FixYa.com
Tags:
Brother MFC-210C All-In-One InkJet Printer
Only print on black and yellow (by 2 users)
posted by mandrakos on Mar 20, 2008
my mfc-210c will only print in black and yellow even when i have cleaned it the cartridges are all full No matter how mant times i clean it its always the same
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by sgsaxman, posted on Mar 25, 2008
All of a sudden the magenta stopped printing. After cleaning multiple (perhaps 10) times, I can get two dashes of magenta in a test print out of the 150 that are supposed to show up. Brother Help says, "must be a mechanical defect, since you're using our print cartridges." As the machine is out of warranty, I'm thinking I could buy a new one for the cost of repair. Any suggestions on how I might proceed before pitching it in the trash?
Best Solution
posted on Mar 24, 2008
Helpful (85)
bigdaddy67
Rank:Master Master
Rating: 88%, 45 votes
Brother units are very sensitive when it come to using generic ink. If you have used generic ink you will need to buy Brother ink and run through the cleaning cycle at least 4 times. Print a test sheet, if the color begins to come back, the generic ink is the issue. Generic ink may have damaged the print head also.
Rating Locked! (?) mandrakos has rated this solution as Helpful
Solution #2
posted on Mar 22, 2008
Helpful (85)
Mix-it-up
Rank:Guru Guru
Rating: 88%, 1022 votes
did you use generic ink? those ink will clog the ph espacially the mag + yellow channels.
do use original brother ink carts because these contains special cleaning fluids!
Can you Help with these Printers problems?
Brother MFC-210 printing...
The printer works but only... Answer This...
scan pictures full scale
How do I scan pictures to take... Answer This...
programming of Laser 8500 fax
How do I program the 8500 to... Answer This...
Color printing problem
I can get the unit to manually... Answer This...
Gaps/Missing Ink in Checking...
I can't print, the quality very... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
