Question about Dryers
My noisy hoover tumble dryer...help please!
My Hoover nextra condenser dryer has been making loud rubbing/squeaking noises for some time now. We took the top off to investigate further but everything is hidden underneath the drum. How do we find out the problem and does this machine need totally dismantling to fix it!!Hoping you can help Jennifer
P.s it still works and have been using it but the noise is starting to get louder!
  • owenstribe Aug 08, 2008
    Mine is not a condenser but the squealing noise when the drum turns is unbearable now. Mine is a Hoover Nextra 6kg. Would love to know how to cure this please!!!!!!!!!!!
  • Anonymous Apr 06, 2009
    Yup, I have the same problem.
  • 56 Answers
Possibly bearings gone on drum shaft
Posted on Mar 20, 2008
SOURCE:
I have a Hoover nextra 6 kg condenser tumble dryer which is leaking water and the collector is empty and seems not to locate fully into the hole at the back?
Check for Lint/Dirt in the Drain and then you need to ensure it is fully connected in the Washer to the Drain...
Jan 03, 2015 | Hoover Dryers
Hoover HDV 7 FM tumble drier. The drum is not turning (its making a loud buzzing noise like its trying to get going) and the filter light is on, although that is free from fluff. Is it time for a new drier...
sumanth m 's answer may well be correct because I have the same dryer and it has the same problem. I got a massive electric shock off mine and so I think the buzzing is a protection measure against a short circuit
Feb 15, 2011 | Hoover HDV7FM Electric Dryer
My hoover dryer vhc392t makes a loud squeaking noise when in use can it be repaired
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 23, 2010 | Hoover Dryers
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Noisy when running need to check belt and bearings
i need the serial # to assist you better
thank you
May 14, 2009 | Dryers
Nextra7 condenser dryer making squeaky noises
heatman101
tukuymhg
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover Nextra 8 dryer making a squealing noise
you have to open the dryer and lubricate the rollers, these are the parts that normally make the squealing sounds.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Dryers
Hoover hdv fm tumble dryer
only thing may make a buzzing sound is a relay not making up or a motor contactor not closing all the way.
Sep 11, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Dryers Logo
1,418 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
