Hope you like my info
May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
HP 5510 Scanner/Copier/Fax Stuck
I had the same problems some months ago. I only solved it when I deleted the printer settings from my computer and reinstalled the software, making sure that I installed all the components from the CD. Also make sure that the printer is on fax default setting when you are using it as fax. You can check this by going to My Computer then Control Panel, then choose Printers and Other Hardware then choose Printers and Faxes. You can then set as default hp Officejet 5500 series fax. Hope these suggestions help.
Jan 08, 2009 | HP Officejet 5510 All-In-One Thermal...
We have an hp officejet 5500 - our laptop failed a few weeks ago so we brought it back to Best Buy - they installed new hardware - reinstalled the operating system but not the hook up to the printer - I...
Dear Dpatch.
Here is the link for the driver of your HP Officejet 5500, you can direct download the driver for your Officejet 5500 :
http://www.soft32.com/download_171164.html
Be Happy Always
Regards
Dec 04, 2008 | HP Office Equipment & Supplies
WHERE COULD I DOWNLOAD THE HP DIRECTOR SOFTWARE
Hi go to hp site find utiliity section for this printer
Sep 03, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
H P Director not working
hi yesjay,
I've seen this exact same problem before. What I deduced from that experience is that the Readiris software takes over the redirector function of the HP Director service. The only way we got the HP Director to function again was to:
1.) Uninstall Readiris
2.) Uninstall the HP printer
3.) Reinstall the HP printer without installing Readiris
This resulted in the HP director service working properly again, but with the user unable to use the character recognition functionality provided by Readiris.
Hope this information helps to clarify your current situation and thanks for using the FixYa service
Kind regards
Feb 15, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Printer installation
ok how is the computer hook to printer ,
(usb? or serial cord) ?
what operating system are you using
and what software are you using for print drivers
let me know and i can help you in greater detail but here is a link to hp for your printer
i hope this is somewhat helpful
feel free to reply back if you cant get it working im shure i can help
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+5510+All-in-One&opname=HP+Officejet+5510+All-in-One&qry=I+am+having+trouble+with+the+computer+recognizing+the+HP+Officejet+5510.++What+can+I+do%3F&method=prodFinder&ctry=us&lang=en&dlc=en&sni=311255&search=0&submit.x=0&submit.y=0
Oct 31, 2007 | HP Officejet 5510 All-In-One Thermal...
727 people viewed this question
jasbo
jasbo
