Question about Apple iPhone Smartphone
I cant restore my iphone
I bought an unlocked iphone and everything was great until i got the yellow triangle and connect to itunes message.
Everytime i try to restore it to its original settings or use an updated version,It just says waiting for iphone and nothing at all happens.
If you could give me an idiot proof guide of how to sort it out,It would be greatly appreciated
  • Apple Master
  • 19,396 Answers
  • Ginko
    Ginko Mar 20, 2008
    If you get this sign
    then follow the solution below
    If Itunes doesn't see your iPhone, you may need to invoke recovery
    mode. Although this is an extremely helpful tool, how to use it is not
    very apparent. ?
    It's actually very simple:
    Turn off your iPhone by holding the "Sleep/Wake" button for about
    five seconds and then sliding the red slider. If your iPhone is already
    off, there's no need to turn it on and then off again. Once it's turned
    off, press and hold the "Home" button and plug the iPhone into your Mac
    or PC. Keep holding the "Home" button until you see a yellow triangle
    and text which says "Please Connect to iTunes". You can now release the
    button. Open iTunes (if it's not already open) and you will be told
    that "iTunes has detected an iphone in recovery mode". Click "OK" and you will be taken to the iPhone pane.
    Click restore and you're done. Depending on the extent of your iPhone's
    ills, it may take some time to do a full restore. Once you're done,
    however, you should again have a perfectly working iPhone.
    If this doesn't fix your problem, your iPhone likely needs to be serviced.
    regards
My 3g iphone is locked disable and i dont have any passcode that i remember i can not go to itoones neither how can i unlocked
  • Rank: Apprentice
  • Rating: 100%, 1 Votes
Some of the advice from the reply from Joed911 is correct. I used to work tech support for Apple Care on the iPhone, and I can tell you that there is no link in iTunes that say's "Unlock your iPhone" THESE ARE YOUR OPTIONS .............. 1) Your daughter can remember the password she set. 2) You will need to restore his iPhone using iTunes. *** Assuming # 1 is not an option I have instructions on how to restore his iPhone. Restoration of iPhone to original factory defaults will fix your problem, with the downside that all data and information stored on your phone will be lost. Normally iTunes will make a backup automatically when you connect and sync the iPhone with the program, however, it?s still a good recommendation to copy out and backup everything that you may need on the phone before proceed to restore the iPhone. To manually back up his iphone: ~Connect to itunes , on the left side of the itunes page you will see the iphone icon. ~ Right click the iphone icon ( under devices) and choose back-up from the drop down box. To restore iPhone and reset the phone to default factory settings, follow these steps: ***Easiest way to restore his iPhone: (this will work if his iphone is recognized in iTunes under devices) ~ Just left click on the iPhone icon under devices in itunes , ~ under the summary pane you will the option to restore his iphone. ~ click "RESTORE IPHONE" ~ wait for the process to finish restoration . ***** If his iPhone is not recognized in itunes under devices you will not see the iPhone icon. In this case you will need to restore with this method. 1. Turn off iPhone ? Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off. 2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iPhone Recovery Mode 3. Plug the iPhone into Mac or Windows PC. Release the button if you haven?t. 4. Run and open iTunes if it?s not already opened yet. 5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK. 6. You will be taken to the iPhone pane. Then, click on Restore. 7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings. AFTER RESTORING THE IPHONE YOU CAN >>>RIGHT CLICK IPHONE AGAIN UNDER DEVICES AND CHOOSE RESTORE FROM BACK-UP TO REPLACE SOME OF HIS INFO PREVIOUSLY ON THE IPHONE. Hope this was helpful , and Good Luck !! Teresa
Jan 18, 2011 | Apple iPhone 3G
Forgot password iphone
you will have to restore it with itunes but if it dosent HOLD the Power Button and the Home Button until a 'Yellow Hazard Triangle' Appears...(25 SECONDS)
Then connect to iTunes and it will prompt to Restore
Jan 09, 2011 | Apple iPhone 3G
My daughter set a password for son's iphone 3G and she cannot remember the password, can someone advice me how to unlock the phone
Plug it into iTunes with it at the unlock screen. Somewhere it should say "Unlock your iPhone" or something like that in iTunes. Click it. Otherwise do a restore by going to the screen where it shows how much memory you have used up in iTunes and click restore.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 08, 2011 | Apple iPhone 3G
I brought a second hand 3 g iphone offline. When it came it was unlocked, i put it on itunes and it said that the sim was not supported, so i restored it. Now I have nothing on the phone at all ,just to...
Follow these steps to try and get your phone running - although I cant guarantee it is unlocked, you'll have to take it up with whom you bought the phone off but if they unlocked "jail broke" it themselves and not via their network which they where locked to then it is most likely the phones software is altered with and restoring it will make no difference....
Power up your computer & itunes & make sure you have updated your itunes then power down your iphone and follow the steps below!
  1. Hold down the home button and continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button *** if this doesn't appear then release button and hold down again for around 6secs and then still holding the button plug into the computer***
  2. The above message will appear in iTunes
  3. Continue with the restore option and when you get the screen to setup the iphone select restore as new iphone
Like i said before, if who you bought the phone from unlocked it themselves then its most likely the software is affected within the phone
Dec 30, 2010 | Apple iPhone 3G
My iphone 3gs got stucked and i cannot operate any of the functions, not even sleep/wake mode also
  1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
  2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iphone-recovery-mode.jpg
  3. Plug the iPhone into Mac or Windows PC. Release the button if you haven't.
  4. Run and open iTunes if it's not already opened yet.
  7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it's hardware related.
Oct 23, 2010 | Apple iPhone 3G
I've recently changed my pass code on my iphone and forgotten it, how can i reset my iphone so i dont have to type it in?
  8. google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Oct 04, 2010 | Apple iPhone 3G
IPhone 3G: I cannot turn on the phone...
Restoration of iPhone to original factory defaults will likely to fix all problem, with the downside that all data and information stored on your phone will be lost. Normally iTunes will make a backup automatically when you connect and sync the iPhone with the program, however, it’s still a good recommendation to copy out and backup everything that you may need on the phone before proceed to restore the iPhone.
Turn off iPhone – Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
Run and open iTunes if it’s not already opened yet.
Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related.
May 16, 2010 | Apple iPhone 3G
The pass code screen pops up and i cant remember the pass word what do i do
Hold the Power Button and the Home Button until a Yellow Hazard Triangle Appears (25 seconds)
Then connect to iTunes and it will prompt you to Restore
Oct 29, 2009 | Apple iPhone 3G
It seems that my iphone 3g is processing lot of things. so , it seem to be lagged. Does it have like reset button or anything?
1.Turn off iPhone – Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your ifone already off. 2.Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. 3.Plug the iPhone into Mac or Windows pc .Release the button if you haven’t. 4.Run and open iTunes if it’s not already opened yet. 5.iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK. 6.You will be taken to the iPhone pane. Then, click on Restore. 7.Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related problem.
Aug 13, 2009 | Apple iPhone 3G
The entire screen magnified itself and wont go back 3g's
Just double click the screen with three fingers :-)
Jul 01, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
53 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
